New Novak Brusless System
#1531
Super Moderator
Originally Posted by dbmartin
I have discovered a cure for my thermals, For the longest time, i would keep shutting down at the 3.5 minute mark with my 4.5, I eventually switched back to the 5.5 so i would make a full race. I then in practice set my min. drive to the setting 1, from both the 2 and 3 settings. I ran 6.5 minutes in 90 degree wether. ran the same setup the hext day in both my heat / main, and did not have any shut downs. By the way, the car was still a rocket
fdr 10.17, did not try a higher gera, but didn't need to as the car was plenty fast.
Temp coming off track was 157 degrees
My settings were
7 on drag brake
1 on min drive
3 on the min brake setting
everything else is default.
My settings were
7 on drag brake
1 on min drive
#1532
Super Moderator
Originally Posted by Marcos.J
the cure to my is I run a 11.0 with the 4.5 with the default profile #1 and with the track temperature around 140 my motor still comes of the track around 135 degrees.
#1533
R/C Tech Elite Member
Originally Posted by syndr0me
Also, brushless motors stop getting faster and start getting hotter when you overgear them. They may not slow down, though, so it won't be apparent that they're overgeared. If you go up a tooth and it's not any faster, go back down a tooth for your next race. The motors often have enough torque to overcome bad gearing, but it will cause them to heat up and use more battery.
#1534
Originally Posted by CIVIC91
Hey Syndrome, what's the part number for just the endbell upgrade?
Each of these endbells has a larger bearing in the front, which will allow you to use the newer rotors. You won’t be able to use your stock SS rotor, though. You’ll be able to ditch the brass shims which will quiet the motor down a lot. I recommend the sintered rotor, personally. I’m going to be using the ribbed endbell with the sintered rotor in my 4300. Here’s the two parts:
http://www2.towerhobbies.com/cgi-bin...?&I=LXMYJ8&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMGJ4&P=7
#1536
I'm beginning to feel skeptical about the tunability of these motors. The tuners keep saying "you just wait and see," insinuating that when there's enough interest, the tuners will get around to messing with these too. While we've seen that there's a few things you can tweak, nothing at all has provided significant results. Not to mention, the motors are so damn powerful, I'm not sure anything small matters like it does with brushed motors. I think I could replace my bearings with bushings in the 4300 and it wouldn't slow down.
#1537
with this new heat sink you can already mount any 25 x 25 mm fan with out any modifications.
How so Marcos? I looked at one at my LHS today and couldn't figure out how the fan would mount. I didn't see any screw holes . . .are teh gaps in the fins just the right size to alow M3 screws to catch and hold? Just looking for some clarification. Peace!
#1538
Super Moderator
#1544
I am looking for a brushless motor to run TC stock class. I also heard of a sintered rotor upgrade that will allow the motor to run cooler and "faster".
Does anyone know this setup?
#1545
The setup you're hunting for is the Novak 13.5 motor with a GTB esc.
It is the MOST comparible motor to a regular brushed stock motor. I'm not saying that it is or isn't actually comparable. Different ppl say different things. But it is definately the closest thing they do.
Yes - this is nit picking. But someone will always want to chime in.
As for the sintered rotor - again a Novak product designed for their motors only. Improves the low down torque of the motor and is more resistant to high temps.
Check with your locla track to see what IS or ISN'T legal before buying!!
Hope that helps.
Hope that helps.
