Old 05-09-2007, 12:45 PM   #2221
gashuffer's Avatar
Trader Rating: 48 (100%+)
I would like to give props to Novak. I went to the factory this morning and they fixed my problem in five minutes I am just lucky to be so close to all the major factories in SoCal. Thank You Novak keep up the great work.
T-Sal
gashuffer is offline   Reply With Quote
Old 05-09-2007, 01:28 PM   #2222
TFR
TFR's Avatar
Sorry, newbie question. The new 10.5 motor is equivalent to a 19T brush motor?
Nevermind, found the answer.
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 05-13-2007, 11:02 PM   #2223
GymBeam's Avatar
13.5 ~= 27 T
10.5 ~= 19T
GymBeam is offline   Reply With Quote
Old 05-13-2007, 11:05 PM   #2224
GymBeam's Avatar
just upgraded my rotor in my 7.5 to sintered rotor.
was wondering if i did it right before i run it.
when i turn the pinion now, the motor "cogs" just like a modified brushed motor.
just checking because with the non-sintered rotor it used to spin freely like a 540 silver can motor.
thanks
Old 05-13-2007, 11:12 PM   #2225
Drewdc90's Avatar
Yes it 'cogs' because the magnet is stronger.
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 05-14-2007, 06:18 AM   #2226
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
thanks
its a stronger magnet and you will have more drag brake than the bonded rotor
Old 05-18-2007, 12:03 AM   #2227
SWTour's Avatar
Charlie,
Tried to send you an email...but the @teamnovak.com mail got bounce back...
[email protected]
SWTour is offline   Reply With Quote
Old 05-21-2007, 09:46 AM   #2228
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
anybody have tips on how to do the wiring so i can easily switch between a brushless and brushed motor? i think i pretty much know what to do with the 3 wires going to the negative tab of the brushed motor. its the red wire connecting to the battery that i'm having problems with...
[TRF418][TB-04Pro][FF-03Pro][M-05v2][TRF102][F-104 WGP][TT-01R TypeE]
[Cross CF-01'08][Yokomo R12][Team C TC02Evo][Team C T8E v3]
VooDooPH is offline   Reply With Quote
Old 05-21-2007, 10:29 AM   #2229
rcgen's Avatar
Create a jumper wire from the battery to the motor or splice the red wire going to the battery and the motor
rcgen is offline   Reply With Quote
Old 05-21-2007, 06:12 PM   #2230
VooDooPH's Avatar
is it OK to use a dean's connector? I'd like to be able to switch from brushed to brushless easilly.
Old 05-21-2007, 06:52 PM   #2231
Rainey's Avatar
Yes, you can use Dean's connectors. I got some help with this sort of thing earlier but i can't seem to find the links that shows some of these ideas. I put Dean's in the motor wires to make motor changes quickly and it works great. One of the guys who showed me an example also had a setup to run the brushed motors also. i will keep looking.
Mark
*edit** --- found it ! http://www.rctech.net/forum/showthread.php?t=86490
www.rcracingxtreme.com
racers running races for racers !
Rainey is offline   Reply With Quote
Old 05-21-2007, 08:44 PM   #2232
edseb's Avatar
Little help. Ben gearing a 4300 BL motor at 5.3 with 6 cell, what should I be gearing that motor with 5 cell?
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-21-2007, 09:02 PM   #2233
Super Moderator
Marcos.J's Avatar
ill start around a 4.2
Old 05-21-2007, 09:44 PM   #2234
dash yonkuro's Avatar
is it posible for me to use a 19T peak dinasty product with a GTB? what should i do to get the best result? FYI im using a teamlosi jrx-s. thx bro!!!
TOO FAST TO BE THE LAST...
dash yonkuro is offline   Reply With Quote
Old 05-21-2007, 11:13 PM   #2235
Super Moderator
Marcos.J's Avatar
you can run any brushed motor with the GTB as long as you switch the profile for brushed motor
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
