New Novak Brusless System >
Old 03-13-2006, 03:30 PM
  #721
nnick,
at the 1/12th euros some team drivers had a 4 star and a 5 star and were testing them against the 5.5r and 4.5r
according to a driver who was there that I race with, he said on sunday that the LRP lacks punch out ogf the corners. i suspect this is a software problem rather than the motor / esc itself
TraceRacing is offline
Old 03-13-2006, 03:37 PM
  #722
Thinking about doing the jump to brushless. I want to start running mod, but the cost and hassle of cutting the com every 2-3 runs really gets old. I figured with the brushless I can maximize practice time. So how do these brushless compare with the mod motors. I was running an 8x2 and a 9x2 this past weekend. Loooking for something comparable to the brushed mods I was running. Thanks.
Proteus is offline
Old 03-13-2006, 03:39 PM
  #723
Super Moderator
Marcos.J's Avatar
Trader Rating: 237 (100%+)
get the GTB with the 4.5 is fast !! its supposed to be faster than a 7 turn! I have it and I got it geared at a 10.11 fdr and it still wants to accelerate at the end of the straight
Marcos.J is offline
Old 03-13-2006, 03:43 PM
  #724
having recently made the very change you are thinking of, here's my take on it.
GTB with 5.5r is a tad quicker than a 10 turn, not as quick in a straight line as a 9, but with greater efficiency found i was reeling in 9t in the final 40-50 seconds as there was no noticable drop off in peformance at the end of the race.
My only gripe with the Noval is the sensor harness wire - if the made an external to motor connection similar to the one on the GTB they could sell loads of different lengths for us to select which best suits our layout. In my Xray the gtb is maybe 10mm away from the motor - but I have about 15 yards of harness to "loop" which looks really messy.
Old 03-13-2006, 03:49 PM
  #725
Super Moderator
Marcos.J's Avatar
I shorten the wires on mine with no change on performance,now they are about 3 inches just enough to reach the ESC
Marcos.J is offline
Old 03-13-2006, 04:31 PM
  #726
Thanks for the input. I guess I should just go with the 4.5. and pick up a 5.5 for smaller and/or technical tracks.
Proteus is offline
Old 03-13-2006, 04:36 PM
  #727
Super Moderator
Marcos.J's Avatar
I bought the 5800 for short technical tracks and it works great, I have the 4.5,5.5,5800 and Im getting the 6.5 also to try out!
Marcos.J is offline
Old 03-13-2006, 05:53 PM
  #728
Instead of purchasing 2 or 3 Brushless motors, wouldn't it the same to just get one 4.5 or 5.4 motor and make adjustments through the radio systems and GTB Esc unit to make the motor more controllable on smaller more technical tracks?
vadn1 is offline
Old 03-13-2006, 06:03 PM
  #729
My choice would try gearing down so and have gobs of torq if car is to fast.
corwin is offline
Old 03-13-2006, 06:31 PM
  #730
vadn
in large high speed track, you need all the power you can have from the motor. 4.5 motor is the way to go. Peaky power curve is not going to cause drivability problems case high speed track is usually wider and longer
for technical track, you need a lot of torque and flatter power curve. I would go with 6.5 or even 5800 motor. Drivability is the key for technical track.
azmio is offline
Old 03-13-2006, 07:11 PM
  #731
what was I thinking, The torque curve for the 5800 , 6.5, 5.5 and 4.5 will be different...
vadn1 is offline
Old 03-14-2006, 12:05 AM
  #732
AngryAsian's Avatar
WOW>......
we ran my friends 4.5 today. Unfortunately, we were short on time so we couldn't do a literal side-by-side compario of the 5.5 and the 4.5.
But wow did that car fly... Good power. Good speed. Definately a big jump up from the 5.5....
We came away quite impressed. It was about as fast as i've seen any other motor go, so that's a good sign. Bjust have to see what it's like on track..
AngryAsian is offline
Old 03-15-2006, 03:59 PM
  #733
James's Avatar
Does any1 have any suggestions regarding braking for a GTB/5.5 in an XRAY T2 (running a one-way)? that is, without the car completely spinning out under brakes..?
would drag brake slow the car down without it spinning out? should i fiddle with the ABS function in my helios radio? Should i just change the front diff to fully locked (solid axle?) to get more stable braking?
never used the BL system yet, I'm a stock racer moving to mod, about to throw it in for some action this weekend. Pretty tight track, technical. following w'end i have a huge open track to race on..
suggestions welcome!
James is offline
Old 03-15-2006, 04:00 PM
  #734
Super Moderator
Marcos.J's Avatar
just cut back on your brake travel on your radio
Marcos.J is offline
Old 03-15-2006, 04:25 PM
  #735
James's Avatar
that simple huh? I'll check it out!
James is offline
