Old 10-21-2005, 01:53 PM   #586
Danny: What are your thoughts on using a "maintenence zapper" like the Integy unit on these cells? It seems to have helped keep the voltage up on my 3300's, but this will be my first time using 3800's.
Corner Weight is offline   Reply With Quote
Old 10-21-2005, 03:36 PM   #587
Company Representative
Danny/SMC's Avatar
I never really used a maintenance zapper. I assume that if it worked well for you in the past it should still work.
Danny/SMC is offline   Reply With Quote
Old 10-21-2005, 06:41 PM   #588
UCHEATULOSE's Avatar
Thumbs up
Originally Posted by Danny/SMC
With a temp gun using .02 peak detect for the entire pack your IB3800 packs should peak in the 135-145 range.
lol i'm taking a number and standing in line for those killer volts.
i'm by no means a battery guru, but i gotta ask.. if joe racer walks into a hobby shop and has a choice between brand A gp 3700 cells matched at 30 amps with say 440 run time and 1.19 volts or choose brand b's cells matched at 35 amps with 411 run time and 1.195 + volts why in the hell would they buy brand A's bateries? this is a world dominated by numbers on little labels..it has been that way since the late 80's and hasn't changed ever since. more run time lower Ir and tons of voltage... team drivers run what they are given and can win any race at any time with avg equipment on occasion....but the avg joe racer will buy the best numbers he can find...GP is losing in the numbers game today....and this is coming from a racer who loved the GP 3300 cell fact is i think the 3300 cell was the best cell ever produced for r/c racing the last 20 years...right now though i see IB setting the standard and GP forced to catch up?
oscar if you match batteries you gotta admit the numbers coming from the newset IB cell makes your GP batteries a nice option for a cordless drill? numbers don't lie do they? would you care to take the IB challenge? have a turbo matcher contest may the best cell win? i'll bet on IB today IR voltage and run time all dominated today by IB cells
round 1 gp volts Ir run time
round 2 IB volts Ir run time
round 3 ????????
and the year is not over wow!
the snowbirds should be a deciding factor i'm counting the days....cya bill
UCHEATULOSE is offline   Reply With Quote
Old 10-21-2005, 08:31 PM   #589
biker's Avatar
hey guys, just picked up some IB3800 Pro-match packs...
Any special considerations for choosing a charger when using these packs? Or will anything that charged 3300's work ok?
biker is offline   Reply With Quote
Old 10-21-2005, 08:43 PM   #590
same charger 135 deg .02 drop back instead of 150 deg and .03 drop back used on the GP 3300 cell
dead shorting is a waste and leaving a 500 second charge in the pack if not going to be used 14 days or more is a good idea . gearing down a tooth and playing with brush cuts. they have a lower Ir so they release there power differently than a GP 300 did. oh and try and tray them right before charging. hope that helps? bill
Old 10-21-2005, 08:46 PM   #591
Pro Models's Avatar
Unfortunately you cannot take the Birds as a comparison between the ib3800s and the GP 3700s especially within the mod class, dont forget that Orion/Peak have the best drivers in the world so whether you like it or not they will be using GP 3700s no other human being will be able to get hold of.
Lets face it 'no offence meant' no driver is up to par to Hara, Rheinard or Groskamp, or Teemu at the moment so forget seeing any fair comparison between the two cell manufacturers ..... it would be interesting if each of the mentioned drivers are able to test both cells and see the difference in lap times .... however that would never occur .... the only competitors that would give them a hard time at the moment would be most probs Masami, Burch or Dumas but the odds of placing first is highly unlikely when the above mentioned guys are present.
The true comparison should be made at club level racing .... I have tried the latest generation Peak 3700 cells with all the bells and whistles of 1.195v labels stuck on the the cells and a normal ib3800 bought through an internet site claiming a 1.180 @ 30 amps on its labels . The truth is that the ib3800 gave me a .2 sec advantage per lap over the Peak pack ..... using a 7 turn motor..... I also tried out DC motor sport packs that claimed a 1.179v @ 35amps which also lead to further improvements in lap times. IB 3800's are giving us normal drivers the chance of owning top notch packs unlike the GP promoters who keep there best cells to themselves ......
Bye for now......
Pro Models is offline   Reply With Quote
Old 10-21-2005, 08:50 PM   #592
josh69162's Avatar
Send a message via AIM to josh69162
Danny recommended the CE Pitbull or Turbo35 to me, as my Millenium was frying my packs. I took his advice and bought the first Pitbull I could find. The step charge works great, and you get that CE quality charge. I'll never look back. And Pro Models: You should get a newer pack of IB's. Mine are 1.196 at 35 amps, with 420 seconds of runtime. I had to use this pack in two races, second one uncharged, because I forgot to charge my other packs. Granted, I didn't finish all of the first race, but I did finish more than half (around 3 minutes), and still had runtime for the full second race, with a 9 turn. I experienced very little drop off.
-Josh
josh69162 is offline   Reply With Quote
Old 10-21-2005, 09:59 PM   #593
koabich's Avatar
Send a message via Yahoo to koabich
Lets face it 'no offence meant' no driver is up to par to Hara, Rheinard or Groskamp, or Teemu at the moment so forget seeing any fair comparison between the two cell manufacturers ..... it would be interesting if each of the mentioned drivers are able to test both cells and see the difference in lap times .... however that would never occur .... the only competitors that would give them a hard time at the moment would be most probs Masami, Burch or Dumas but the odds of placing first is highly unlikely when the above mentioned guys are present.[/QUOTE]
Especailly if you consider the fact that drivers like Blackstock, Cryul, Easton, Burch (Tosso did not do bad this year on indoor carpet with foams consideringsince he is the current ROAR Indoor Carept National Champ) and several others typically win these type of races and most will probably be running IB Cells.
koabich is offline   Reply With Quote
Old 10-22-2005, 12:32 AM   #594
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
-Josh
Did you have a Millenium or Millenium Pro? Any idea what was causing the trouble?
Josh
Speedo is offline   Reply With Quote
Old 10-22-2005, 12:43 AM   #595
josh69162's Avatar
Regular Millenium. I'm not sure what it was. I didn't use the NiMH setting, because there were problems with that cooking your packs, and I never got the updated version. I just did a linear NiCD charge with 4mV/cell peak detect, and they got really, really hot if I let the charge go all the way through. Now I have perfect charges, so I'm not too worried about the Millenium anymore.
-Josh
Old 10-22-2005, 01:08 AM   #596
PitCrew's Avatar
I just got IB3800: 416 1.203 @ 35 amps.
PitCrew is offline   Reply With Quote
Old 10-22-2005, 01:20 AM   #597
Hello,
I would like to know if it's easy to make 5 min with an IB3800 and a 8 turn ?
ThanX
Team Awesomatix - WTF - Thunder Power - Mikovic Body Painting - ToniSport - PRT Electronics
Manu_05' is offline   Reply With Quote
Old 10-22-2005, 01:41 AM   #598
josh69162's Avatar
Yes.
-Josh
Old 10-22-2005, 06:33 AM   #599
Send a message via AIM to GroffBall
GroffBall is offline   Reply With Quote
Old 10-22-2005, 08:23 AM   #600
koabich's Avatar
Originally Posted by GroffBall
Where did you get his from, I hope not Promatch.
I've seen some SMC packs with numbers like that. I have several.
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
