New Novak Brusless System >
Old 12-18-2006, 07:28 AM
  #1741
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
Originally Posted by tornado
Hey guys.....how to fit the motor heat sink ?.....mine don't fit....
yiu might have to heat it up some to let it expand
Marcos.J is offline
Old 12-18-2006, 07:32 AM
  #1742
dr_hfuhuhurr's Avatar
Trader Rating: 91 (100%+)
Yeah, if Novak's going to put out a smaller brushless ESC, it may just bring me back to the Novak table. Though a small esc with a Massive Capacitor doesn't really help.
dr_hfuhuhurr is offline
Old 12-18-2006, 08:26 AM
  #1743
vtl1180ny's Avatar
Funny thing.... I'm loving the 13.5 in my 12th scale but I can do without the GTB.... It just doesn't fit well in my Gex-X, the chassis is way off balance, and I'm relying on the tweak screws to preload the one side a heck of a lot more and if I could find a smaller ESC to run the motor, I'd jump on it in a heartbeat.... I guess I could put a hunk of lead, but I don't want to make the car any heavier than it already is....
I'd kill for a smaller ESC right now....
vtl1180ny is offline
Old 12-18-2006, 08:53 AM
  #1744
Trader Rating: 17 (100%+)
Don't force it...you are not the only one, call NOVAK now and they will let you know what to do....if you force it, it will never come out again.
Solara is offline
Old 12-18-2006, 09:33 AM
  #1745
Super Moderator
Marcos.J's Avatar
check your pm i got a way to mount it on a 1/12th scale
Marcos.J is offline
Old 12-18-2006, 09:53 AM
  #1746
vtl1180ny's Avatar
Thanks.....
Old 12-18-2006, 11:16 AM
  #1747
asw7576's Avatar
When I buy Velocity 7.5R, lets say in January 2007. Do I get the sintered rotor ? What about the ribbed casing on 7.5R ?
asw7576 is offline
Old 12-18-2006, 11:25 AM
  #1748
Super Moderator
Marcos.J's Avatar
sintered rotors are great i have one in all my motors!
Marcos.J is offline
Old 12-18-2006, 11:34 AM
  #1749
asw7576's Avatar
Will later production of 7.5R comes with sintered rotor as standard or we have to buy it separately ?
asw7576 is offline
Old 12-18-2006, 11:36 AM
  #1750
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Use a heat gun to heat it up and then slide it on. It *should* slide on with out much if any resistance so I expect after it is hot. Just be sure you get it situated and aranged on the windings how you want it before it cools as you may not be able to turn it after it has contracted. IF you can't get that to work, like mentioned above DONT FORCE IT!!! Call novaks cs and they will give you some better info on how to get it to work. If you want to go back a few posts/pages you will read what happends when you force it (personal experience)
andrewdoherty is offline
Old 12-18-2006, 12:24 PM
  #1751
Super Moderator
Marcos.J's Avatar
not sure on that one but is a great upgrade to get the sintered rotor
Marcos.J is offline
Old 12-18-2006, 01:25 PM
  #1752
I thought I saw somewhere saying sintered rotor is standard on ONLY 3.5 motors.......the rest of the motors are option. It is not a recall/replacement item so it does not matter when or where you get your 7.5 motor.
Solara is offline
Old 12-18-2006, 03:13 PM
  #1753
Originally Posted by syndr0me
Hmm, if they're releasing a 4 cell version, it's almost certainly going to be smaller. What reason would they have, otherwise? I wonder if it'll work with 6 cells using the slower motors, like the 13.5 or 4300. The mind boggles!
Looks like the 4300/5800 upgrade kit has been updated to include the sintered rotor. That eases the pain a little bit, and makes the process a little easier. Hopefully we'll see an improved 10.5 motor in the future.
http://www2.towerhobbies.com/cgi-bin...?&I=LXPYT1&P=7
Saw that from RCzone...probably on Novak site too...
"NEW LIGHTER GTB SPECIFICALLY DESIGNED FOR 4-CELL APPLICATIONS
Novak is pleased to introduce the #1714 GTB 4-Cell Programmable Racing Brushless/Brush ESC. The new #1714 GTB is 25% lighter and has a 30% smaller height profile than the original #1710 GTB, yet retains all the great features and performance of the original GTB, but is geared for 4-cell applications. Also new is the #5485 Novak 4-Cell Transponder Voltage Booster, which can be used with any 4-cell application to boost voltage to the transponder for consistent lap counting
Description: The GTB 4-Cell Programmable Racing Brushless/Brush ESC offers all the same high-tech features and performance as the original #1710 GTB, but is geared specifically for 4-cell applications such as 1/12-scale on-road and 1/12 or 1/10-scale pan car oval. Includes 6 throttle profiles specifically designed for 4-cell racing. Features a 25% lighter and 30% smaller height profile than the original #1710 GTB. Compatible with any Novak 540-size brushless motor and any brushed motor. Additional features include a user-friendly programming interface, gold-plated PCB Direct-Solder Wiring Tabs, Re-solderable user-replaceable input and switch harnesses, a water-resistant case, and Thermal Overload Protection. Designed and manufactured by Novak in the USA.
Part Number: #1714
List Price: $325.00
Available: January 2007.........."
GTB for 12th scale.............
Solara is offline
Old 12-18-2006, 03:16 PM
  #1754
Super Moderator
Marcos.J's Avatar
Part Number: #1714
List Price: $325.00
im buying one i need more room in my 1/12th scale
Marcos.J is offline
Old 12-18-2006, 03:19 PM
  #1755
Nooooo....why January. Everything is January...I think January is the new "Two Weeks".
Tekin Brushless - January
LRP Sphere Comp - January
Novak 4 cell BL - January
Losi Type R - January
It's an RC conspiracy!
