New Novak Brusless System >
Old 04-17-2007, 11:15 AM
  #2116
I was reading that the new GTB has some lipo cutoff feature. I have not purchased a lipo pack yet, but plan on to. Is there anything I need for my regular GTB in order to run a lipo pack?
silence360 is offline
Old 04-17-2007, 11:28 AM
  #2117
No, just remember to pull your car off the track as soon as you see the car slow.
I do believe Novak makes a seperate kill switch too that won't allow you to run the pack past a certain voltage. You may want to look into that
DOTMAN is offline
Old 04-17-2007, 11:42 AM
  #2118
Company Representative
Protect Your Li-Po Battery Investment
NovakTwo is offline
Old 04-18-2007, 03:38 AM
  #2119
edwintklee's Avatar
Trader Rating: 23 (96%+)
Originally Posted by KoE
rob,
i believe he was referring to his 23T gearing
sorry to cause misunderstanding....5.3 its for my yokomo flt 23T with 6 cells,
i was wondering if using gtb 4.5R, what would be my ratio like?
koe, maybe you can help? at TT what the best ratio for gtb 4.5R
thanks a lot, sorry for my newbie question..
edwintklee is offline
Old 04-18-2007, 05:28 AM
  #2120
I)arkness's Avatar
hey im just wondering if novak is planing to bring out anything better straight after the gtb spektrum spread so i know wether to get that instead
I)arkness is offline
Old 04-18-2007, 05:48 AM
  #2121
Aluma's Avatar
hey guys, any of you run the GTB 6.5R on the T4 truck? Is there a special setting for the profile...like min drive,brake, etc... that I should set it at?
Aluma is offline
Old 04-18-2007, 08:34 AM
  #2122
The new Novak GTB Spread Spectrum optimized controllers are for use with spread spectrum radios only.
NovakTwo is offline
Old 04-18-2007, 08:49 PM
  #2123
I)arkness's Avatar
yeah i know that i have a spektrum radio system
Old 04-19-2007, 01:20 AM
  #2124
does any1 no if the velociti 3.5r would be suitable with the tt01 chassis and if it doesnt what kind of things should i do to make it suitable?
andy147 is offline
Old 04-19-2007, 01:34 AM
  #2125
will fit , but your car will be undrivable and your plastic shaft will bend as a elastic rubber band everytime you full throtle ( or even not full ..)
even if you replace the drive shaft by the alu one, i dont think you can make the car take turns right, TT01 are not very adjustable and you need to adjust when running as fast as the 3.5 can run
DrKucho is offline
Old 04-19-2007, 01:50 AM
  #2126
rampal's Avatar
Hey dude!!! I've just said that on the other thread!!!
so, have you already decided to send that burned GTB for replacement??
rampal is offline
Old 04-19-2007, 02:07 AM
  #2127
so theres no way of it being possible, for instance upgrading the spur and pinion gears? i currently have a 12 turn motor in there and it seems to go quite well but how much faster is the 3.5r?
andy147 is offline
Old 04-19-2007, 02:22 AM
  #2128
rampal's Avatar
which 12 turn??? anyway, a 12t brushed motor have a range between 8 and 6 , that you can accomplish with the TT01.... and the tt01 can only use spurs from tamiya, due its shaft... the so called "sweet spot" for the 3.5r is around 10.8, the tt01 cannot make less than 8.35 (the ratio range is 5.72 - 8.35)... nevertheless, if you try 5-cell, perhaps and 8.35 is a good call... with 6-cell I think you shouldn't... unless you want to fry something....
but that's my opinion, you're free to try....
al
rampal is offline
Old 04-19-2007, 04:16 AM
  #2129
thanks for the help its a Trinity D6 12 turn double competition motor
andy147 is offline
Old 04-19-2007, 04:34 AM
  #2130
LOL!!!! rampalus !!!!, i asked novak for a group global price for my SS, SS+, and GTB , but im afraid that is not possible , i had to try .... LOL
i will send them all to repair anyway i can even use one of the SS for crawling use with BL outrunner motor, i heard that someone is using those motors with really good result as they run so good at very low speed
DrKucho is offline
