Old 08-18-2002, 06:20 PM   #16
Peter Busch's Avatar
R/C Tech Charter Subscriber
Who makes the Titanium sets, was it HG or Hardcore?
Peter Busch is offline   Reply With Quote
Old 08-18-2002, 07:03 PM   #17
rcruv's Avatar
Yes, they do. And other brands like team ae, tamiya also make some parts for their kits.
Maybe there are some more.
rcruv is offline   Reply With Quote
Old 08-18-2002, 09:01 PM   #18
Which one, HG (hammund ghummand) or Hardcore?
Old 08-19-2002, 10:02 PM   #19
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
I see where Niftech describes their titanium screws as 10 times stronger than aluminum screws. About $4.00 for each screw.
John Stranahan is offline   Reply With Quote
Old 08-20-2002, 01:11 AM   #20
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
hey John. miss your Tips and Tricks for Stock thread at Trinity Tech Talk. That was really informative stuff you had going there. Maybe you can start one out here in rctech. Im sure a lot of guys will learn a lot from you. Or maybe you can contribute to the "Faster Cornering Speed" thread.
By the way, i was "fAfA" at tech talk. remember me? im that friend of alfred and abit in manila. anyway, i hardly post there so you might not recall ....
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-20-2002, 07:11 AM   #21
RoboRat
Yes I remember. Good to hear from you. I'll tell Alfred Hello. I'll take a look at the other thread.
Old 08-20-2002, 09:09 AM   #22
ruf
ruf's Avatar
Send a message via AIM to ruf
ROBORAT - Alfred just celebrated a birthday this weekend. Both of them are doing very well. Abit is shopping for a new bike...
As far as screws go, the nicer lunsford stuff is advertised as 6al/4v so it is the nice stuff. I'm not sure of the T6 aluminum. I assume that they are heat treated to some extent, but it may be T5 or something. Duralumin is a cheap aluminum alloy that tends to bend instead of shear. IIRC, SS should be the strongest of the bunch followed closely by titanium. The thing is that SS is relatively brittle in comparison so it CAN break where a titanium part would flex/bend and live. Ballends come to mind. How many SS ballends have you snapped off at the head and how many titanium ones? I'm also used to seeing titanium turnbuckles bend before they break. Aluminum should ONLY be used in non-load-bearing applications. No shock towers, no suspension pivots, no bulkheads. I might use them for gearboxes, but I usually reserve them for upper decks if anything. That is where the weight savings will do the most good anyways. I actually stay away from aluminum now. I use steel screws on all my bottom deck mounts, and titanium anywhere else. I like to think it keeps my CG lower, but I'm sure it's insignificant...
Also NEVER buy HG crap. That stuff is horrible for fit and finish. It will destroy other parts on your car. Lunsford, Niftech, Yokomo, Tamiya, and Schumacher all market very accessible, reliable titanium screws.
Joe Chen
www.reflexracing.net
ruf is offline   Reply With Quote
Old 08-20-2002, 09:03 PM   #23
ROBORAT's Avatar
ruf/John: thanks for saying hi for me. alfred and i are in touch thru email ang via yahoo messenger. we're actually planning to meet up in NY next month if my US trip pushes thru. I was thinking of doing some racing there but i'll be with the wife and kid and dont think i'll have time fly over to houston so thats why alfred will come meet up with me (besides he gets free airfare thru his sis!). i may check out the trinity facilities in jersey with another fellow filipino based there.
John: saw your post at the other thread. great stuff as usual! finally, i have something to follow in these message boards! keep it up!
Old 08-20-2002, 09:03 PM   #24
Well Joe and I sacrificed two screws for science tonight. One was a blue aluminum screw (probably associated). I broke it in half with two small pair of pliers. Pretty easy. It broke with a brittle fracture (you can see the crystals of the metal in the break). No tearing. No real bending at all. This indicates a tempered aluminum screw.
The other screw was a standard steel screw that comes with the Losi and Associated kit. It bent a little (about 10 degrees) and then broke with a brittle fracture. This indicates a tempered screw that is quite a bit harder than grade 5 which will bend over 90 degrees. Probably a grade 8 screw. Much harder to break than the Aluminum. OK, so I was bored waiting for packs to charge.
By the way join us at ReflexRC in Houston for the Region 9 on-road regionals this weekend August 24-25 Check details at ReflexRC.com
Roborat-Thanks. Seems we posted at the same time.
Old 08-20-2002, 09:13 PM   #25
rcruv's Avatar
Both of them do as far as I know.
Old 08-20-2002, 10:11 PM   #26
TRF-Powered's Avatar
Just wonder if is it harder to anodize Titanium screws?? or anodizing any type of metal is pretty much the same just some material needs longer time to do it?
TRF-Powered is offline   Reply With Quote
Old 08-21-2002, 05:36 AM   #27
TRF-Powered. Pretty simple to anodize titanium. Use simple green for a solution and three 9 Volt batteries to get a blue color. Takes about 10 seconds per screw. More details if you like.
Old 08-21-2002, 02:05 PM   #28
John,
Simple Green as solution!!??!!!!! Wow....I thought might be some Cu+ based solution to get the blue color... since Cu+ is blue colored. But simple green~! hum~
Yeah more detail please~ should I make the screw attach to the positive side or negative side??
Thank you very much!
Old 08-21-2002, 05:05 PM   #29
Place negative wire in the solution and let it fall to the bottom. Attach positive wire with a clip to the clean and degreased part (use alocohol). Dip the part not including any part of the clip into the solution for 10 seconds. Presto blue turnbuckle. Polish the part beforehand if you want to improve the finish. The solution only acts as a conductive medium and does not add to the color in any way. Lots of things will provide a good solution. The color is affected by the thickness of the anodized layer that forms on the part. Colors (grey 9V), Dark purple 18 V, Blue 27 Volt, light blue 36 V. Connect the 9 Volt batteries in series (plus minus) to obtain the proper voltage. Use three 9 V transistor batteries to get 27 Volts. Although these batteries are on the tiny side, 27 volts will give you quite a shock and start quite a little fire if you short them. Be careful. I always like to wear some kind of eye protection even though the simple green is a fairly safe chemical it is probably not pleasant to splash it in your eye. You can connect the batteries by soldering short lead wires to them or use alligator clips. Have not tested the setup with clips but saw the setup work quite well with soldered batteries.
Old 08-21-2002, 09:12 PM   #30
ROBORAT's Avatar
John: ive alwasy wanted to learn how to anodize! wow! it sounds simple. but im not clear about how to set-up the positive wire with that clip you meantioned. cant picture it in my head. is the process the same for aluminum screws? and how do you get non conventional colors like red, orange, green?another thing is if lets say a screw is already anodized blue, can i re-anodize it to change it to another color?
oh, and please pardon my ignorance. what is simple green and where can you get that? sorry for the stupid question.
TC3 graphite chassis strength berlincam86 Electric On-Road 5 07-08-2007 06:07 AM
tranny/diff strength Losi VS. Associated yamrz350 Electric Off-Road 31 03-07-2007 04:10 PM
No Bling, but strength bcane98 Monster Trucks 27 01-27-2006 10:50 PM
Measure Magnet Strength vaiogeek Australian Racing 13 01-19-2004 02:23 AM
