Old 05-07-2007, 09:41 AM   #2191
Company Representative
Originally Posted by DRAG_ON
can anyone please help some GTB feature for:
1) What is Dead Band???? there is a selection of dead band form 2% until 6%
what is Dead band for???
2) What is Minimum Drive??? what is the effect by increasing the percentage
ratio???
3) the last question what is Drive Frequency and what is the effect by
increasing % of kHz ?
Here are some definitions of general speed control terminology:
All About Speed Controls
NovakTwo is offline   Reply With Quote
Old 05-07-2007, 11:11 AM   #2192
Originally Posted by g12314
Had my GTB go up in flames yesterday in my ZX5. Car was running fine, sitting on the start line waiting for the tone. Looked like a BIG smoke bomb.
I know the GTB is toast, but is there a way to check the motor for damage? Either way, I'll be sending the GTB back into Novak for the upgraded GTB when the cost is determined.
Jimmy
Hmm...mine did the same thing on saturday. I'm just curious...were you using the new spread spektrum version or regular gtb?
DOTMAN is offline   Reply With Quote
Old 05-07-2007, 12:08 PM   #2193
gashuffer's Avatar
Trader Rating: 48 (100%+)
Question? I have a 2- cell li-po cut off on my GTX and I was wondering can I run regular cells through the cut off aswell or do I have to remove it? Thank You in advance.
T-Sal
gashuffer is offline   Reply With Quote
Old 05-07-2007, 12:38 PM   #2194
The Evicerator
Well technically you can run the standard NiMH cells through your 2 cell smart stop, but being as that the resting voltage of the NiMH cells generally falls off faster than that of a Li-Po packs you might run into stutters and cut offs that the smart stop is mis-interpretting as a low voltage li-po
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 05-07-2007, 12:48 PM   #2195
g12314's Avatar
Send a message via AIM to g12314 Send a message via Yahoo to g12314
I was using the regular 1st generation GTB (no lipo cutoff).
Jimmy
"PREPARE TO QUALIFY"
g12314 is offline   Reply With Quote
Old 05-07-2007, 01:07 PM   #2196
Rainey's Avatar
We had one let the smoke out this past Sat also. Looked like someone set off a smoke bomb. And it even melted itself to the chassis. Was running a 3.5 in mod class. And i know that it was not the spektrum version.
www.rcracingxtreme.com
racers running races for racers !
Rainey is offline   Reply With Quote
Old 05-07-2007, 02:25 PM   #2197
I'm hoping mine isn't melted to the chassis. I haven't try to pry it off yet. This was only the 6 time I had run it. I've never seen that much smoke. A lot of pretty colors too
Old 05-07-2007, 03:32 PM   #2198
g12314's Avatar
hehe, I still have some melted plastic on my fingers. I ripped everything apart while hot so my servo, RX, and PT would not become fused together with the melted GTB. The motor sensor plug was fused, but its gonna go back anyways.
I'll have to take some pics of the custom flame job on my RX .
Old 05-07-2007, 03:38 PM   #2199
hmm...i guess I should have taken a closer look at my surrounding electronics to see what other damage there may have been. It smelled so bad I put it in the garage and haven't really looked too closely at it since saturday.
Old 05-07-2007, 05:52 PM   #2200
Charlie's Avatar
Hey Guys,
Just use the service forms when you send these guys in. Makes the receiving and entering into the computer system a bit easier, and will help avoid any processing delays we might have.
www.teamnovak.com in the customer service section. Also, you'll find the "matrix" of exchanges we now offer just in case you want to get a different model/motor/version of something returned. It's very easy if you look it over.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 05-07-2007, 08:33 PM   #2201
Rainey's Avatar
OK- I need to correct my statement from earlier. We actually had 2 "let go" and both were the newer spektrum units. Not sure if it matters but both were in mod class ... one with a 3.5 and one with a 4.5.
Old 05-08-2007, 07:04 AM   #2202
RocketRacer's Avatar
will the Novak GTB work with Nosram and Speed Passion brushless sensored motors?
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 05-08-2007, 07:43 AM   #2203
rampal's Avatar
Send a message via MSN to rampal
I've used mine in the past with a Nosram 3 star... works ok....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 05-08-2007, 07:46 AM   #2204
DRAG_ON's Avatar
thanks novak two
DRAG_ON is offline   Reply With Quote
Old 05-08-2007, 09:57 AM   #2205
Trader Rating: 37 (100%+)
Once you initially set your GTB w/ the throttle trims using the one-touch programming...
If you switch from a 13.5R to a 4.5R motor or vice versa do you need to do any other reprogramming? I'm just wondering if the default Profile of 1 is fine for any of the brushless motors.
The only reason I ask is because the way I have my GTB mounted in a TA05R I cannot see the LEDs. So after initially doing my throttle settings I'm wondering if I need to view the LEDs at another time. Normally I do not do custom profile settings nor will I be switching from Brushless to Brushed...
Thanks in advance Novak
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
