Old 03-19-2007, 12:28 AM   #2056
RocketRacer's Avatar
so, with much nervousness, i ran my 3.5R in my 415MSXX this weekend...all i can say is whhhhhhhoooooooossssssshhhhhhhh!!! that thing is like a rocket!!!
it thunders down our main straight and the braking is crisp and accurate! power on the infield is phenomenal as the car darts from one turn to the next.
i am very very happy with my GTB and 3.5R Veocity motor.
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 03-19-2007, 01:48 AM   #2057
I am thinking of getting either a 3.5R or 4.5R for my 415MSX...which one would be a better choice?
chumanji is offline   Reply With Quote
Old 03-19-2007, 03:51 AM   #2058
ford_racing's Avatar
Send a message via MSN to ford_racing
Main thing would depend on the track size, if its a large track then the 3.5, if its a smaller track the 4.5 would be the better motor.
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 03-19-2007, 03:59 AM   #2059
in my limited experience with brushless, i would say get the 3.5, it is the best motor Novak has to offer. i am completely stoked with mine. besides, sooner or later you will want more....and the 3.5R gives it all!!!
RocketRacer
Old 03-19-2007, 07:44 AM   #2060
trjracing's Avatar
YES SIR, I'm with you on that one, when I had my 3.5R it was worth every dollar I spent on it. Trust me if you get it you will love it. The power on it is great and if you go Lipo you will get every last rev out of that motor. For a 6 cell or 2 cell lipo the 3.5R is fast. I was shocked how fast it was when I got mine... You will look like this when you first run it and if you go lipo, You would be happy like a pig in the mud. A friend of mine using the novak 4.5 was beating nitro cars and he just upgraded to a 3.5R and his PRO4 is a rocket, he's also running lipo.
trjracing is offline   Reply With Quote
Old 03-19-2007, 09:33 AM   #2061
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
dont count the 5.5 out either the 5.5 with the sintered rotor is pretty fast!!!
Old 03-19-2007, 05:31 PM   #2062
Charlie's Avatar
Some of our team guys don't even run the 3.5 for all conditions. They run the 4.5 as it's easier to drive, and a bit "tamer" if you will.
Alum, Start out about 2-3 teeth taller then the regular stock motors. Go for around 130-140F as a final Temp of the motor and you should be pretty pleased. Gearing is a tough call for sure, it's different for a lot of guys.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 03-19-2007, 09:23 PM   #2063
GymBeam's Avatar
i run corally tubes on my batt pack and direct solder for my motor wires.
anyone got a good setup, on how to change from a brushless wiring to a brush wiring with minimal fuss??
GymBeam is offline   Reply With Quote
Old 03-19-2007, 10:53 PM   #2064
Trader Rating: 17 (100%+)
When is the release date for the new Pro 10.5 (4300) brushless system with the new GTB going to be out?
429racer is offline   Reply With Quote
Old 03-20-2007, 07:11 AM   #2065
GymBeam's Avatar
anyone know if this is the correct bearing for the older style endbell (the 4300 and 5200)
http://cgi.ebay.com.au/1-8x3-8-x5-32...QQcmdZViewItem
INNER DIAMETER: 1/8"
OUTER DIAMETER: 3/8"
HEIGHT: 5/32"
Old 03-20-2007, 07:53 AM   #2066
retsilla's Avatar
is it possible to use the slim type cap instead of e novak cap?
anyone tried?
retsilla is offline   Reply With Quote
Old 03-20-2007, 09:34 AM   #2067
I tried the smaller diameter cap that the new LRP's use and it was ok but the speedo ran cooler with the novak cap.
Unregistered is offline   Reply With Quote
Old 03-20-2007, 10:17 AM   #2068
Send a message via AIM to barry Send a message via Skype™ to barry
Originally Posted by edwintklee
steve,
what is the lowest ratio for 3.5r motor on a hot day or let say 30 c.....?
Try ratio 10.9 to 11.3 for tropical weather like in Malaysia.(Gangsa track i used around 11.0 to 11.1 due to tight infield corner)
barry is offline   Reply With Quote
Old 03-22-2007, 06:01 PM   #2069
i just installed my lipo batt together with the Novak Smart Stop for 2 cell , it happnes that when radio is off the car goes full power
shoudnt be a problem when normal operation but in case of radio signal loss its very dangerous
my setup is novak gtb , 5.5 BL , futaba R133F receiver, maxamps lipo 8000 and Novak 2 cell Smart Stop
help apreciated
thanks in advance
DrKucho is offline   Reply With Quote
Old 03-22-2007, 06:22 PM   #2070
im so stupid , didnt read the manual ... there is a set up button ...
once i did the set up, all is right
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
