Old 05-01-2007, 08:29 PM   #2161
nashrcracer's Avatar
R/C Tech Charter Subscriber
well I hooked up my friends 5.5 and smoked it and it wasn't even in the car. never made it to the track. guess I'll be sending it back.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 05-01-2007, 09:33 PM   #2162
how come the "Novak Velociti Ribbed Bearing & Endbell Replacement " only comes with the front ribb can. why not also the rear peice near the solder tabs?
POOKGAI66 is offline   Reply With Quote
Old 05-01-2007, 09:51 PM   #2163
KE4PJO's Avatar
Your's runs in reverse and your "friends" let the smoke out? What's the common denominator here?
"If at first you don't succeed, sky diving is not for you" Unknown
"A bad day racing is still better than a good day at work" Me
KE4PJO is offline   Reply With Quote
Old 05-01-2007, 10:16 PM   #2164
bad speed control darryl... guess you still get to beat my brushed motor car this sunday.
Old 05-02-2007, 06:55 AM   #2165
If you're having speedo problems, it's a good idea to send back the motor also. I've never had a Novak brushless speedo let go but I have had motors let go. They will do strange things when they quit and it can take the speedo out. Had one thermal the speedo inside 30 sec.
One thing to check on the motors (especially the older ones) is that they aren't shorted out. I've had one short out because it got too much heat during soldering. Just look under the plastic end cap and double check. Normally it's a busted cap but I don't think that there are caps on the new motors (took them off of my 5.5 and it's fine).
Sometimes you can feel a short in the motor by just turning it over by hand. Feels like there's a big drag in one spot.
Unregistered is offline   Reply With Quote
Old 05-02-2007, 08:45 AM   #2166
GymBeam's Avatar
Hey novak, how about you guys give a lesson to the people at tower hobbies what "sintered and rib can motor" is.
i just bought a 7.5r from towerhobbies and in their product description it specifically says "Upgraded with sintered rotor and ribbed end bells"
GymBeam is offline   Reply With Quote
Old 05-02-2007, 08:57 AM   #2167
The Evicerator
Nash,
Sorry to hear you're having such trouble with the stuff I know you've been anxious to run it for a while now
We'll get you all sorted out I'm sure!
Pookgai66,
The reason it doesn't come with the rear ribbed endbell is because the motor would need some SERIOUS disassembly for you to be able to replace that part of the motor.
It involves alot of unsoldering/soldering which most people just don't have the knowledge or equipment to do.
Also, removing that endbell would mean that the sensor assembly would be removed and getting that back in and timed correctly are not exactly easy things for just anyone w/o the proper equipment to do either.
Gymbeam,
I will pass this along and hopefully we can get it sorted out!
Also to everyone,
Unregistered is right that we do like to see both the motor and the ESC whenever you are having trouble just so we can be sure to get you back up and running as quickly as possible without dilly dallying around w/ half the system at a time!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 05-02-2007, 09:01 AM   #2168
Regional Moderator
Darkseid's Avatar
Originally Posted by Darkseid
Has anybody ever asked Novak if its possible to send in one of their BL motors and get the sensor wire shortened?
I know they don't want us to do it, but I've never heard whether they would.
Steve Weiss...I had a question....see above.
TLR 22...Tamiya F104...
Old 05-02-2007, 09:53 AM   #2169
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
i have my 5.5 novak motor that I shorten sensor wires for over 1 1/2 years with no problems, it will void the warranty for sure, but it was time comsumming to solder each little wire and heat shrinck it
Old 05-02-2007, 10:38 AM   #2170
Is that the official term?
Tony Vega is offline   Reply With Quote
Old 05-02-2007, 11:54 AM   #2171
Regional Moderator
Darkseid's Avatar
Thanks for the info Marcos.
Old 05-02-2007, 12:02 PM   #2172
The Evicerator
Darkseid,
Unfortunately we cannot do custom wiring for people
Steve Weiss
Old 05-02-2007, 12:05 PM   #2173
Regional Moderator
Darkseid's Avatar
Darkseid,
No prob...
Just asking to see.
Just curious, why doesn't novak make the sensor wire plug into the motor so that it could be change to a short unit like with LRP motors? Raise the cost of the motor too much?
Old 05-02-2007, 12:11 PM   #2174
The Evicerator
I don't really think cost was the issue so much as that they felt like it would be easier for a plug to come undone durring a race and cause a failure.
2 sensor wire connectors is twice as many possibilities to get pulled out in a crash or something
Steve Weiss
Old 05-02-2007, 02:35 PM   #2175
vtl1180ny's Avatar
Originally Posted by GymBeam
Hey novak, how about you guys give a lesson to the idiots at tower hobbies what "sintered and rib can motor" is.
however all i got is the old version
and this is the reply i got from them, when i told them they sent me old stock.
I just recieved a 6.5r system and got the same old motor... I thought everything was updated???
I still lurk....
vtl1180ny is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
