Old 12-17-2005, 04:10 PM   #931
curious mind's Avatar
Default help
hello, i got my new pack (SMCib3800), as per instructed i made my initial charging at 5.0Amp ; 03mv/pack delta peak ; using a cell master, how come it only charged 2500mah?? Is this normal? Note: i did discharge the tray using novak smart tray. My second charge was a week after, Setting: 5.0A;05mv/pack; much more cel master, charge was 3600mah. iI was hoping it will charge more than 3800mah. Why oh why?? Hope you guys can help. tnx
curious mind is offline   Reply With Quote
Old 12-17-2005, 05:34 PM   #932
Regional Moderator
daniz24's Avatar
Maybe your battery is false peaking, you charging with a fan?
I've never experience that kind of problem with new batteries.
daniz24 is offline   Reply With Quote
Old 12-17-2005, 05:51 PM   #933
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
To get .03 like Danny suggest would be 30mV on the MM Cell Master. The cell master used Millivolts. I would start with 20 on the Cell master and check the temp. Then adjust till it peaks at 130 degrees F.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 12-18-2005, 03:46 PM   #934
Jsaves's Avatar
Default 3800
Danny, I know you have answered this before, but could you tell me what exactly to do for my 3800's 6 cell I use for mod touring (brushless) and my stock 4 cell 12th.
I have your batteries and it said to charge at 6 amps with a 35 mv cut off.
Is this correct still? I would like to keep my packs going for at least a year of on road ( winter) and off road (summer).
My process is to:
A couple days after racing I charge them 500 sec. each for storage. (Race every other week mostly)
The night before I race I discharge them on my Tekin 350 at 30 amps and then tray them on a trinity discharge tray until lights go out. I them charge them as I need to race day.
Thanks for any info
God Bless
Bryan
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 12-18-2005, 03:59 PM   #935
Company Representative
Danny/SMC's Avatar
Charge at 6 amps with 20mv - 30mv peak detect for the entire pack. The goal is to get the pack to peak in the 130-140 degree farenheit range measured with a temp gun.
After your run discharge them down to .90 per cell at 30/35 amps on your Tekin discharger. Leave alone until the next time you plan on using them. Prior to charging them place them on your discharge tray for a few minutes then start charging them.
Your routine that you have been doing is o.k. but you most likely lost a bit of runtime by storing them after they were trayed.
Danny/SMC is offline   Reply With Quote
Old 12-18-2005, 06:48 PM   #936
Jochim_18's Avatar
I discharge my 3800 @ 30 amp then I tray them until the lights go out and store them till the next race days, My 3800 will go over 4000 MAH which is amazing and I charge them on 6.5 with delta peak @ 28mv cut off temp around 130 -135 deg. It give my packs one heck of a punch.
I'm using maxamps IB 3800 they are awesome not to mention I don't have to pay an arm and a leg.
Old 12-18-2005, 07:57 PM   #937
cannon's Avatar
Trader Rating: 35 (100%+)
Most 3800's go 4100-4200 mah on charge.
cannon is offline   Reply With Quote
Old 12-18-2005, 08:07 PM   #938
JayBee's Avatar
Trader Rating: 31 (100%+)
My Br00d 4-cell packs average 4300maH
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 12-18-2005, 08:13 PM   #939
Still Bill's Avatar
My SMC and KC 3800 4 and 6 cell packs are typically in the 4300s.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 12-18-2005, 09:05 PM   #940
Jsaves's Avatar
Default Thanks
Danny,
Thanks for the info and the time.
God Bless
Bryan
CRC GT-R
CRC WTF-1
Old 12-18-2005, 10:00 PM   #941
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default IB3600 Techniques
Hi all,
I see Danny posted some standard practices for charging and storing. I have a couple questions for him.
Why do you reccomend charging at 6A vs 5A
The Peak detect is understandable.
Whats interesting to me is the methods used to prepare packs for the storage. You suggest to discharge the pack at 30A or 35A to 5.4V per pack. Would this create extra unneccessary heat and shorten the lifespan of the pack? Why not just discharge at 10A or 20A? What is the intent of discharging at such a high rate?
You mention to TRAY them prior to the next charge. Are you saying Equalize them prior to the next charge cycle?
What specifcally are you commenting on that reduced runtime?
rinkrat99 is offline   Reply With Quote
Old 12-18-2005, 10:27 PM   #942
UCHEATULOSE's Avatar
Talking
IB cells do not respond well to dead shorting or bringing down the voltage under .90 per cell . the result of dead shorting or a deep dis charge is loss of run time.
all of our cells are trained to dis charge quickly thus the need/reason to dis charge them at 30 or 35 amps at all times. they will perform best and give all they have if you keep the dis charge rate as close as you can to race conditions. the cells from smc have been matched at 35 amps to weed out the weak cells and to teach them to perform at there best by matching them to closer race conditions. danny feels the 35 amps is closer to real on track conditions than 30 amps.
the tray alot of racers have been using is the integy zero thirty. you place the pack in the tray until the lights go out. remove the pack as soon as the lights go out, this is to avoid a deep dis charge (under .90 a cell) and reducing run time.
place the pack in your battery box until the next time you race. when your ready to charge the pack on race day, place the pack into the zero thirty tray until the lights go out and charge.
*****disclaimer****** i'm not danny and i do not work for smc...but i did stay at a holiday inn express last night.
UCHEATULOSE is offline   Reply With Quote
Old 12-18-2005, 10:55 PM   #943
rinkrat99's Avatar
Thanks for the reply. I should state this is a question related to Stock class.
When I said Equalize, I use a rayspeed equlaizer which I believe discharges individual cells down to 0.9V at a 5A rate.
I think you are saying that a discharge rate equal to race conditions is how the pack should be brought down to 5.4V after a race.
My question is if I am running Stock and my typical avg discharge rate is 20A then I should match that rate to bring the pack to 5.4V?
I agree a 30A or 35A discharge rate for matching purposes does weed out weaker cells.
My plan for these new cells based on Danny's postings will be as follows;
Charge rate = 6 Amps
Peak Detect = 20mv - 30mv
Temp cutoff = 130-140 degree farenheit
After racing, discharge at 20A using my Integy 16x7 charger/Discharger to 5.4Vdc
Before recharging, Equalize on RaySpeed to 0.9Vdc per cell
Old 12-19-2005, 06:47 AM   #944
Suspended
cr250 is offline   Reply With Quote
Old 12-19-2005, 07:16 AM   #945
EddieO's Avatar
R/C Tech Charter Subscriber
Are you trying to say the "memory" effect does not exsist in a battery?
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
