Old 10-13-2005, 12:43 PM   #541
theisgroup's Avatar
i thought trays that have a cut off at lets say .9, stop doing anything after they reach .9v per cell. so leaving them on the that type of tray does not do anything. Like the rayspeed once the .9 is reached, the relay switchs open.
the resistory type trays like the integy (octane) basically just hold the cell at 0v with resistors and just keep from cell reversal.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-13-2005, 12:53 PM   #542
rayhuang's Avatar
Yes-the resister trays holds at zero-but it takes them a good 20 to 30 minutes to hit zero-even if they were trayed to 0.9 on a NOvak smart tray for example. Thats why its safe to put them in the Octane for 1 to 5 minutes. Its a quick way to drop the voltage and equalize the cells.
Old 10-13-2005, 12:56 PM   #543
theisgroup's Avatar
ahhh, i see said the blind man.
thanks Ray
yang lai
Old 10-13-2005, 09:10 PM   #544
josh69162's Avatar
Send a message via AIM to josh69162
What kind of step charging are you guys using? I really don't know what makes a good step charge, so any tried and true methods would be great. Thanks.
-Josh
josh69162 is offline   Reply With Quote
Old 10-13-2005, 09:16 PM   #545
Alex_kipper's Avatar
There are 2 ways to step charge (in my eyes)
Aim for run time, or punch
Im using the CTX cell master, and i have been step charging my packs
Using
step 1- 7.5 amps to 2200mah
step 2- .5 amp for 50mah
step 3- 6 amps till it peaks
peak setting 04 on the cell master
That setting gives me the both of best world for my batteries, Run-time And Voltage.
Alex_kipper is offline   Reply With Quote
Old 10-13-2005, 10:28 PM   #546
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Does anybody have a good setup for step charging 3700's and 3800's on the ICE?
CarlosG. is offline   Reply With Quote
Old 10-14-2005, 05:30 PM   #547
josh69162's Avatar
My current set up is:
7 amps to 3200mAh
.2 amps to 3250mAh
5 amps till a .012 peak detect on a Pitbull.
I'm thinking that the cool down stage might be a bit of a stretch. It does take quite a while for the second stage to get over and done with, and I'm wondering if bumping it up to .4 or .5 amps would be a wise decision.
-Josh
Old 10-14-2005, 09:36 PM   #548
teamgp's Avatar
-Josh
For the IB3800's:
1) 8A until 3050mAh
2) .2A until 3080mAh
3) 6.2A until 4mV/cell (or 20mV/pack) for stock/19T
.....or
.....4.0A until 4mV/cell (or 20mV/pack) for mod
If you don't know when the next run will be you can substitute the following two steps for #3 above:
3) 6.0A until 3500mAh **with a delay of more than 10 minutes before #4
4) 6.5A until 4mV/cell (or 20mV/pack) for stock/19T
.....or
NOTE: You have to tray them first, otherwise they may peak in step #3 before 3500mAh. If you didn't tray them, then cut #3 off at 3300mAh.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 10-15-2005, 06:35 PM   #549
josh69162's Avatar
What charger are you using? I have the Pitbull X3, so I am limited to three stages.
-Josh
Old 10-15-2005, 07:50 PM   #550
teamgp's Avatar
-Josh
Ah. I forgot to add that I'm using a Futaba CDR-5000 and performing each stage manually. I have each of the six steps below saved seperately on the CDR and I manually change to each steps saved settings after the previous one is completed. Of course I have to set my cell phones alarm to remind me during race day, so as not to let any time pass between the steps.
Guy Hood
Old 10-16-2005, 07:50 PM   #551
I should get 4 new packs of IB3800s by friday!!
Cant wait to see what the numbers are looking lke
Old 10-19-2005, 06:13 AM   #552
my IB3800 started to act weird.i cant charge the pack because the pack is showing 14+ volts before it charges.why is this?did one of my cells reverse?thanx
shortyboy is offline   Reply With Quote
Old 10-20-2005, 01:51 AM   #553
LazyBug's Avatar
Just got a message from my Japanese friend, Team Orion is testing IB cells for All Japan 1/10 Touing Car Championship. Are they leaving GP soon ???
LazyBug is offline   Reply With Quote
Old 10-20-2005, 03:15 AM   #554
cannon's Avatar
Trader Rating: 35 (100%+)
More likely a case of not putting "all your eggs in one basket" > And this was the company that basically said that IB cells were not up to the task.
cannon is offline   Reply With Quote
Old 10-20-2005, 03:22 AM   #555
LazyBug's Avatar
It will be really interesting to see if Orion will LEAVE GP this time
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
