Old 10-11-2005, 05:11 PM   #526
Company Representative
Danny/SMC's Avatar
No problem glad to answer and help when possible. These message boards are great to share info.
Danny/SMC is offline   Reply With Quote
Old 10-11-2005, 05:35 PM   #527
rayhuang's Avatar
Hey Guys,
I'd like to let people know that sme of the earlier reported failures of cells were caused by people charging the IB's with a 0.05 to 0.06 delta peak like there GP's. This lead to some cooked packs.
I charge at 6 and peak at 0.024 on my Pitbull X3 and 0.02 or 0.03 depending on room temp on my GFX. I peak around 4300 or mor e mah (not that thats important) and pack is about 130 to 135 degrees.
Ray
Old 10-11-2005, 06:15 PM   #528
beidle99's Avatar
I temp my cells for the first few cycles of their lives and this pack all the cells were around 125 to 128 F
beidle99 is offline   Reply With Quote
Old 10-11-2005, 07:38 PM   #529
Trader Rating: 4 (83%+)
Send a message via AIM to letitroll
Any suggestions for CTX Cell Master?
I would prefer to use the step charge.
letitroll is offline   Reply With Quote
Old 10-13-2005, 08:47 AM   #530
So I've been out of the sport since the first run of GP3300's came out. I'm reading up on everything, but I can't seem to find straight info on exactly how to tray these new IB3800's. I still have my reactor 30, which sounds like it'll be ok for the initial discharge after a run. But after that, I can't seem to figure out if I need a .90 AND a zero tray or would it be ok to take the pack from the reactor 30 straight to say a Trinity zero tray?
I see there may be other, better options out there now. If I must get the integy 030 and other trays in order to keep these batteries performing well, I'm not opposed to it. But, I'm trying to get good performance without buying an entire hobby shop right off the bat. So, if the reactor is acceptable, I'm just looking for how to tray them after that step.
Thanks for any help!
Phil
habajaba is offline   Reply With Quote
Old 10-13-2005, 10:13 AM   #531
Danny/SMC's Avatar
Your current equipment is fine. The reason I reccomend the 0-30 is because it's very easy to use and discharges really fast.
Discharge your pack down on your Reactor after your run. Leave the pack alone until the next time you run it. Then before you go to charge it back up place it in your Trinity tray. Sinced the Trinity tray discharges slower than the 0-30 I would leave the pack in for 2 minutes then remove it from the tray and start charging it.
Old 10-13-2005, 10:22 AM   #532
litespeed-dom's Avatar
Danny,
I haven't invested in the 0-30 Integy tray yet, but I do have the Duratrax version at 25amp instead. Think it'll make a difference much discharging at 25 instead of 30? I'm also using your matched batts with Br00d labels.
Thanks!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 10-13-2005, 10:28 AM   #533
Danny/SMC's Avatar
The Duratrax tray is fine as it's the same as the 0-30. It does discharge a bit slower but is still fairly fast. Just put your pack in it for 1-2 minutes prior to charging.
Old 10-13-2005, 10:47 AM   #534
Danny do you suggest traying all the way down to .0 before a charge, if not what would be the impact on the pack.
Ramyuras is offline   Reply With Quote
Old 10-13-2005, 10:48 AM   #535
Danny,
Is your resoning behind the 0-30 tray the same as with using a 10amp discharge? So you would prefer to dump the cell at a high rate as is the 0-30 vs. say the Novak tray? Thanks.
Brian Anthony is offline   Reply With Quote
Old 10-13-2005, 10:55 AM   #536
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by Brian Anthony
Danny,
As stated in am earlier post by Danny, discharging at a lower amp rate, such as 10 amps, trains your cells to discharge at that lower amp rate which is no good for power.
And yes, he recommends the high rate discharge of the 0-30. The Novak tray is to equalize the cells not dump them.
koabich is offline   Reply With Quote
Old 10-13-2005, 11:28 AM   #537
Danny/SMC's Avatar
If you bring your pack down all the way to zero and leave it like that for to long you will lose some runtime. This is why I reccomend leaving it on the tray 1-2 minutes before you charge it.
The amp at which you discharge the pack down before you charge it isn't really critical. What your doing is bringing the cells down to a similar level. The Novak tray will work but due to its high cost you can get the same results with a resistor only tray for 1-2 minutes.
Old 10-13-2005, 11:40 AM   #538
theisgroup's Avatar
so basically
discharge down to .9 and store them. when you are ready to charge discharge each cell down to 0v and hold for 1-2min and then charge.
is that correct? with out using any brand or name of any product
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 10-13-2005, 11:43 AM   #539
rayhuang's Avatar
Originally Posted by theisgroup
so basically
not quite my friend. Discharge to 0.9 and then before charging again-1-2 minutes on a 20 to 30 amp discharge tray then recharge.
I use a combination of different discharge boards. When I use the INdi-whihc discharges at 20-I let them sit for a minute or two. If I use the NOvak Smart tray-I just leave them till the lights go out at 0.9.
I have deadshorted IB3800's, but i am tired of the deadshort hassles.
Old 10-13-2005, 12:33 PM   #540
Danny/SMC's Avatar
so basically
Leave your pack in a resistor tray for 1-2 minutes just before charging it. The cells don't need to be at 0V.
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
