Old 10-31-2006, 04:30 AM   #1561
pheyhoe's Avatar
R/C Tech Charter Subscriber
I am going to be running a 3.5 on a medium/large carpet track more twisty than simple. What gear ratio should i look at running?
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 10-31-2006, 04:38 AM   #1562
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
How low can you go?
I'd be starting below 11:1 - maybe 11.5:1?
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 10-31-2006, 04:52 AM   #1563
pheyhoe's Avatar
Well, im running a BD. waiting to hear how low it can go but the chart says 10.8...
Old 10-31-2006, 05:17 AM   #1564
BrainTeased's Avatar
hi guys i've got an enquiry to make hope someone can help.
i've brought a new GTB speedy on its own and a new 5800 motor on its own i was wonder out of the 2 items will either come with the sensor wires?
cheers in advance for the help guys
www.feralbatteries.com.au
BrainTeased is offline   Reply With Quote
Old 10-31-2006, 07:05 AM   #1565
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
10.8 should be good Ive been running the 3.5 on my Cyclone geared at 10.73 with no problems and its FAST!!
Old 10-31-2006, 07:34 AM   #1566
pheyhoe's Avatar
Thanks Marcos,
What size track are you running on? Are you running any fans?
Old 10-31-2006, 07:56 AM   #1567
Trader Rating: 16 (100%+)
Send a message via AIM to playinrc
brainteased all the motors that you buy from novak come with the sensor wire attached
Team Scream Racing,
playinrc is offline   Reply With Quote
Old 10-31-2006, 07:58 AM   #1568
Super Moderator
Marcos.J's Avatar
Thanks Marcos,
its a medium size track , I only run the fan on the GTB but I also have the Novak heatsink
Old 10-31-2006, 08:13 AM   #1569
pheyhoe's Avatar
Ok, thanks.
My track is a little smaller than that indoors. So i might need to get a fan or heatsink.
I dont suppose you know if the heatsink will be available in th UK? If not could you tell me which shop sells them thanks for your help.
Paul,
Old 10-31-2006, 08:51 AM   #1570
rampal's Avatar
Send a message via MSN to rampal
Originally Posted by DrKucho
hello all
anyone knows about the weight of the new Novak Velociti 3.5R Nickel-Plated Sintered Rotor compared with the normal one?
if it is more light its very interesting for me as i am driving a 5.5 motor in a shaft car subjected to torque steer, so less weight in te rottor should mean less torque steer
This is indeed interesting... has anyone measured it? I got both, but my scale gets nuts when close to a magnetic field....
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 11-01-2006, 04:55 AM   #1571
thanks mate!! appreicate your help much much
Old 11-01-2006, 06:52 AM   #1572
Super Moderator
Marcos.J's Avatar
Ok, thanks.
Paul,
http://www2.towerhobbies.com/cgi-bin...?&I=LXNLZ5&P=7
Old 11-01-2006, 12:57 PM   #1573
Trader Rating: 48 (100%+)
Has anyone run the 13.5 motor? How does it compare to brushed and race tuned stock motors?
Yellowtaro is offline   Reply With Quote
Old 11-01-2006, 02:37 PM   #1574
it is about the same 13.5 a little faster on the bottom
Team Scream Racing,
Old 11-03-2006, 07:02 AM   #1575
jobo_ph's Avatar
Send a message via Yahoo to jobo_ph Send a message via Skype™ to jobo_ph
I don't have a weighing scale but based on feel, the sintered rotor is slightly heavier than the regular rotor.
The sintered rotor's diameter is lesser though (around 2mm lesser).
The sintered rotor's magnet was obviously stronger than the used regular rotor which makes me wonder how much the magnet on the original rotor (around 30 5-minute runs) has weakened compared to when it was new.
Here's a side by side pic...
New Novak Brusless System-img_1101_.jpg   New Novak Brusless System-img_1104_.jpg
jobo_ph is offline   Reply With Quote
Novak GTB 4-cell Brusless Speed Controller Greg Amendola R/C Items: For Sale/Trade 0 04-16-2008 12:59 PM
WTB: ASSOCIATED B44 W/ BRUSLESS SYSTEM levi m R/C Items: Wanted to Buy 1 02-15-2008 05:27 PM
brusless esc , maybe system jslider R/C Items: Wanted to Buy 1 11-18-2007 05:30 PM
Novak XBR Brusless/Brushed ESC Delyt R/C Items: For Sale/Trade 4 11-15-2007 09:44 AM
Novak 4.5 Brusless System Speedo/4.5 Motor w/Sintered installed mike ivy R/C Items: For Sale/Trade 5 10-25-2006 06:57 AM
