New Novak Brusless System >
Old 05-02-2007, 02:58 PM
  #2176
Charlie's Avatar
Hey Guys,
For anyone that ordered a new motor recently, and received the older version, please simply Email [email protected] OR [email protected] and you will be able to get this problem resolved.
[email protected]
Charlie is offline
Old 05-02-2007, 05:29 PM
  #2177
GymBeam's Avatar
Hi, my problem has been resolved with tower.
As i live in australia, sending the motor back and forth turn-around time would of been weeks.
I sent a pic of the new motor and invoice to tower and
I requested the updated rotor (5908) and updated ribb can (5919) from tower hobbies. Though this wont be 100% the upgraded motor (as it will be missing the Ribb peice at the rear of the can), i will be satisfied with that.
GymBeam is offline
Old 05-04-2007, 09:44 AM
  #2178
swopemike's Avatar
Default Charlie, Email won't go thru....
Charlie,
FYI
Tried to send an email plead for help, it bounced. Twice.
Sent to [email protected]
Will try again later....
--- Update, no bounce yet from [email protected] ---
UPDATE... within an hour Charlie had my email and had fixed his filter... how's that for fast?
Thanks,
Mike
swopemike is offline
Old 05-04-2007, 01:40 PM
  #2179
asw7576's Avatar
Originally Posted by Charlie
Hey Guys,
[email protected]
I like this kind of attitude VIVA NOVAK !!!!
asw7576 is offline
Old 05-04-2007, 02:56 PM
  #2180
KE4PJO's Avatar
Like I've always said, "You can't go wrong with orange".
KE4PJO is offline
Old 05-04-2007, 03:28 PM
  #2181
Originally Posted by ttso
More size comparison:
NOVAK GTB: 29.5 x 37.8 mm
NOVAK GTX: 28.2 x 21.8 mm
NOVAK SS/SS+: 33.5 x 44.5 mm
KO VFS1: 28 x 25 mm
LRP Sphere: 33.3 x 37.7 mm
LRP QC2: 28.7 x 25.7 mm
One more to throw in there:
Tekin R1: 33.0 x 25.4 mm
InspGadgt is offline
Old 05-04-2007, 04:03 PM
  #2182
Company Representative
Another comparison:
Novak SS/SS+.........33.5 x 44.5 mm
Novak XBR Sport......30.0 x 39.0 mm
At least, they are going in the right direction.....
NovakTwo is offline
Old 05-06-2007, 12:32 PM
  #2183
g12314's Avatar
Had my GTB go up in flames yesterday in my ZX5. Car was running fine, sitting on the start line waiting for the tone. Looked like a BIG smoke bomb.
I know the GTB is toast, but is there a way to check the motor for damage? Either way, I'll be sending the GTB back into Novak for the upgraded GTB when the cost is determined.
Jimmy
g12314 is offline
Old 05-06-2007, 01:20 PM
  #2184
Jimmy
Here is the chart that lists prices for the GTB "different version" exchange program.
The new program also allows exchanging an existing Novak BL motor for any other series motor. (Vel, SS Pro, HV, 4300, etc.)
NovakTwo is offline
Old 05-07-2007, 01:16 AM
  #2185
DRAG_ON's Avatar
can anyone please help some GTB feature for:
1) What is Dead Band???? there is a selection of dead band form 2% until 6%
what is Dead band for???
2) What is Minimum Drive??? what is the effect by increasing the percentage
ratio???
3) the last question what is Drive Frequency and what is the effect by
increasing % of kHz ?
DRAG_ON is offline
Old 05-07-2007, 04:59 AM
  #2186
BrainTeased's Avatar
Jimmy
any ideas why it went up in smoke?
BrainTeased is offline
Old 05-07-2007, 06:09 AM
  #2187
Trader Rating: 42 (100%+)
Jimmy
Yikes.
Hopefully your ZX5 isn't melted as well.
Nexus is offline
Old 05-07-2007, 06:13 AM
  #2188
g12314's Avatar
I wish I knew. Ran a 5 minutes practice, and things were fine. Sitting on the line to start the 1st qualifier and she let go.
Something in the GTB / Motor definitely shorted. The Positive battery wire got hot enough to unsolder itself, so it was drawing a good amount of current. Based on the condition of the GTB, failure analysis will be "Electrical Overstress" (standard answer from our component engineering guys at work ).
I chalk it up to "stuff happens", and will send it back w\ my $90 to get the newer GTB w\ lipo cutoff and sintered 5.5 motor to replace it.
Jimmy
g12314 is offline
Old 05-07-2007, 06:17 AM
  #2189
GymBeam's Avatar
with the zx5, the body toughes the motor tab wires when installed. so you really need to make 110% sure your tabs are soldered good. otherwise with all the vibrations with the body and motor tabs, a short could occur pretty easily
GymBeam is offline
Old 05-07-2007, 08:15 AM
  #2190
g12314's Avatar
I had the motor rotated so the tabs were pointed twards the side of the body to avoid contact. Not sure how the body rubbing the tab would cause a short though since plastic is non-conductive.
g12314 is offline
