Old 02-12-2007, 02:35 AM   #1906
Drewdc90's Avatar
My GTB got a little warm last metting.
New Novak Brusless System-dscf0890-small.jpg   New Novak Brusless System-dscf0893-small.jpg   New Novak Brusless System-dscf0894-small.jpg   New Novak Brusless System-dscf0895-small.jpg
-Xray--Nosram--Orion--Trak Power--Duratrax--Spektrum--Futaba-
Sunshine Coast QLD AUSTRALIA
"If you stand still long enough you'll go backwards"
Drewdc90 is offline   Reply With Quote
Old 02-12-2007, 03:12 AM   #1907
warren_s's Avatar
Send a message via MSN to warren_s
What did you do?
All gods creatures have a place alongside my chips and gravy
T2'007 - resting / TRF 501x x 2 RIP / Durango DEX410 - All I can say MFG "WEAPON"
TC12L4 - why? / TC5R - Love that car /M05 Pro little bit on fun
MBX5R - noisy bugger / SC10 / T4 x2
warren_s is offline   Reply With Quote
Old 02-12-2007, 04:41 AM   #1908
Drewdc90's Avatar
Nothing, it ran fine for the first three races then towards the end of the last race the car slowed down and heaps of smoke poured out of the car, a marshal unpluged my battery but it was a too late. I might try the GM next.
Old 02-21-2007, 11:03 PM   #1909
Trader Rating: 48 (100%+)
How do you gear the 4300 motor for touring cars with rubber tires? What is the recommended FDR for this motor? Thanks.
Yellowtaro is offline   Reply With Quote
Old 02-21-2007, 11:14 PM   #1910
syndr0me's Avatar
Trader Rating: 32 (100%+)
It varies greatly depending on what rotor you're using, and a little bit based on what batteries you're using. With LiPo, I can give you a ballpark in rollout. I'm not sure how to convert that to FDR.
Bonded (stock) Rotor: 28.5MM
Sintered Rotor: 33MM
The 4300 ships with the bonded rotor. The updated version that's coming out, the SS 10.5 Pro will ship with the sintered rotor. You can update your 4300 with a sintered rotor as well, though you'll need to also add the updated endbell with the larger bearing. There's a kit specifically for this that comes with the sintered rotor.
syndr0me is offline   Reply With Quote
Old 02-22-2007, 05:02 PM   #1911
Hi there
i got a little mess on my GTB capacitor ... i removed the heat shrink cover to check the damage
it got a road shave ... , there was some liquid in the shaved part, not much, looks like the shaved part was sweting , i cleaned it with a napkin , and it looks like it doesnt sewt anymore ....
i should replace it , i know , but im not sure i can get a new one before sunday race...my question is , what would happen if i run it and capacitor fails? would it damage the ESC? battery? both? nothing? flames? explosion?
DrKucho is offline   Reply With Quote
Old 02-22-2007, 05:48 PM   #1912
I have the upgrade to sintered rotor. Just out of curiosity, how do you calculate roll out? What is considered a good rollout?
Old 02-22-2007, 05:55 PM   #1913
greetings all,
Will the SS 13.5 Pro combo include the spread spectrum speedo (#1711 GTB Spread Spectrum Brushless/brush ESC)?
Cheerz
Obsidian is offline   Reply With Quote
Old 02-22-2007, 06:21 PM   #1914
Nexus Racing's Avatar
That's pretty risky...it'll probably damage the ESC based on what I have seen.
Novak recommends changing power caps even when they get the slightest little dent!
NEXUSRACING.com
Nexus Racing is offline   Reply With Quote
Old 02-22-2007, 07:08 PM   #1915
SlamMan's Avatar
www.GearChart.com for calculating roll out. Try one of the roll outs syndr0me recommended.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 02-22-2007, 07:44 PM   #1916
AngryAsian's Avatar
Yeah true - I assume because it's doing 3 times the work of a "Regular" speedo, the large cap is required to stop the thing from overheating..
Actually - I do recall some members who had thermalling problems which were "cured" by replacing their caps..
You could always substitue another cap in there if you can't find the Novak one. Or get a few smaller low voltage capps and wire them in parallel.
Eg. 2 x 2400uF 10V in parallel..
Actually the more caps the better..
AngryAsian is offline   Reply With Quote
Old 02-23-2007, 06:05 AM   #1917
thx, im trying to get the cap but looks like here in spain 10v capacitors are not so popular , we have 16v , 25v and they are bigger in size.... i woudnt want to run a very big cap .....
i know VFS-1 ESC fr brushed motors uses 25v and 2500uF which size is just little bigger than GTB one
so i wonder , if i use a 16v cap, can i use less uF ( lets say 3500 ) ?
Old 02-23-2007, 07:13 AM   #1918
rcdy's Avatar
you can use capacitors with higher volts but keep the uF the same as the one novak used on the GTB. so 16v is fine.
TeamXray, TeamAssociated, Esky, Tamiya
rcdy is offline   Reply With Quote
Old 02-23-2007, 08:55 AM   #1919
will the extra volts do anthing good to ESC or battery?
Old 02-23-2007, 09:40 AM   #1920
The Evicerator
Hey guys,
Just wanted to let you know that any of your local hobby shops/distributors that carry Novak products should be able to order you proper replacment capacitors from us.
Just ask them and I'm sure they'd be happy to order them for you!
Most of the team runs the Trans-Cap Module on pretty much everything. The Novak part # for that is: 5679
Cheers guys!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- 1UP Racing -- ActivRC -- P1 BRAND -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
