New Novak Brusless System >
Old 09-05-2007, 03:15 AM
  #2581
JevUK's Avatar
Originally Posted by mazmo
Thats great ... common sense prevails
Hey ... what do you think of the LRP 13.5 ??
I have seen them run and they look strong.
You should thank Bob Novak for that. He got a lot of bad rap on forums when people wanted to run fiegao's and other none stadardised sensorless aircraft motors. But now the tables have turned. Funny thing is novak motors and speedo's are still the best anyway.
JevUK is offline
Old 09-05-2007, 05:57 AM
  #2582
Trader Rating: 16 (94%+)
Anyone else break fan blades on the GTB? I have broke fan blades off three of the standard clear 30x30mm fans. Got tired of this, too expensive. I put the Novak 25x25mm black fan on the GTB without any issues now.
According to Novak specs, the 25x25x10 fan is nearly equivalent in cfm specs to the 30x30x6 fan.
Problem I see with the stock 30mm clear fan is the blades are at or above the top level of the fan housing. Just a slight touch when the fan is spinning, and you can crack or break a blade. After that initial touch on the fan, it won't be long before more blades break off too.
I for one would like to see Novak change the design and replace my fan for free now that I have bought 2-additional clear fans (broken now) and 2-additional black 25mm fans. Didn't realize that the speed control would be the most delicate thing in my TC5.
kn7671 is offline
Old 09-05-2007, 06:36 AM
  #2583
STLNLST's Avatar
Trader Rating: 32 (100%+)
I also run a GTB in my TC5 and I'm curious to know how you keep hitting the fan blade on the speedo? Is it a fluke each time with a nut driver? Not saying you're worng or anything....just would like to know how it breaks each time.
STLNLST is offline
Old 09-05-2007, 06:50 AM
  #2584
JevUK's Avatar
I broke my fans too. I've got a low profile 25mm fan on one and much stronger 30mm on the other and they have been fine for ages. I agree that is one thing that novak could make a big improvement on. Wasn't a big issue for me though.
JevUK is offline
Old 09-05-2007, 07:56 AM
  #2585
Simple, touching it with your finger when setting the car down, or picking the car up. Also, if you get in a jam during a race and a marshal has to come and assist your car, they might wrap their finger around the inside and touch the fan.
kn7671 is offline
Old 09-05-2007, 08:06 AM
  #2586
PitNamedGordie's Avatar
I have a TC5 also and have no problem. How is your GTB mounted? Do you have a pic?
PitNamedGordie is offline
Old 09-05-2007, 08:47 AM
  #2587
Here are some pics.
Attached Thumbnails New Novak Brusless System-img_0608.jpg   New Novak Brusless System-img_0609.jpg   New Novak Brusless System-img_0610.jpg
kn7671 is offline
Old 09-05-2007, 11:24 AM
  #2588
Charlie's Avatar
The clear fans are not as durable as the black fans. We have everyone run the black fans.
The material the clear ones are made of doesn't seem to "take a hit" at all. I've had guys "report" that they "just break", but I'm guessing wiring hit them, or a stray wrench/finger or anything.
Charlie is offline
Old 09-05-2007, 11:43 AM
  #2589
bxpitbull's Avatar
Here are some pics.
That is GENIUS! Deans on the motor, so you can remove the ESC or motor withour putting a strain on your soldering joints. BRILLIANT!
bxpitbull is offline
Old 09-05-2007, 11:58 AM
  #2590
ROV
ROV's Avatar
OH YHER
Started runnin my novak GTB 13.5ss in stock,,gotta love the power...
FDR 4.7 after 5 min race its commin off at 140 to 148 F maybe a little hot ??
and gonna be worse in summer...
Can anybody tell if i can run a novak 5.5 with a hacker Roadster speedy,,
i think this speedy in sensorless it was a waste of money as i brought it before i was novakated.
CHEERS
ROV is offline
Old 09-06-2007, 01:51 PM
  #2591
ROV
ROV's Avatar
ROV is offline
Old 09-09-2007, 07:15 PM
  #2592
Chris08527's Avatar
Trader Rating: 16 (100%+)
hey guys after todays club race i am almost ready to make the brushless jump
most of the guys today were running the LRP sphere with the novak 10.5
any reason they just dont run the GTB is the lrp brushless speedo better for some reason???
Chris08527 is offline
Old 09-09-2007, 07:21 PM
  #2593
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by ROV
OH YHER
CHEERS
I belive you CAN run the novak motor with out the sensor, but it will cogg..
Some say it worked, others say it wont work at all.... I havent ever tried it, so I cant say for shure
No, those temps are perfect!
The LRP is better! The throttle curve and everything about them is alot smoother, and nicer feeling
BlackedOutREVO is offline
Old 09-09-2007, 08:02 PM
  #2594
magm20001's Avatar
the lrp has a slightly lower profile and footprint so fitment is slightly easier.
they both feel the same and can get the same lap times with either speedy.
magm20001 is offline
Old 09-10-2007, 11:12 AM
  #2595
ROV
ROV's Avatar
Cheers BlackedOutREVO
I have never experianced cogging with any gear,,,,,,so what am i looking for and is it bad for my gear.
ROV is offline
