Old 12-27-2005, 11:58 AM   #1021
thanks
Fantomcat is offline   Reply With Quote
Old 12-27-2005, 12:27 PM   #1022
Send a message via AIM to rcguy2477
Originally Posted by Fantomcat
anyone using the ice charger and ib 3800, can you post your setup with the amp rate, peak sensing and all of that. thanks
5mv per cell, 6 amps (the temperature reaches about 125 at peak and increases to around 130 about a minute afterward)
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 12-27-2005, 03:51 PM   #1023
rinkrat99's Avatar
Send a message via AIM to rinkrat99
HAs anyone had any issues installing the IB3600/IB3800 cells in the Losi JrXs when using the individual shrink wrap and an aluminum tray?
rinkrat99 is offline   Reply With Quote
Old 12-27-2005, 05:08 PM   #1024
wannabee's Avatar
Okay, I'm still having a problem with half my pack over heating. I've been racing for a long time and am no ROOKIE. So what the %#[email protected] is causing this??
They are Promatch TEAM packs, I have torn the packs down resoldered them and all...
It's like the pack isn't cutting off on the first 3 cells and the other cells are still charging...
I'm using a Pulsar Comp 2 I've dropped the cut off to 10 for the pack.
Did I get BUM batts.??
wannabee is offline   Reply With Quote
Old 12-27-2005, 05:32 PM   #1025
POOKYT's Avatar
Are you equalizing the cells before you recharge? Just a hunch.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-27-2005, 05:35 PM   #1026
wannabee's Avatar
Yea I bring them down until the lights go out then charge it.
I'm wondering if my charger isn't messed up...
Old 12-27-2005, 11:51 PM   #1027
Tks Anthony. So Cato is the brother of Derek and the owner of SR Batteries? The two brothers are so active in HK R/C. I can see their name in most HK Races. Wonder why Andy Lam has slow down in R/C??
MARKANO is offline   Reply With Quote
Old 12-28-2005, 08:24 AM   #1028
racer-oZ's Avatar
R/C Tech Charter Subscriber
i thought the lrp only went down to 5mv cutoff? isn't that too hot to charge the 3800's? i've always used 5mv on the pulsar for gp packs and felt it got them pretty warm...
another question... i gotta friend with a novak millineum charger, is 3mv low enough for 3800's or is that going to get them too hot as well?
thanks for the info, this thread is very helpful!
racer-oZ is offline   Reply With Quote
Old 12-28-2005, 08:26 AM   #1029
racer-oZ's Avatar
ringrat, if you use extra shrink wrap with 3600 and 3800's it's going to lengthen your pack by like .040 and you are likely going to have to dremel out the plastic part in the rear of the car to get them to fit.
Old 12-28-2005, 12:14 PM   #1030
The only real way to know if your packs are getting to the right temp is with a temp gun,chargers are diffrent so you will have to borrow a buddies temp gun if you don't have one to set your charger to the right temp 125-135 degrees is what you're after,mine peak right at 130 degree's this is on a gfx set at .02 dropback charging at 6 amps.
Hyper1 is offline   Reply With Quote
Old 12-28-2005, 12:24 PM   #1031
wannabee's Avatar
That is how I came to the 10MV per pack that my charger is set at. 5 out of 10 charges this will happen. The first 3 will keep charging almost like the line lock out is on, and there is no peak detect set. While the others are right at 125* the first 3 are at 150+ and still trying to charge.
If I don't shut the charger down they start venting...etc etc
Old 12-28-2005, 12:27 PM   #1032
Check the voltage on each cell and see how close they are.
Old 12-28-2005, 12:57 PM   #1033
wannabee's Avatar
The biggest spread is: 1.218 to 1.215 in a pack.
I can honestly say I've never had this problem with my GP cells.
Old 12-28-2005, 01:30 PM   #1034
[QUOTE=wannabee]The biggest spread is: 1.218 to 1.215 in a pack.
Are these the #'s on the labels? measure the cells with a volt meter say at their EQ point they should all be at .09 or what ever your EQ point is then measure it again at their peak to see what it is then.
Old 12-28-2005, 01:32 PM   #1035
wannabee's Avatar
[QUOTE=Hyper1]
Labels, will do, thanks for the advice.
KE
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
