Old 03-14-2007, 01:05 PM   #2041
trjracing's Avatar
Originally Posted by RocketRacer
thanks TRJ. i still have to finalise a tidy up a bit. i am so amped 'cos i will be running the 3.5R in my 415 for the first time this weekend. it should be a blast!!!
You will have more than a blast with your car, the machine you have your brushless set up on is serious. Take Care...
trjracing is offline   Reply With Quote
Old 03-14-2007, 09:44 PM   #2042
edwintklee's Avatar
Trader Rating: 23 (96%+)
Steve Weiss
thank for the info....i try to work on it.....and try to get it below 175f after a five minute race....thanks a lot...
I am a Red Star, Blue Star, Fans......
edwintklee is offline   Reply With Quote
Old 03-15-2007, 10:01 AM   #2043
swopemike's Avatar
Talking Two questions
I have 2 questions.
- Can you use the black Novak fans in place of the clear 30mm ones on the GTB ESC (I'm running the 4.5) ? It looks like the clear ones are unreinforced nylon whereas the black ones are glass reinforced (much stronger). I keep getting rocks (offroad stadium truck) and fingers (touring car) into the fan and breaking off blades. Gone through 2 clear fans so far.
- I have the 4.5 bought with GTB system. Can I purchase the sintered rotor and have the equivalent of the 3.5 or does the 3.5 also have different stuff inside the motor housing? And how well does that rotor work in the 4.5? To run mod touring car and offroad stadium truck on big tracks.
OK, that's 3 questions...
Thanks !
swopemike is offline   Reply With Quote
Old 03-15-2007, 10:08 AM   #2044
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Originally Posted by swopemike
I have 2 questions.
Thanks !
Nexus racing has a direct replacement fan for the GTB and it flows alot more air than the stock novak fan
http://nexusracing.net/product_info....89c59f7847cbdd
Old 03-15-2007, 10:17 AM   #2045
Charlie's Avatar
You can use the black fans. They are more durrable for sure. They won't fit "square", but if you use to screws and put it on a slight angle, you get very good coverage.
Still use the spacers. And you will need longer screws. 4-40 screws work the best, but 3mm screws can be used also.
Changing the Rotor does not change the "wind" or turn of the motor. The New Sintered Rotor is simply a much better rotor then the orignal. Stronger and more effecient is the idea. Much better braking as well.
You can always email us directly [email protected]
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 03-15-2007, 10:38 AM   #2046
swopemike's Avatar
Thumbs up
Thanks Charlie.
PS the extra braking will be greatly appreciated. On our large asphalt track, with missle launch acceleration and the original rotor's braking, it only took a little too much throttle blip and I'd be testing our custom "SAFER" barriers again. My cars thank you !
Old 03-16-2007, 05:42 AM   #2047
edwintklee's Avatar
steve,
what is the lowest ratio for 3.5r motor on a hot day or let say 30 c.....?
Old 03-16-2007, 05:55 AM   #2048
Originally Posted by edwintklee
steve,
I use on a medium to large sized outdoor track a FDR of 7.9 for my 3.5R at 5 Cells.
Rob Janssen is offline   Reply With Quote
Old 03-16-2007, 11:36 AM   #2049
edwintklee's Avatar
thanks, i am doing 6 cell, any idea??
Old 03-16-2007, 11:39 AM   #2050
Super Moderator
Marcos.J's Avatar
try a 10.5 ive run it down to a 10.25 and it comes off the track around 160 degrees but i find that the motor runs better around a 10.75 fdr to a 11.25
Old 03-16-2007, 11:55 AM   #2051
The Evicerator
Marcos's recommendations are good. I usually run 10.5 or 10.3 depending on the track... larger tracks need different gearing though.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-16-2007, 07:29 PM   #2052
Aluma's Avatar
Whats the proper gearing for a 13.5 SS motor without the sintered rotor for a small track with a 90ft straight? I was running a CO27 at about 7.19FD. I've read from several thread to gear about 3.9 to 4.8FD, but my motor got up to 160 degrees running a 5.01FD...no way I'm going that low.
Aluma is offline   Reply With Quote
Old 03-16-2007, 08:26 PM   #2053
Super Moderator
Grizzbob's Avatar
Like I mentioned in my PM, I'd try about a 5.8 FDR to start, that should be closer to what you need(especially since it sounds like your track may be similar in size to mine)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-17-2007, 03:56 AM   #2054
JayBee's Avatar
Trader Rating: 31 (100%+)
You have a 13.5 SS Pro 'without' a sintered rotor?
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 03-17-2007, 06:48 AM   #2055
Aluma's Avatar
sorry Jaybee, not a "pro" motor.
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
