Old 04-27-2006, 03:54 PM   #946
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
So youre saying that when youre not holding down the set button all leds are on? If you can steer and accelerate then youre not in the programming mode. When you first hold down the set button you have to do the throttle, brake and neutral thing then go into the actuall programming and selecting what profile. Correct me if Im wrong.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-27-2006, 03:57 PM   #947
Dan415ms's Avatar
I have done the one touch programming (i.e. hold down set button and then set up speedo for throttle neutral and brake). I'm confident i've done it correctly as it's the same method as my GTX and other Novak's I've had to set-up.
It's when I switch on the unit, ready to use the car, that the LED's I explained occur:
Neutral
When in neutral, the blue, amber & red LED's are solid on.
Throttle
When I apply throttle the motor spins, the red LED goes off and the blue & amber stay on. Full throttle shows solid green instead of red but the blue + amber still stays on?
Brake
As soon as I apply brake (from neutral) the red & blue disappear (amber stays on) and on full brake I get blue and amber solid and the green LED flashes.
Dan415ms is offline   Reply With Quote
Old 04-27-2006, 04:05 PM   #948
Dan415ms's Avatar
Just got email reply from Charlie @ Novak - I sent him just what I posted on here:
Hello,
All of that is exactly what is supposed to happen.
You've done an excellent job on your description.
Totally normal.
Old 04-28-2006, 01:29 PM   #949
syndr0me's Avatar
Trader Rating: 32 (100%+)
Well, they're definitely working on a motor that's even more detuned than the 4300, presumably to make it a little more reasonable as a replacement in stock racing. They said it'll be several months still, but it's a common request, and one they're taking seriously and actively developing.
syndr0me is offline   Reply With Quote
Old 04-28-2006, 01:34 PM   #950
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
yes it is the 12.5 and the 14.5 turn I saw them both run last weekend .
Old 04-28-2006, 01:43 PM   #951
syndr0me's Avatar
Cool, that will be pretty great for club racing I imagine. Interesting that the dropped 2 turns for the detuned motor. I'm sure they know what they're doing, but the 4300 (10.5) seemed pretty close. Hey Novak, if you need any testers, you know where to find me! :-D
At some point, it seems like the 5800 and 4300 are going to need to update their names. Here's my updated list of motors (present and future) in this class:
Novak Brushless
3.5R (3.5 turns) [rumored, not yet available]
4.5R (4.5 turns)
5.5R (5.5 turns)
6.5R (6.5 turns)
7.5R (7.5 turns)
5800 (8.5 turns)
4300 (10.5 turns)
12.5R (12.5 turns) [rumored, not yet available]
14.5R (14.5 turns) [rumored, not yet available]
Reedy Brushless
5-Star (4.5 turns?) [rumored, not yet available]
4-Star (5.5 turns)
3-Star (6.5 turns)
2-Star (7.5 turns)
1-Star (8.5 turns)
Old 04-28-2006, 01:47 PM   #952
Super Moderator
Marcos.J's Avatar
Novak Brushless
4.5R (4.5 turns)
5.5R (5.5 turns)
6.5R (6.5 turns)
7.5R (7.5 turns)
5800 (8.5 turns)
4300 (10.5 turns)
Reedy Brushless
4-Star (5.5 turns)
3-Star (6.5 turns)
2-Star (7.5 turns)
1-Star (8.5 turns)
I seen the 5 star by a team driver( P??) and its fast! Our ROAR region director tested both the 12.5 and the 14.5 and they are both pretty competative in stock class, I may test one of them at our next club race(maybe).
Old 04-30-2006, 08:42 AM   #953
Birky's Avatar
Hey Guys,
I'm looking at getting a brushless system and I'm just wondering if there is any benefit to cooling the motor using a Much More Motor Thermocooler?
Cheers
Ben
Smash 'EM! F1 Racing: WA's Home of Fun in Formula 1 RC Motorsport.
Birky is offline   Reply With Quote
Old 04-30-2006, 08:43 AM   #954
Super Moderator
Marcos.J's Avatar
Originally Posted by Birky
Hey Guys,
Cheers
Ben
you wont have to if you gear it correctly
Old 04-30-2006, 01:12 PM   #955
syndr0me's Avatar
Hey Guys,
Cheers
Ben
Supposedly the MuchMore 30MM fan will help keep the ESC cooler than the stock Novak fan, and it's got the same plug on it. I imagine anything to keep the motor cooler couldn't hurt, but I don't know for sure. Gearing it properly is the first step, but if you're trying to squeeze more out of it than it's willing to offer, give it a try, it might help.
Old 04-30-2006, 01:26 PM   #956
bhambrent's Avatar
Anyone know a online hooby shope the sale the MuchMore 30mm fan?
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 04-30-2006, 01:32 PM   #957
syndr0me's Avatar
http://nexusracing.net/product_info....products_id=76
They're out of stock though. Same with Speedtech.
MuchMore 30mm ball bearing fan: part# MR-30FAN
30mmX7mm
Wire length=200mm.
5V, 0.17A, 0.85W
Old 04-30-2006, 06:01 PM   #958
BrianH28's Avatar
What roll out should I run on my Corally RDX. I have a Novak 4.5 system and I shut down in the A-main last week with a 105/30. Where should I be to be fast and not thurmal?
BrianH28 is offline   Reply With Quote
Old 04-30-2006, 06:05 PM   #959
Super Moderator
Marcos.J's Avatar
it should have a FDR between 9.75 to 10.25 , I run a 10.17 and the car comes of the track around 141 degrees. Are you running on carpet or asphalt?
Old 04-30-2006, 08:31 PM   #960
BrianH28's Avatar
I see your in Tampa, do you run a speedline? I run in Port Charlotte. It's asphalt.
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
