New Novak Brusless System >
Old 04-03-2008, 04:37 PM
  #2656
zenithrr's Avatar
yea, don't forget about the heat. someday we all learn to put the finger with ease on the throttle. sensors tells me the temperature and speed according to it,
zenithrr is offline
Old 11-29-2008, 06:58 PM
  #2657
KoE
KoE's Avatar
Default need help
if anyone here running GTB SS-M8-spektrum-hacker combo? i really need your help to set up the GTB to M8/Spektrum...as the esc blips the motor for about 1 sec @ switch on
KoE is offline
Old 11-29-2008, 07:11 PM
  #2658
ray3619's Avatar
i run gtb w/spectrum no problem , my son runs novak cyclones w/spectrum and one of his does the 1 second th blip at turn on , weve never been able to cure , waiting to here what others say , ray
ray3619 is offline
Old 11-30-2008, 01:56 AM
  #2659
KoE
KoE's Avatar
ray...i've re-bound the rx/tx ....problem gone!
btw, does anyone know what is this: (found in GTB setting up manual)
F.
Set ELECTRONIC TRIGGER THROW ADJUSTMENT to 70% throttle and
30% brake
throw (or 7:3) for Forward & Brake only Profiles
and how to accomplish that in Airtronics/Sanwa M8 ?
KoE is offline
Old 11-30-2008, 07:31 PM
  #2660
Davidka's Avatar
Trader Rating: 85 (100%+)
Nothing needs to be done. The M8 is set to that throw already. Some older radios had an option to run a 50/50 trigger/brake throw but most race oriented radios are set up 70/30 from the factory.
Davidka is offline
Old 12-01-2008, 02:16 AM
  #2661
KoE
KoE's Avatar
thanks for the info
KoE is offline
Old 12-12-2008, 10:31 AM
  #2662
Racingbod85's Avatar
Unhappy
Help!!
I've just re-installed my GTB (std) and a 10.5R into my 12th. motor ran fine before it went in. soldered it back up and it won't go. no warnings on speedo, all lights do as they should. it has brakes and drag brake but when you apply power it feels like the brakes are on.
i've checked all the wiring and re-setup the speedo but nothing is working.
It seems to me it's motor related but i haven't got another to try.
i also shortened the Cap wires when it went in.
CAn anyone help?
Racingbod85 is offline
Old 12-12-2008, 10:40 AM
  #2663
The Evicerator
Double check to make sure that you soldered the cap back onto the board correctly.
TRIPLE check to see that you didn't accidentally solder the motor leads on inccorectly OR that the tabs are shorted somehow... even a tiny little whisp of solder between tabs can cause a problem.
Blue to A
Yellow to B
Orange to C
Originally Posted by Racingbod85 View Post
Help!!
CAn anyone help?
Steve Weiss is offline
Old 12-12-2008, 01:09 PM
  #2664
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Is the Havok speed controller going to be packaged separately? I have been building a few cars buying motors alone. Right now I'm one ESC short. I'd like to put the GTB back in my other car if possible and run a 21.5 havoc combo in my spare TA car.
liljohn1064 is offline
Old 12-12-2008, 01:37 PM
  #2665
The Evicerator
As of now I know of no plans to sell the Havoc ESC separately, but I'm not 100% sure one way or the other. Sorry
Old 12-12-2008, 02:12 PM
  #2666
SpidarX's Avatar
Should you be able to rotate the purple motor sleeve on a completely assembled motor? I bought a used novak 10.5 that had a heatsink motor sleeve on it. I took that sleeve off and replaced it with the original purple sleeve, but after re-assembly, I can still rotate the purple sleeve. Is this normal? Thanks
SpidarX is offline
Old 12-12-2008, 02:17 PM
  #2667
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
I've seen the sleeve on the Novak motors be able to rotate. I asked a friend who owned one about it. It appears to be normal.
SpraydbySprague is offline
Old 12-12-2008, 02:22 PM
  #2668
All of mine spin, 4 21.5s and 1 17.5. I move them around so the wind count can easily be read.
Old 12-12-2008, 02:39 PM
  #2669
The Evicerator
The sleeve can rotate in certain circumstances and wouldn't worry about it. It should not effect the performance at all.
Old 12-12-2008, 05:38 PM
  #2670
burbs's Avatar
I didnt have time to read the whole thread so please excuse me if this is posted already. I have heard of a few guys using the mongoose 1/8th scale brushless esc with the larger 1oth scale 21.5 and 13.5 motors. With both 4 cell and lipo.
I know this may effect a warranty, but does this esc work well with those motors? Also i have heard both lipo and 4 cell can be used with it. I am mainly wondering if performance will be the same as say using a GTB. I like that the esc is 80 bucks, plus i race oval and it would be nice to be able to use a smaller esc. The GTB fits but its tight. thanks
burbs is offline
