New Novak Brusless System >
Old 11-04-2005, 03:34 PM
  #466
Charlie's Avatar
Hello,
Check that you get a Red LED when you're at neutral (along with the other LEDs depending on your setting). If the Red LED is not on, the ESC is not seeing it's neutral and will make it not go on initial throttle input.
When you drive it, is the front part of the trigger movement dead??
Usually, when a cap dies, the Cap Pops, or it vents, Usually the ESC is wounded within the first run of the cap being bad.
If the ESC is getting hot just sitting there not running, there are two possible problems, one is a short in your wiring to the chassis or battery, or to each other, the second is that system has not been set to the radio yet. A very common mistake.
Email me directly for details on this if you'd like, that's what I'm here for.
[email protected] or [email protected]
Charlie
Dan- Glad it's got one under it's belt so far.
WC- Thanks, Now all I have to do is convert you somehow, then I can retire....
Charlie is offline
Old 11-04-2005, 04:08 PM
  #467
jw92656's Avatar
Thumbs up
Hi Charlie,
I love my new Velocity system I got in my BK2. Is there anyway to upgrade two SS5800 systems that I own to the Velocity system ? I saw a New Model Replacement section on Novak's website and thought I would ask. Thank you kindly.
jw92656 is offline
Old 11-04-2005, 04:36 PM
  #468
Charlie's Avatar
In the future things like that should really be emailed, eventually new products make it to the New Item Upgrade list, but it's usually several months after it's realeased. Other then that, there are no real "upgrades" through us.
Charlie is offline
Old 11-04-2005, 04:58 PM
  #469
jw92656's Avatar
Sounds great, I'll be on the look out. I actually sent out an Email first on Monday at 3:01pm, but my company blocks stuff like this sometimes. So I wasn't sure if you had got it ? Thanks.
jw92656 is offline
Old 11-05-2005, 08:40 AM
  #470
Team Duratrax's Avatar
Originally Posted by danjoy25
Checkout the previous post of someone using a modified 3 way deans plug which is very neat.
Do you have any idea on where that post is? I need to make one.
Team Duratrax is offline
Old 11-05-2005, 12:22 PM
  #471
jaejw1's Avatar
Originally Posted by Charlie
Hello,
Charlie
i didnt calibrate it to the transmitter prior to the incident nd now when i try to calibrate it it wont recognize full throttle or full break,,,
and alsowhile running it, the green light for throttle only comes on when it is at way open throttle...
jaejw1 is offline
Old 11-05-2005, 05:00 PM
  #472
mini-dub's Avatar
Trader Rating: 16 (100%+)
Charlie
jaejw1 - I think it's best to email these questions to Charlie or Novak directly. The green light is supposed to only come on at full throttle though. That's how you can check to make sure it's reaching full throttle.
mini-dub is offline
Old 11-08-2005, 03:09 AM
  #473
Trader Rating: 16 (94%+)
if possible would someone mind measuring the actual size of the GTB esc (depth, width, height), the only dimensions shown on the novak site are the footprint, which I assume is not the total size of the case incl tabs/switch/etc...
domo is offline
Old 11-08-2005, 03:22 AM
  #474
danjoy25's Avatar
Trader Rating: 38 (100%+)
40x40x32
danjoy25 is offline
Old 11-08-2005, 03:28 AM
  #475
thanks! now to see if it will fit on the cyclone...
domo is offline
Old 11-08-2005, 08:51 AM
  #476
Davidka's Avatar
Trader Rating: 85 (100%+)
Ok this might be reaching but here goes. Does anybody know if you can run the 5800's rotor and front portion of the can? I'm wondering if this would be a good idea to soften the power delivery of the 6.5. Also, is the rotor and front (from the Velociti) an available option for the 5800? I had a 5800 and now I have a 6.5 but the 6.5 is a little much for 70x40 offroad tracks.
Davidka is offline
Old 11-08-2005, 10:41 AM
  #477
Sense the winding is in the can not the rotor I donít think it would make a difference even if the parts are interchangeable between the to motors. Do you have a radio that you can change the throttle endpoint down?
Davenport is offline
Old 11-08-2005, 04:40 PM
  #478
What's the difference between the 5.5 and 6.5?
everythingsale is offline
Old 11-08-2005, 04:54 PM
  #479
danjoy25's Avatar
The difference is the 5.5R has less windings than the 6.5R. Its like comparing a 6 to a 7 turn brushed motor, everything is the same except the winding. I open my 5.5 once and can see the the windings a stuck in the can. I doubt if the rotor will be different with a 6.5.
danjoy25 is offline
Old 11-10-2005, 02:15 AM
  #480
Suspended
GordonFreeman's Avatar
Dave, just turn your end point down I'll try the rotor/end bell swap for ya anyways.
This is what I'm talkin' 'bout. Within a 2 minutes I can change from nice sweet brushless to old tech nasty brushed!
GordonFreeman is offline
