New Novak Brusless System >
Old 10-23-2006, 09:23 AM
  #1546
rough512's Avatar
Originally Posted by Marcos.J
they mount via the fins just like the heatsink on the GTB
I initially thought the heatsink replaced the purple band on the BL motor... that would have been neat. No clamping needed. Go as far replacing the ribbed ends .
rough512 is offline
Old 10-23-2006, 09:31 AM
  #1547
The Evicerator
It DOES replace the purple band on the motor
Steve Weiss is offline
Old 10-23-2006, 10:24 AM
  #1548
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
it replaces the band look closely its not a clamp heatsink
Marcos.J is offline
Old 10-23-2006, 11:29 PM
  #1549
Drewdc90's Avatar
The only problem with it is that you wouldn't really be able to use a motor cooler (freezer). How much cooler does you motor run with it?
Drewdc90 is offline
Old 10-24-2006, 12:26 AM
  #1550
syndr0me's Avatar
Trader Rating: 32 (100%+)
My heatsink was impossible hard to get on or move around. I think I ended up killing a motor trying to position it on the rotor. Yay. :-(
syndr0me is offline
Old 10-24-2006, 03:19 AM
  #1551
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
With regards to the motor clamp/heatsink. Yes it does block the use of a motor cooler (peltier type). Yes, it is difficult to put on. (needs to be to effectively transfer heat).
Leonard.
DirtyDog3375 is offline
Old 10-24-2006, 04:26 AM
  #1552
BrainTeased's Avatar
hi guys i was wondering if anyone could help me with a small amount of info in regards to the 5800 motors.
are those optional sinerster rotors avaliable for the 5800 motors?
if i was to run both
GTB + 5800
and
SS+ esc and the 5800 motor
which setup would be faster? would GTB come out on top due to its lower resistance?
thanks in advance for all input
BrainTeased is offline
Old 10-24-2006, 04:58 AM
  #1553
rampal's Avatar
GTB + 5800
and
Hi:
In order to use the sintered rotor on the 5800, you need to get velocity bearing and endbell replacement that uses the oversize bearing that fits the sintered rotor. You can get the upgrade set, but it cames with a normal rotor, that you won't use anyway.
regarding the ESCs, I think I've seen some performance reports around both escs and a 5800 motor, and GTB ones were slightly better.
al
rampal is offline
Old 10-24-2006, 05:37 AM
  #1554
thanks a million for the input al
Old 10-24-2006, 10:18 AM
  #1555
syndr0me's Avatar
Originally Posted by rampal
Hi:
al
Get the ribbed Velociti endbell instead. It's 1/2 oz lighter than the one in the upgrade kit, and doesn't come with a rotor you won't need or use. Plus, it'll let you use the sintered rotor, no problem.
http://www2.towerhobbies.com/cgi-bin...?&I=LXMGJ4&P=7
I'm using that endbell with the sintered rotor in my 4300, no problem. The weight savings is a pretty big deal in my opinion, since the car is SO heavy on that side to begin with.
syndr0me is offline
Old 10-29-2006, 10:06 AM
  #1556
hello all
anyone knows about the weight of the new Novak Velociti 3.5R Nickel-Plated Sintered Rotor compared with the normal one?
if it is more light its very interesting for me as i am driving a 5.5 motor in a shaft car subjected to torque steer, so less weight in te rottor should mean less torque steer
DrKucho is offline
Old 10-29-2006, 03:57 PM
  #1557
BlueR1's Avatar
hi.
what is "Dead band"?
i assume min drive means that the motor moves even if left in neutral
having "minimum drive" doesnt that negate "min brake"
BlueR1 is offline
Old 10-29-2006, 07:43 PM
  #1558
FUJIMO's Avatar
Trader Rating: 63 (100%+)
Default BRUSHLESS TIMING
I AM HOPING SOMEONE CAN HELP ME OUT.
I HAVE SEVERAL GTB SYSTEMS AND 3 NOVAK BRUSHLESS MOTORS.
I HAVE HEARD THAT BY MOVING THE BLACK NOTCHED RING ON THE BACK SIDE OF THE MOTOR, THAT YOU CAN ADVANCE THE TIMING.
IS THIS A FACT OR FICTION ??
AND IF IT IS FACT, DO YOU INCREASE TIMING WITH A CLOCKWISE TURN OR COUNTER CLOCKWISE TURN ??
AND HOW DO YOU KNOW WHERE TO STOP AT ?
DO U TURN IT ALL THE WAY IN ONE DIRECTION OR WHAT ??
I ATTEMPTED A LOOK THROUGH THIS POST BUT WITH 52 PAGES THAT STARTED TO GET TIME CONSUMING.
ANY HELP IS APPRECIATED.
BY THE WAY, THE MOTORS ARE 3.5R, 13.5 AND 4300
THANKS, FUJIMO
FUJIMO is offline
Old 10-30-2006, 02:42 AM
  #1559
AngryAsian's Avatar
Originally Posted by BlueR1
hi.
Dead band is the small throttle movement allowed before the motor starts to move. More dead bands means you can pull the trigger further before things start moving...
Min drive is the initial percentage throttle that comes in. So you can choose a small initial throttle, or large initial throttle. THis is analogous to changing how much "punch" the motor has..
DItto for the brakes...
these two adjustments are independent..
AngryAsian is offline
Old 10-31-2006, 04:03 AM
  #1560
BlueR1's Avatar
howdy.
would there be any issues if i used a too long a screw for the engine mount hole? i think mine went too long and i think it hit something on the inside of my 6.5r. i didnt turn on the motor though. you think this may of done damage?
also how are the older type 4300/5800 motors? do they have the same "feel" as the newer velociti motors?
BlueR1 is offline
