New Novak Brusless System
#2537
any info is helpful. does all the novak 3.5 and 4.5s has weak full trigge3r brakes. i have a 3pk radio and a 3.5 and 4.5r system and the touring cars won't stop in their tracks if i want them to. the radio brakes is maxed out and i'm set at 10 on the cost drag brake. 100 foot straights come very fast, but have to use the last 1/4 to slow down enough to make a 90 degree turn on a 10 foot wide lane without smacking the pipe. got a 6900 mamba and man does it have brakes. WOW!
#2538
#2539
#2542
i am in the process of getting another brushless setup and cannot decide between a Novak GTB with 4.5R motor and LRP TC Spec and 4.5T motor? which is the better system and why?
does the Novak 4.5 motor in the NOV3001 system come with a sintered rotor??
#2543
Hi Guys,
I know some guys are running the LRP 13.5 with the GTB speedy.
Does anyone know whether the LRP wiring harness will plug straight into the GTB
... or is moodification required ??
#2544
Hey guys, quick questions here...
Can I setup the GTB brushless system while the wires for the brushless motors (the three colored wires) are connected? Or should I disconnect the wires first and the brushless sensor harness? There is no stated in the manual that I should not connect the wires from esc to BL motor but the sensor harness, yes...
#2547
disconnect the wires first Xanavi. and remove the sensor cable from the ESC.
#2548
One more question guys... Does all the led lights of the GTB ON all the time??? I mean all the 4 leds??? Cause mine are all on all the time while in nuetral... I set it up right though like what the manual says... but it doesn't say anything in the manual about all the leds will be on when in neutral position...
#2549
