New Novak Brusless System
#2341
Ran my GTB 13.5 brushless combo for the first time tonight in my Mi3, Couldn't figure out the gearing. Its on a small tight indoor track, rubber tire touring car and usually run a gear ratio of 8.01 with a brushed motor. The 13.5 i have is the ribbed version with the orange timing ring.
Anyone help please?
Paul
Anyone help please?
Paul
#2342
It's safe to start around 2-3 teeth taller then your Current Brushed Stock motor. But likely you'll keep going from there. Watch the motor temps at the end of your run, you want around 160-170F.
#2343
If i overheat my 4.5r or gtb because i've over geared, what exactly happens? Does the gtb shut off completely or can i still use my steering servo?
#2344
I am trying to understand the gearing on my 13.5 BL as well. Whenever I ask around hear I get the same answer..."most are running around a 4.5"....but your response as well as the literature that cam with say start around 2-3 teeth larger than current set up. I guess my question is ....is the gearing really different or the motor is just that much stronger that it can pull that much gear? I am not a newb but I am not a seasoned vet either....
#2345
Just gear it up until you're competitive and keep an eye on the temp. You aren't going too high until you... a) lose the "punch" and... b) it gets too hot. (over 170).
#2346
#2347
Welcome to the world of brushless Paul!! Does Ian let you run that at Maritime - or was that at Sidcup with Simon?
#2348
Anyway, i'll hopefully be back up there again soon, i'm hooked on this brushless malarky - I've just bought a 4.5 to try at Barham!
Paul
#2349
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Mutley
don't you get to far ahead of me
let me get my spek GTB/13.5 first
then i'll get the 6.5 9can't handle 5 or less (too old & shaky
#2350
I just switched to the 13.5 sintered motor. Hoolleee crap! That thing will pull whatever gear you put on it. I'm down to 5.4 FD in my Type R, motor is still coming off around 100F. It's weird buying spurs now to change ratios. When you can't fit that 44t pinion, something has to give. I'm putting one in my 12L now. Should be a treat.
#2351
Super Moderator
#2353
GTB
Well I have just installed my GTB,8.5pro and done the setup procedure it all seems to work except the blue and ,amber light is staying on all the time as well as the red and green as you accelarate and brake .
Could someone please explain what i might be doing wrong And if so a remidy
Thanks in advance Mark
#2354
No substitute for experience
Just gotta get hold of a 10.5 for 19 t racing now
#2355
That means that the drag brake is enabled.
