Old 08-01-2007, 02:19 PM   #2476
question for Charlie or other novak tech(s).....several of the guys at our local track in Maryland are planning to switch over to 10.5 brushless systems for 1/12th scale club racing comparable in speed to the brushed 19 turns that we ran last season. I see that Novak now offers two brushless speedos without heat sink made special for 4 cell racing. My question....what's the functional difference between the normal 4 cell speedo and the one for spectrum equipped cars? I don't have spektrum yet, but plan to get it at some point after making the switch first to brushless (can't afford everything at once). Need some help to figure out which system to order and why.
vafactor is offline   Reply With Quote
Old 08-01-2007, 02:33 PM   #2477
The Evicerator
Vafactor,
Both the Spread Spectrum and the Standard versions of the 4 Cell GTB have all the same programability and functionality.
The Spread Spectrum units generally tend to run a little cooler and sometimes people feel that the throttle response is a little smoother as well.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-01-2007, 02:40 PM   #2478
Blisster's Avatar
so I realize that a major selling pont of BL sytems is the "low-maintnence" aspect, but I'm wondering what sort of day-to-day or "after-race" maintnenece is recommended? Cleaning the motor with motor-spray?, jsut blowing it out/off with compressed air? anything else? What do you BL guys do?
and whats the diffeerence between the standard GTB and the 4-cell GTB model? Can I run my standard GTB/13.5 combo in my 1/12 scale with a 4-cell pack?
WCERacing.com for R/C videos, news and more!
CRC T-Fource
AE TC5
CEN Matrix C-1 FRE
Blisster is offline   Reply With Quote
Old 08-05-2007, 06:21 AM   #2479
mazmo's Avatar
Default Punchy Profile ??
Hey guys,
I have GTB with 13.5 SS (sintered). It's got lots of speed however, some of the other 13.5 runners have more torque / punch - our rollout is the same so it seems overgearing is ruled outed.
I am using the default profile (number 1), is there a 'punchier' setting that I can use ?
Cheers
mazmo is offline   Reply With Quote
Old 08-05-2007, 10:49 AM   #2480
There really isn't much maintenance for the BL motors. Just check them every few raceweekends for stuff in the motor (normally just foam or dust) and oil the bearings. Compressed air may be useful but I wouldn't use motor spray on the motor.
If you drop a rotor in the dirt, it can pick up all kinds of little magnetic dusties. The best way I've found to clean this off is the cleaning putty that the gas guys use.
Yes, you can use the regular GTB in 12th. It's a tight fit under the body but it works fine on 4 cells.
Unregistered is offline   Reply With Quote
Old 08-05-2007, 06:25 PM   #2481
Can anyone explain to a newer guy like me how the brushless system works, and if it's allowed in stock racing? Is it a just a track to track type of thing where the owners decide what to run, or is it approved by ROAR? Thanks for any help.
The Italion is offline   Reply With Quote
Old 08-10-2007, 12:13 AM   #2482
ROV
ROV's Avatar
So i just got new novak GTB 13.5 ss and with all my spur's and pinon can only get a FDR of 6.5-7.5.am cyclone 78 spur 29 pinon 48 pitch,,car 2.4375
Question is this too much 4 the motor as i have not run it yet.....and is the ss sinterd rotor??
any suggestions welcome
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 08-10-2007, 12:18 AM   #2483
SkeeryJones's Avatar
you can tell the 13.5 is sintered if it got the orange timing ring. also there should be cogging with the sintered rotor
SkeeryJones is offline   Reply With Quote
Old 08-10-2007, 12:21 AM   #2484
ROV
ROV's Avatar
Yep she's got the red ring around,thanks
PS what should be the FDR for the 13.5,,,distructions only talk about 10.5 down to 4.5....
CHEERS
Old 08-10-2007, 12:31 AM   #2485
novak recomends pinion 2-3teeth higher than a 27T stock motor. which probably means you can do 3-6 teeth higher.
Old 08-10-2007, 05:22 AM   #2486
ROV
ROV's Avatar
CHEERS SkeeryJones, but i can see your avoiding the question.thats ok
But i would like to know a ballpark figure for FDR for the 13.5 GTB setup for a tightish track....i know i must fine tune FDR from motor temp, but a starting piont is what im after........
CHEERS for any help
Old 08-10-2007, 05:27 AM   #2487
HVFracingwilly's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to HVFracingwilly
anywhere from a 4.3 to a 4.7 depending on how well your car is working
HVFracingwilly is offline   Reply With Quote
Old 08-10-2007, 06:37 AM   #2488
For the higher wind motors (13.5 and 10.5) it's pretty hard to give an exact "startingpoint" because these things have a huge window where they work. From what I've seen you can go 3 teeth up or down and not have a huge change in performance.
Locally, we're gearing for laptimes only. We don't run the motors at a specific temp or anything like that. It's all aout the laptimes and experimenting. For a first time startingpoint, just use the recommendations from Novak (instructions or website).
Old 08-10-2007, 06:38 AM   #2489
ROV
ROV's Avatar
WO now im confused,,,i just got word to be in the low 7 FDR range from someone at my track....(maybe someone is takin the micky)
my car Am cyclone 2.47375 belt & 48 pitch 78s, 29p but i don't know if that makes the differance........
Thanks for the advice,,i will try both,,and looks like some testing to do for me.
but race day sun and ive run out of time to test, so looks i got to wing it on race day,,,,,,,steppin from 540 to stock.
CHEERS for all advice guys........
Old 08-10-2007, 06:41 AM   #2490
turtle's Avatar
Most people I have spoken to say between 4.5 and 5 is about where you need to be at. Obviously it depends on what sort of track you are on, but probably a good place to start
turtle is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
