Old 06-21-2007, 07:03 PM   #2326
James's Avatar
[QUOTE=K_King;3419141]Thanks Steve! I didnt realize that the blue and red at the same time meant brushed. Im good to go now.
thats a nice clean install too! nice job with the fan blowing across the GTB!
http://www.teamadrenaline.net/ - RC Race Results, News, and gossip in Australia!
http://www.nolimitarcade.com/ - the best web flash games
http://www.fireflyhelicopter.com/ - R/C heli vids 'n more
James is offline   Reply With Quote
Old 06-22-2007, 06:05 AM   #2327
trf junkie's Avatar
Hi guys,
This brushless motor/esc is all new to me. If someone can point me in the right direction as to what I need to change / get to run brushless.
I currently race 27 turn stock , car trf mre, volac esc and spectrum pro receiver/ futaba control.
please if someone has a mo, what is the proper brand to go for and what motor is equivalent to 27 turn if it exist.
What do I need to change in my setup besides the esc?.
thanks in advance, I appreciate it
trf junkie is offline   Reply With Quote
Old 06-22-2007, 07:03 AM   #2328
James's Avatar
Originally Posted by trf junkie View Post
Hi guys,
you could go a novak GTB esc, with a 13.5 motor. check out www.teamnovak.com for more info on both!
Using the Spektrum DSM, you could go for the DSM optimized GTB esc... (info also on Novak web site)
Cheers
Old 06-22-2007, 07:14 AM   #2329
mutley001's Avatar
I've just done this, got to use a brushed setup for club racing and going to use the brushless for fun.
It's a bit of a tight squeeze in my Mi3 especiall that rather hugh power cap! which I've just tie wrapped to the motor wires for now
Works great and isn't too bad to switch between brushed and brushless.
Looking forward to getting something hotter in there 3.5 maybe????
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 06-22-2007, 07:24 AM   #2330
trf junkie's Avatar
Thanks guys, narrows things down a bit.
Are these esc compatible with other motor manufacturers or not.
How does the 13.5 brushless compare to the std 27 turn brushed motor?
How often does it need maintenance or not?
Is it expensive to maintain?.
Sorry about all the questions, gotta do the research...spend monies once, not like before when I started racing, we've all been there..
Old 06-22-2007, 07:50 AM   #2331
If you're having problems with the heat sink and don't want to return it to Novak for a new one try this.
Use some Easy Off oven cleaner on a rag and clean off the anodising on the inside of the heatsink. Don't get any on the outside because it will remove the anodising. It should remove enough material to allow the heatsink to slide on.
Unregistered is offline   Reply With Quote
Old 06-24-2007, 11:17 PM   #2332
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.shopatron.com/index/135.0.15995.22397.0.0.0
Does the availability of sensor harnesses (in various lengths, praise be thy name!) hint at a future update for the Novak motors?
syndr0me is offline   Reply With Quote
Old 06-24-2007, 11:52 PM   #2333
James's Avatar
1. yes
2. the 13.5 was designed to be simular to a 27t stock motor
3. practically zero maintenance
4. no
Old 06-24-2007, 11:52 PM   #2334
James's Avatar
I dont think so:
"Novak's double-ended brushless motor sensor harness is for use with brushless motors that use a double-ended, replaceable sensor harness. Length is 4 inches (102mm). A longer 9 inch (229 mm) harness is also available (part #5355)."
"Note that the Novak brushless motors do not use this harness. However, this harness can be used with Novak Brushless ESCs when using a non-Novak sensored brushless motor."
Old 06-25-2007, 05:15 AM   #2335
The 13.5 is the stock brushless motor. I've had my motor for over a year. I've only opened up twice- Once to change the rotor and the second time a few weeks ago to clean it(It took more time to take it apart than to clean it).Mine was really clean inside.Gear it in the 4.50 overall gear ratio for outdoors.You'll hear of some people going lower but it will get hotter and the overall speed is not gained.I've raced against the same chassis and a 3.90 gear ratio and it was not faster. I've raced against a 5.16 overall while I was 4.42 and it was the same speed. Now I will stay around 4.50 for right for testing( got a new car).Oh make sure you get the SS version with the sintered rotor!If not you'll get one later after you thermo.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 06-25-2007, 07:19 PM   #2336
J@UNE's Avatar
Can I use the GTB Spread Spectrum with a crystal type receiver? I'll prbably go to spektrum later...
Thx
J@UNE is offline   Reply With Quote
Old 06-25-2007, 07:23 PM   #2337
tfrahm's Avatar
Send a message via AIM to tfrahm
Thx
Everything I've seen says NO! The GTB Spread Spectrum speed control has been reprogrammed to use much higher drive frequencies (cooler motor, cooler ESC) -- the ONLY way they can do that is for Spektrum type radios. Crystal radios are subject to interference from these higher drive frequencies and will glitch... You will have to use the standard GTB with a crystal receiver...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 06-25-2007, 07:31 PM   #2338
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
wow i didnt know there were still people out there using crystals
Old 06-25-2007, 08:11 PM   #2339
tallyrc's Avatar
hey, i love my crystal radio, people don't even ask me what channel anymore!
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 06-25-2007, 08:52 PM   #2340
STLNLST's Avatar
Trader Rating: 21 (100%+)
My spread spektrum feels nice. I still have one crystal receiver that I'm holding on to just incase of an emergency I might be trading it in for a back up spektrum though.
STLNLST is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
