New Novak Brusless System >
Old 03-02-2007, 10:56 AM
  #1981
The Evicerator
Sorry DrKucho!
Culprit means "might be the reason for"
Endplay is exactly that... if you hold the shaft of your motor it is the amount that it can move in and out of the motor.
There should be a small amount of movement... if there is no movement the rotor could be binding up the bearings and causing the bearing failure you are experiencing.
Steve Weiss is offline
Old 03-02-2007, 11:02 AM
  #1982
understand, i will check on that ! thanks
DrKucho is offline
Old 03-02-2007, 12:07 PM
  #1983
Trader Rating: 54 (100%+)
I just want to check that the rotor that comes with the upgrade kit for 4300/5800 motor can be used in 4.5 motor? Thanks.
Yellowtaro is offline
Old 03-02-2007, 12:38 PM
  #1984
The Evicerator
The rotor that comes in the 5929 upgrade kit will work in your 4.5R just fine.
Old 03-02-2007, 05:27 PM
  #1985
Sam_Smith's Avatar
Quick questio...what sort of gearing is everyone using on a medium sized carpet track with the a)3.5 b)4.5???????
TIA
Sam_Smith is offline
Old 03-02-2007, 06:09 PM
  #1986
The Evicerator
Sam,
Really depends on your tire size... but if I recall correctly with like 57.5 mm tires I would run 10.5 with the 3.5 and 9.5 with the 4.5... that's with sintered rotors in either one.
Old 03-02-2007, 06:16 PM
  #1987
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
steve
will the new spectrum gtb be sold with motors????like the current system, or will it be esc only????
thanks
Matt
Matt M. is offline
Old 03-02-2007, 07:28 PM
  #1988
The Evicerator
I *think* for now it's just going to be sold by itself... I don't think they want to have all those new part numbers to worry about
Old 03-02-2007, 11:36 PM
  #1989
Just bought a 4300 motor few weeks ago and saw that 10.5 is out. So what is the performance difference between the two motors? Is 4300 going to be smoked by 10.5?
Old 03-02-2007, 11:44 PM
  #1990
syndr0me's Avatar
Trader Rating: 32 (100%+)
Na, the 4300 is a 10.5. The 10.5 just comes standard with the sintered rotor and a ribbed can. If you get the sintered upgrade kit for your 4300, it'll be the same motor aside from the "ribbed" look of the can. Unfortunately, it's a bit of an expensive upgrade. :-(
http://www2.towerhobbies.com/cgi-bin...?&I=LXPYT1&P=7
syndr0me is offline
Old 03-03-2007, 05:43 AM
  #1991
rcdy's Avatar
steve, will the new gtb prevent posible glitch prob? I had the same prob until i switched to dsm.
rcdy is offline
Old 03-03-2007, 09:38 AM
  #1992
The Evicerator
If you use the Spread Spectrum only GTB with standard 27, 40, or 75 MHz systems your chances of glitching are higher than if you were to run a standard GTB.
This is because the Spread Spectrum only GTB has faster switching, which while it makes the ESC run cooler and more efficiently, is also more prone to glitching with standard radio gear.
When you run Spread Spectrum you do not need to worry about the little bit of extra noise created by the faster switching because your radio system is operating much further out of range of the interference than before.
Old 03-04-2007, 12:06 AM
  #1993
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
Steve . i just bought a 13.5 with gtb , what is the gearing for this motor on a xray 007 US , i started with 116spur and 34 pinion for a final ratio of 5.80 and this thing was asking for more. apprx 135 for temp
turboxrayt1fk05 is offline
Old 03-04-2007, 08:32 AM
  #1994
The Evicerator
I am pretty sure most everyone is gearing the 13.5 in the mid to upper 4's... 4.5 would require a 43 tooth pinion.
Old 03-04-2007, 11:26 AM
  #1995
ottoman's Avatar
we run our 007 with a 100 spur and a 34/36 pinion. This is rubber tires on carpet. You wont be able to gett a big enough pinion on with a 116 spur
ottoman is offline
