New Novak Brusless System >
Old 12-01-2006, 03:48 AM
  #1666
pheyhoe's Avatar
Ok, im still searching for that magic gear ratio. Im currently running 11.5 on a 3.5 and LIPO. I ran it on a fairly fast sweeping track with not many braking points and it was fine. I had it set at 120 Trottle High Pot, 150 being full (yes its set correctly so when you got o 149 it does decrese the motor speed)
so thats 11.5 wtih lipo at 120.
Now i tried running the same gearing on a similar size track in a smaller hall which was more twisty so it required more acceleration and braking. But i only ran the Hipot at 105. thermalled at about 4 minutes. Somebody told me that i might have gone the wrong way with my gearing but if its not thermalling on a higher speed circuit that tells me its not thermalling becasue its revving too high... the highest gearing i can acheive is 13.5.
What would you recommend i try next? 12, 12.5, 13?
pheyhoe is offline
Old 12-01-2006, 04:27 AM
  #1667
Racingbod85's Avatar
Christ. I've been running a 4.5 on 9.9 on big but twisty track at carpet wars and it was near cold when it came off! saw someone gear a 3.5 to the moon - absolute missile, baking hot but still going. i think you're going the wrong way.
Racingbod85 is offline
Old 12-01-2006, 05:50 AM
  #1668
STLNLST's Avatar
Trader Rating: 32 (100%+)
I don't know the actual size difference of both of your tracks but I'd run a 3.5 at about 10.4-10. Out here the only reason to run the 3.5 is to get that killer launch of the corners to mid straight. The motor is still coming on at the end of the straight when it's time to let off for the turn. The 4.5 does the exact same but it's a hair milder. Are you heavy on the breaks and are you running a sintered arm in your 3.5?
STLNLST is offline
Old 12-01-2006, 05:59 AM
  #1669
pheyhoe's Avatar
Its about 25 meters by 16 meters.
I ran 10.1 and it thermalled early on in the race. That might have been becsaue the track was extra twisty that week and you really had to use the brakes to be fast.
I will try it at 10.5 and see how it goes. Im just suprised that the motor would be revving too high as it was only on 105 out of 150. It was about as fast as a 10-11 turn motor..
And yes im using a sintered rotor.
pheyhoe is offline
Old 12-01-2006, 06:29 AM
  #1670
R/C Tech Elite Member
Marcos.J's Avatar
Trader Rating: 240 (100%+)
i ve been running a 10.75 with the 3.5 with no issues , i cut back some of the drag brake on profile #1 and I barely use brakes, motor comes off the track around 120 degress. I also have the new Novak heatsink installed in it with a Nexus fan on the esc wired to the receiver.
Marcos.J is offline
Old 12-01-2006, 04:58 PM
  #1671
Charlie's Avatar
Pheyhoe, Don't turn your EPA down to make it slower. That actually makes it hotter. If it's over geared, it's overgeared, doesn't matter how little throttle you use.
Gear down on the pinion for a smaller or tighter track.
Charlie is offline
Old 12-01-2006, 07:20 PM
  #1672
i decided to post this here since i didn't want to start a new thread, but for the ss+ speed control, i can't change drag brake or minimum brake individually. whenever i change one, the other changes too. is this supposed to happen? i want to put my drag brake up without having minimum brake on, is this possible through the esc? actually, maybe i should get the terms straight. minimm brake is a braking force that is always on, and drag brake is the braking force when the throttle is in neutral? i actually don't what what dead band means either, but i dont think i'll use it anyways.
SSJChar is offline
Old 12-01-2006, 10:41 PM
  #1673
Jochim_18's Avatar
ok guys I installed my GTB/4300 I got some glitch or something the motor keep on running on and off without a throtle input whats going on?
Jochim_18 is offline
Old 12-01-2006, 10:47 PM
  #1674
Marcos.J's Avatar
check your sub trim and reset your esc to your radio
Marcos.J is offline
Old 12-02-2006, 02:36 AM
  #1675
jarkkom's Avatar
Does anyone know what size are the bearings in SS5800 with an upgrade endbell?
jarkkom is offline
Old 12-02-2006, 05:51 PM
  #1676
Jochim_18's Avatar
I'll try that... But I think is my radio battery I just noticed is already below 10 volts
Old 12-02-2006, 05:55 PM
  #1677
Marcos.J's Avatar
that will probably do it
Marcos.J is offline
Old 12-02-2006, 07:33 PM
  #1678
The Evicerator
SSJChar,
It is correct that you cannot adjust the minimum brake and drag brake separately.
To help explain things...
Drag brake is the amount of braking in a percentage out of full brake that the ESC applies to the motor while the throttle is in the "dead band"
The dead band is the area of trigger throw, both forward and backwards, that the esc does not send any power to the motor for. Usually this is set to 4 or 5%. The reason you have a dead band is because A.) Most radio's potentiometers are of low quality or simply wear out quickly...this can cause minute variations in regards to what throttle signal is given per trigger location. The dead band being there helps "soak up" some of that variation B.) If there was zero dead band the feel would be quite touchy.
Minimum brake is the amount of brake in a percentage out of full brake that the esc delivers to the motor at the first step out of the dead band in the reverse direction.
When you set your drag brake it sets not only the drag brake but the minimum brake setting to the same value.
When you adjust the minimum brake value it assumes that you do not wish to use drag brake and it disables it and simply uses the value you select for the minimum brake value.
There are a few reasons that we do not allow you to change them independantly of on another at the moment but the main one is that it would be completely possible for someone to set their drag brake to say 35%... and their minimum brake to 20%. What would happen would be that if you let off the throttle to neutral, the ESC would apply 35% total brake to the motor... and as you moved to brake... the esc would then only apply 20%... effectively making your car speed up when you hit the brake instead of slowing down.
This is a problem we had with the cyclone series ESC when people would program them with the Pit Wizard...they would set the drag brake value to a value that was higher than the minimum brake value and they would be confused as to why their brakes weren't working right.
Anyhow, hope that it helps you clear up some of your confusion!
Steve Weiss is offline
Old 12-02-2006, 07:34 PM
  #1679
The Evicerator
The large bearing is 1/2" x 3/16"
Old 12-03-2006, 02:50 PM
  #1680
Trader Rating: 54 (100%+)
Hi
I accidentally solder "A" wire to "C" solder tap and vice versa. I blip the throttle a few times just to test it and the motor warmed and was not smooth. I realized that I soldered wrong and corrected it. Is there any adverse effect to the motor or ESC due to what I did? Thanks.
Yellowtaro is offline
