Old 08-23-2007, 07:54 AM   #2551
mazmo's Avatar
Originally Posted by syndr0me View Post
Yea, I'm doing it too. LRP 13.5 with Novak GTB, no problems at all. At least the manufacturers are on the same page in that regard.
Thats great ... common sense prevails
Hey ... what do you think of the LRP 13.5 ??
I have seen them run and they look strong.
mazmo is offline   Reply With Quote
Old 08-23-2007, 08:24 AM   #2552
Xanavi_R34's Avatar
Originally Posted by Xanavi_R34 View Post
oh okay sir... Thanks...
One more question guys... Does all the led lights of the GTB ON all the time??? I mean all the 4 leds??? Cause mine are all on all the time while in nuetral... I set it up right though like what the manual says... but it doesn't say anything in the manual about all the leds will be on when in neutral position...
Anyone guys??? please help... I am getting confused... I know that it should only have the green light on when in neutral... Right???
TAMIYA TRF416
[Tamiya] [Hot Bodies]
[Futaba] [SpeedPassion] [LRP] [YeahRacing] [3Racing] [Imax]
Xanavi_R34 is offline   Reply With Quote
Old 08-23-2007, 08:48 AM   #2553
mazmo's Avatar
When all leds flash, I think it means you are in "throttle profile selection mode". If so they should be flashing ..... the number of flashes will tell you which brushless profile is currently selected.
'Quick press" (and release) the selection button to move to the next profile.
Keep doing this until you reach the profile number you want, then just leave it .... after 3 seconds the esc will exit programming mode and return to neutral.
Neutral shows a red light .. or red and green together if no transmitter signal is present ( radio is turned off).
Hopefully we have diagnosed the problem correctly, and that it will now be OK
Good night.
Old 08-23-2007, 08:51 AM   #2554
The Evicerator
Xanavi,
At neutral you should see a red, blue, and amber LED on all at once.
Red denotes that throttle is at neutral.
Blue and amber at the same time denotes that drag brake is active.
Solid green should only come on at full throttle.
Blinking green occurs at full brake.
At partial brake or throttle you should see the red LED go off.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-23-2007, 10:31 AM   #2555
Xanavi_R34's Avatar
Originally Posted by Steve Weiss View Post
Xanavi,
This is what I want to know about... Thanks sir... I thought I set it up the wrong way... So GTB Brushless esc is way different from GTX... Because in GTX, only red light will appear when in neutral but in GTB, all except the green led will light... BTW, I am very sorry for the confusing question, what I meant was the three led lights are ON at the same time... My bad...
BTW, forgot to ask, if this is the case, then I have nothing to worry about??? Is this right???
@mazmo,
Hey bro, thanks though for the reply...
TAMIYA TRF416
Old 08-23-2007, 10:33 AM   #2556
The Evicerator
Yes you are ok with the lights like this.
The reason the GTX doesn't have the blue and amber lights on at neutral is because it doesn't come with drag brake set to default.
If you used drag brake in your GTX you would see those lights on at neutral as well!
Steve Weiss
Old 08-23-2007, 11:06 AM   #2557
Xanavi_R34's Avatar
Yey, that's relieving... Hahaha...
Anyway, thanks bro...
TAMIYA TRF416
Old 08-23-2007, 11:49 AM   #2558
Xanavi_R34's Avatar
hey guys... Have a quick question here, what is the advisable or that can be used spur and pinion for the ta05ms? I need to get a 11 - 11.5 FDR... Help please...
Or what is the recommended FDR for a 3.5R BL motor??? Big track...
TAMIYA TRF416
Old 08-23-2007, 12:00 PM   #2559
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
anywhere between a 9.75 to a 10.3
Old 08-23-2007, 12:02 PM   #2560
Xanavi_R34's Avatar
but what the manual says that 10 - 10.5 FDR is for a 4.5R BL motor...
TAMIYA TRF416
Old 08-23-2007, 04:18 PM   #2561
Drewdc90's Avatar
I run between a 10.4 to a 11 to let the motor breath, I'd start at a 10.8 and go from there.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 08-23-2007, 04:39 PM   #2562
rampal's Avatar
Send a message via MSN to rampal
Im running 105/24 (9.84) on the TRF415MSXX... for rubber asphalt 5-cell. I can still go up two or three teeth and make runtime, but the car doesn't feel as "alive" as with 24 teeth....
al
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 08-23-2007, 07:27 PM   #2563
Xanavi_R34's Avatar
Guys, do I have to break in the motor (BL)??? Or just plug and go???
TAMIYA TRF416
Old 08-23-2007, 08:52 PM   #2564
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Plug and go beat it up
BlackedOutREVO is offline   Reply With Quote
Old 08-23-2007, 11:12 PM   #2565
Xanavi_R34's Avatar
Thank you sir...
TAMIYA TRF416
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
