Old 03-31-2006, 05:20 PM   #826
RCknight's Avatar
Default I'm sorry but the 4300 is not even close to a well tuned
19t. In fact, I'm having a hard time keeping up with well tunned C27 stock motors. Oh, I guess I could gear to the moon, but I try to keep motor temps around 130. I would like to see Novak make a slower motor for the novice class.
RCknight is offline   Reply With Quote
Old 03-31-2006, 05:23 PM   #827
syndr0me's Avatar
Trader Rating: 32 (100%+)
Yea, I have to agree. Fast stock guys have about the same top speed as the 4300... maybe just slightly less if you really gear it aggressively. What they don't have is the incredible rip of the 4300. 19T kills 4300.
syndr0me is offline   Reply With Quote
Old 03-31-2006, 07:54 PM   #828
bhambrent's Avatar
Lightbulb
A 19t has more punch at the being of a run. But ss4300 get it back at the end of a run.
If you put the upgrade kit on the ss4300, it will be the same as a 19t the whole run.
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 04-01-2006, 03:34 AM   #829
lookinco's Avatar
Just finished installing the GTB onto my Cyclone. Took me a while to figure out the best fitment without all the messy wires. I also used dean plugs so I could switch between brush and brushless motor easily.
lookinco is offline   Reply With Quote
Old 04-01-2006, 04:16 AM   #830
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
In fact, it would be possible to have more profiles in the ESC's that limit he RPM counts which is totally possible with the sensored BL ESC's. You could have 27T, 19T and Modified profiles ready in the speedo. This would make racing very fun. Just program the speedo and you'll be running any class.
The motor manufacturers worst nightmare though, so it probably wont be reality in a couple of years.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 04-01-2006, 07:33 AM   #831
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
looks very neat! Im sure Jason from BMI wil want to see this picture
Old 04-02-2006, 11:13 PM   #832
lookinco's Avatar
THANKS!, Yeah it took me a while to make it all nice and tidy!
I am trying to find the right motor to run with my brushed motor friends.
so is the SS4300 with upgrade kit equal to the speed of a fast 19T motor?
What would be the closest match of brushless motor to brushed 27T and 19T motor?
Old 04-02-2006, 11:37 PM   #833
syndr0me's Avatar
A SS4300 about 1-2 teeth undergeared will have very similar top end and a bit more rip than a fast stock motor, and that's with the upgrade kit. It can't touch a fast 19T. If you need proof of this, check out the difference in laps at the Novak race where they had a 4300 class. It was right about in the middle of 27T and 19T. The 5800 is considerably faster than a 19T, and again, has a lot more rip.
I found the upgraded rotor and endbell didn't make the motor faster, but did give it a bit more rip. It also made it smoother by eliminating the vibration problems it had.
I really enjoy driving with the 4300. It's a great combination of speed and torque, and the smooth powerband is a real treat. It's far more enjoyable than driving with a stock brushed motor, and it remains consistent throughout the run. Stock motors seem to be a compromise between RPM and torque. The 4300 has plenty of both.
Old 04-03-2006, 11:04 AM   #834
FBJ's RDX's Avatar
Originally Posted by Evicerator
The brushed mode in the GTB is the same as profile 3 in the GTX
Hi Steve,
I need some help with setting the GTB to have a smoother power curve when using a 4.5 Velociti motor. The 4.5 has so much rip out of the corners that it literally makes my car understeer on-power no matter how I slowly get on the throttle. Is there a way to go about this? I am looking for the smoothness of an 8x1 Checkpoint motor....Im new to the brushless scene and i don't know if I'm asking for is possible on the GTB. Any tip or advice will be greatly appreciated. Thank you very much.
Sonny
FBJ's RDX is offline   Reply With Quote
Old 04-03-2006, 11:10 AM   #835
Super Moderator
Marcos.J's Avatar
Originally Posted by FBJ's RDX
Hi Steve,
Sonny
I did mine on the Radio(M11) and I put a little more drag brake on the esc
Old 04-03-2006, 11:31 AM   #836
The Evicerator
Sonny,
You can try running profile 3 which has a slightly lower minimum drive % rating which should result in a "softer" bottom end feel.
If this is not enough however you can try using some negative exponential in the throttle channel to get more of a feel you want. I would not go overboard with this though... I would move in increments of 5% until you find the feel that you are looking for.
Another thing to consider is your gearing... when running a 4.5T I generally run around a 9.5 gear ratio... Depending on your application and track size, this may vary a bit...
Hi Steve,
Sonny
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-03-2006, 07:20 PM   #837
FBJ's RDX's Avatar
Sonny,
Hi Steve,
Thank you very much for your input. I'll try it next time I hit the track. Btw, I run in a 112Ft X 75Ft Technical Track with a Final Drive of 10.00, the motor temp reaches to 165*F. Is it possible to gear up some more? Thanks again.
SOnny
Old 04-03-2006, 07:31 PM   #838
Super Moderator
Marcos.J's Avatar
Hi Steve,
SOnny
i was running a 10.11 on my 4.5 on a similar size track and it camo off the track at a 171 degrees! I spoke with Charlie today and he advised me that I could gear up more towards a 10.6 or so!!
Old 04-05-2006, 12:30 PM   #839
Does anyone know if novak or lrp is working on a stock 27T brushless motor?
kahuna2793 is offline   Reply With Quote
Old 04-05-2006, 12:40 PM   #840
The Evicerator
Sonny,
It seems like you're getting close to the "safe threshold" of the motor... I would recommend trying the gearing that you are currently using in race conditions just to confirm that you do not experience any problems, and if you feel confident in the temperature and the performance you can probably go up a tooth safely.
But like always, monitor the temperature of the ESC and the motor.
Hi Steve,
SOnny
Steve Weiss
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
