Old 08-10-2007, 06:44 AM   #2491
Here's the recommendations from Novak. I would start with what they recommend with the sintered rotor.
http://www.teamnovak.com/tech_info/b...r_gearing.html
Unregistered is offline   Reply With Quote
Old 08-10-2007, 06:46 AM   #2492
SkeeryJones's Avatar
Originally Posted by ROV View Post
CHEERS SkeeryJones, but i can see your avoiding the question.thats ok
But i would like to know a ballpark figure for FDR for the 13.5 GTB setup for a tightish track....i know i must fine tune FDR from motor temp, but a starting piont is what im after........
CHEERS for any help
i'm not sure about FDR, i work with rollout, stock 27t i used 26mm (small) to 33mm (large track) rollout.
so for the 13.5 i would start with 30mm rollout.
SkeeryJones is offline   Reply With Quote
Old 08-10-2007, 06:01 PM   #2493
ford_racing's Avatar
Send a message via MSN to ford_racing
The motor really only has a small sweetspot.
I would go for a higher FDR than a lower one to start off with.
At a recent large event there were people running from 26-38mm rollout on the same track. The fastest guys were running about 28mm and the track was fairly open, Mod was running 18-22 with 4.5's
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 08-10-2007, 07:48 PM   #2494
Blisster's Avatar
WO now im confused,,,i just got word to be in the low 7 FDR range from someone at my track....(maybe someone is takin the micky)
my car Am cyclone 2.47375 belt & 48 pitch 78s, 29p but i don't know if that makes the differance........
Thanks for the advice,,i will try both,,and looks like some testing to do for me.
but race day sun and ive run out of time to test, so looks i got to wing it on race day,,,,,,,steppin from 540 to stock.
CHEERS for all advice guys........
Originally Posted by turtle View Post
Most people I have spoken to say between 4.5 and 5 is about where you need to be at. Obviously it depends on what sort of track you are on, but probably a good place to start
I'm geared at a 4.68 FDR with my 13.5 at the two tracks I run at (one huge, one fairly tight) down the back straight i've got just a little bit less motor than the fast guys, but more than alot of the other "middle of the pack guys".
WCERacing.com for R/C videos, news and more!
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Blisster is offline   Reply With Quote
Old 08-12-2007, 08:56 AM   #2495
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
Can someone from novak give me a little help on a starting roll out for S&N Trackside for 13.5 running on foam tires.... And is the 17.5 if run with 6 cells equal to running 6 cell stock motor ?
Just wondering cause i would like to have the same type of speed but use the 17.5 for practice and ease of not having to mess around with motors while practicing and then go to a race where brushless isnt allowed yet and not feel much of a change in speed and power.
If the 17.5 is very close to 27t stock motor,,, what would be a good rollout to start with at Trackside as well.
wallstreet is offline   Reply With Quote
Old 08-12-2007, 04:43 PM   #2496
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
43-45mm roll out is what I ran yesterday and also one of the foam cars was running a very similar rollout
HVFracingwilly is offline   Reply With Quote
Old 08-12-2007, 04:45 PM   #2497
wallstreet's Avatar
for the 13.5 or 17.5 ?
Damn i wasnt even close to that at the sizzler.... no wonder that motor had nothing on the straight
Old 08-12-2007, 04:48 PM   #2498
that is for the 13.5
Old 08-13-2007, 09:35 PM   #2499
wallstreet's Avatar
Bump for some info from the novak gods
Old 08-15-2007, 12:44 PM   #2500
ROV
ROV's Avatar
OOOO YERRR
Had my first run on the new 13.5 SS on the weekend, yes i like,,
I ran a FDR 5.6, cause that was the highest gears i could muster up at short notice, and our track is quite tight and short...at race end had a temp of about 110-115f
looking to get about 4.8 FDR for next weekend and see how that goes,,,but she some punch out of the corners over the standard brushed, but i can see someone who knows what they doing with a brushed is still compative...
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 08-15-2007, 05:09 PM   #2501
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Hey guys im getting REALLY PO'ED about now
I bought a novak 13.5 and the novak black heaat sink sleeve and it wont go on, so I got a heat gun and i got it like 1-2 mm from all on, and I tried to but the end bell on and screw press it and the screws get on and the screws go on and about 3-4mm it just stops and spins like its stripped....
So all togather this stinks, and im getting mad and frustrated, and worried that it may be broken or something
I can even get the heat sink slave off to put it back to normal
This is the 13.5 with a sintered rotor and the finned can, so the new model
PLEASE help anyone?
BlackedOutREVO is offline   Reply With Quote
Old 08-15-2007, 05:47 PM   #2502
Charlie's Avatar
[email protected]
[email protected]
[email protected]
or
[email protected]
Charlie is offline   Reply With Quote
Old 08-15-2007, 05:51 PM   #2503
Hmmm I did cs, but I will email all the other to see who is the fastest...
Thanks Charlie
Old 08-15-2007, 06:54 PM   #2504
Blisster's Avatar
yikes, that doesn't sound good BOR. good luck with that.
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Old 08-15-2007, 09:18 PM   #2505
Motor is done guys
Its beyond F-ed up...... I will send it in, but I will be buying another one.. I dont think Novak will cover this under warrenty, but if I do get another one, I will take the new one back and keep the new one that im buying tomarow.. I would wait, but I waited 3 and a half months to go BL and want it for friday (17th) so I can B-day race it....
Id say whats all wrong, But theres so much it isnt funny
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
