New Novak Brusless System >
Old 07-03-2007, 02:55 AM
  #2356
Which is the fastest MOTOR???
1. Novak Velociti 3.5
2. LRP Vector X-11 3.5
3. Teamorion Vortex 3.5
4. Mamba Max 7700
I'll drive on 1/8th on-road circuit.
Anyone try these? Thanks.
xtaiji is offline
Old 07-03-2007, 03:40 AM
  #2357
rampal's Avatar
4. Mamba Max 7700
the Novak 3.5 is faster than a 1/10 nitro car on the field, however on a long straight (70m in my case), when they reach "warp speed" (2nd gear full throttle) at the end they can catch you... but you will indeed be faster than them on corner speed and acceleration...
I haven't tried the others yet...
rampal is offline
Old 07-03-2007, 04:58 AM
  #2358
Wow, rampal, Thanks.
xtaiji is offline
Old 07-08-2007, 05:12 PM
  #2359
Can any one tell me if Tower Hobbies are selling the latest
GTB/SS10.5 Pro Brushless System (#3010)
the one with the Lipo cut-off. Ive tried Emailing them but waiting for a reply and want to order ASAP.
Steve B is offline
Old 07-08-2007, 05:14 PM
  #2360
STLNLST's Avatar
Trader Rating: 29 (100%+)
does it state that it's a spread spektrum??? If so then that's the latest and greatest out of the Novak camp.
STLNLST is offline
Old 07-08-2007, 06:29 PM
  #2361
Hebiki's Avatar
Trader Rating: 26 (100%+)
check with Steve at speedtechrc. if you call the shop, he'll answer the phone.
www.speedtechrc.com
Hebiki is offline
Old 07-09-2007, 06:41 AM
  #2362
It has to say spread spektrum on it. Part #1711 for the normal one and #1715 for 4 cell. they just had the 4 cell one on rvtvlive.com It came recomennded.
outrunner25 is offline
Old 07-09-2007, 07:06 AM
  #2363
mazmo's Avatar
Default Novak GTB Profiles
Guys,
A question on profile adjustment.
Increasing the minimum drive is supposed to make the motor more 'punchy' at first pull of the throttle ..... but will it also increase the top end speed ?
If not, is there a profile adjustment that will increase top end speed ?
Would appreciate your comments.
Cheers
mazmo is offline
Old 07-09-2007, 07:27 AM
  #2364
STLNLST's Avatar
Originally Posted by mazmo View Post
Guys,
Cheers
Steve or Charlie may chime in on this and correct me if I'm wrong but for more top end speed you can gear up a bit and to try to get that punch back at first throtle pull you can increase the min drive. What motor are you looking to get more top end out of?
STLNLST is offline
Old 07-09-2007, 07:48 AM
  #2365
sportpak's Avatar
Easy question, no time to dig.
I can shorten the leads on the cap can't I? I'm looking for a tight 12th scale install. GTB is darn big, plus the cap.
sportpak is offline
Old 07-09-2007, 09:59 AM
  #2366
VooDooPH's Avatar
Trader Rating: 18 (100%+)
is there supposed to be fore-aft play in the rotor? i replaced my rotor with a sintered one but the old rotor didn't seem to have any shims with it. now, after placing the sintered rotor, i can feel quite a bit of play when i pull on it.
found a round paper washer that looks similar to the paper rings at the top part but i can't seem to find a place for it in the motor.
VooDooPH is offline
Old 07-09-2007, 02:32 PM
  #2367
mazmo's Avatar
I'm using new Novak 13.5 with sintered rotor.
mazmo is offline
Old 07-09-2007, 02:41 PM
  #2368
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
try gearing the car around 4.9fdr (touring car)the stock profile should be just fine
Marcos.J is offline
Old 07-09-2007, 02:46 PM
  #2369
mazmo's Avatar
thanks
mazmo is offline
Old 07-09-2007, 02:51 PM
  #2370
Super Moderator
Marcos.J's Avatar
thanks
if i recall i had my cyclone geared around a 4.4fdr
Marcos.J is offline
