New Novak Brusless System >
Old 06-06-2007, 09:52 AM
  #2281
SammyZ's Avatar
Trader Rating: 138 (100%+)
Originally Posted by SlamMan View Post
I'm sending in my 13.5 today for repair. One of the sensor wires got pinched off. The wires are fairly exposed and have no protection from being pinched against the end of the motor in a crash. The only protection is a thin rubber grommet. So thin that it was gone pretty quick.
I think it could have been designed with a bit more protection. Better yet a user replaceable wire harness/plug system like the Orion motors. Novak seems to be good about improving their products so I hope this is something they look at. The same exact thing has happened to a couple other guys at the local track.
It's going to cost 46 bucks to get it replaced; that's half the price of a new motor. ARrrrrgggg.
Has anyone done anything to protect or cushion this area?
lol
SammyZ is offline
Old 06-06-2007, 12:32 PM
  #2282
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Talking
Does the Novak GTB work well with the LRP Vortex 4.5r motors?
yyhayyim is offline
Old 06-10-2007, 03:48 AM
  #2283
NOOB-SMOKE's Avatar
Default caps
Does anyone know How many microfarads and voltage the standard GTB cap is
thanks.
NOOB-SMOKE is offline
Old 06-10-2007, 04:40 AM
  #2284
V12
V12's Avatar
I think you mix up something here. LRP is Vector X11 and Orion is Vortex.
V12 is offline
Old 06-10-2007, 05:48 AM
  #2285
VooDooPH's Avatar
Trader Rating: 18 (100%+)
can glitching be caused by a motor about to blow?
VooDooPH is offline
Old 06-10-2007, 06:57 AM
  #2286
Alltapdout's Avatar
thanks.
5600uf 10v.. I would recommend getting stock replacement!
Alltapdout is offline
Old 06-10-2007, 08:02 PM
  #2287
NOOB-SMOKE's Avatar
Default cap
Thanks mate
I thought it was 5600uf.
why do you say stick with the 5600 ? what whould changing to a 4700 do.
cheers!
Old 06-11-2007, 10:38 PM
  #2288
I rechecked mine abd it is 4700uf. Not sure why it is different. Will go look at what jaycar has on way ho and mayb get a bigger one.
Dragonfire is offline
Old 06-12-2007, 01:47 AM
  #2289
rampal's Avatar
Thanks mate
cheers!
this multiquote stuff is awesome!!!
yeah, read this:
Originally Posted by NovakTwo View Post
Here is an article from TeamNovak's website explaining capacitors (includes a photo):
Power Capacitors and Capacitor Modules
Reading the info probably won't make you any happier about running the module, but you may see why Novak stands by their "awful design."
the novak module has some other stuff in the board, at least keep the board and solder the cap to the board, not straight to the ESC...
al
rampal is offline
Old 06-12-2007, 05:51 AM
  #2290
mazmo's Avatar
Default Maintenance
recently converted from 27T brushed to SS 13.5 Pro system ... awsome
Read al the Novak manuals, no mention of maintenance.
Any maintenance required on these motors ?
mazmo is offline
Old 06-12-2007, 06:27 AM
  #2291
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
just a drop of oil on the bearings after a dozen runs or so
Marcos.J is offline
Old 06-12-2007, 06:52 AM
  #2292
mazmo's Avatar
FANTASTIC
mazmo is offline
Old 06-12-2007, 11:29 AM
  #2293
Trader Rating: 17 (100%+)
Keep buying big pinion.....you will need that.
Solara is offline
Old 06-15-2007, 09:00 PM
  #2294
Xtant3150c's Avatar
I have a GTB 6.5R that has the new machined can, but the GTB esc does not seem to have the Built in Lipo Cutoff?
The box I have did not have the stickers stating lipo cutoff, but I was under the impression that all GTB's that have the New Machined Can meant that it was an updated version that also has the Sintered Rotor and Lipo Cutoff?
Xtant3150c is offline
Old 06-15-2007, 09:16 PM
  #2295
Default GTB Capacitor info
All,
The GTB has a big cap, 5600uf on most, and a circuit board containing seveal surface mount ceramic caps. The big electrolitic cap is to supply basically a current boost to the controller while the ceramics are used to filter the dc of mainly RF. Any electrolitic cap of the same voltage and capacitance value will work. Their caps are nothing special.
radarwill is offline
