Old 10-08-2005, 09:58 AM   #481
geeunit1014's Avatar
i sorry i meant 20 mV, i think it =.02 on a turbo
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-08-2005, 10:19 AM   #482
josh69162's Avatar
Send a message via AIM to josh69162
Originally Posted by Danny/SMC
.2is to high you need .02 for the entire pack.
IB cells get hotter than GP cells because they are built differently and use different materials. This is why you need to keep the peak detects lower.
Danny- I have a Millenium, and it can only go down to 4mV per cell, which if course is .024 for the pack. Is this sufficient? I have been looking around for a new charger- perhaps you could give me a list of "SMC approved chargers" I can look at. Thanks.
-Josh
josh69162 is offline   Reply With Quote
Old 10-08-2005, 12:19 PM   #483
Company Representative
Danny/SMC's Avatar
.024 should be fine. Most of my packs peak in the 140 range and I have had no issues plus that is the temp they peak at on a TM4.
There are many good chargers out there but I really like Competition Electronics chargers such as the Pitbull and T-35.
Danny/SMC is offline   Reply With Quote
Old 10-08-2005, 02:34 PM   #484
Regional Moderator
daniz24's Avatar
What about Team Muchmore/Orion charger? How many Amp and delta peak do you recommend? Thanks
daniz24 is offline   Reply With Quote
Old 10-08-2005, 04:15 PM   #485
josh69162's Avatar
I was looking at the MM Cell Master as well as the Orion Advantage, and after Danny's recommendation, I'm going to go with the Pitbull X3. I don't really need the motor run-in feature, and with the Pitbull, I still get the Turbo-35 quality charging. It has the step charge, which is a must for me, and it has more delta peak value selection. The Pitbull X3 can measure down to 2mV/cell, while the Advantage and Cell Master only go down to three. The discharge on the Cell Master is only 10 amps. If I need a 10 amp discharge, I'll run it in my car. All of them have long lockout, I believe. One thing that would be interesting to play with though, is the zero delta peak on the Cell Master. It's where if the voltage levels out for eight seconds or so, it terminates the charge. But when it comes down to it, the simplicity, cheaper price, and the high quality CE charging is what attracted me to the Pitbull.
-Josh
Old 10-08-2005, 05:02 PM   #486
Danny/SMC's Avatar
I'm sure the Muchmore charger works well and is a great quality charger. I have never been one to go for all the bells and whistles. I have been in RC racing since 1985 and my first good charger was a CE Turbocharger and it worked flawlessly and then I bought the T-35 and have never used anything else since then.
Old 10-09-2005, 07:07 AM   #487
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
I was just wondering if using my charger's discharge function (@10amps) is okay for my cells??? Or should I discharge my packs at a higher amp rate (30amps with something like a 0-30 discharger) and then equalise them on a Novak Smart Tray???
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 10-09-2005, 11:07 AM   #488
Danny/SMC's Avatar
I wouldn't discharge what is left in your pack at 10 amps this will train the pack to discharge at a lower rate and isn't good. Get an Integy 30 amp reactor which discharges packs down to 5.4 volts at 30 amps.
Old 10-09-2005, 05:17 PM   #489
Still Bill's Avatar
Danny,
If I'm running stock motors only, wouldn't I use a 20 amp discharge rate down to 5.4 volts?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 10-09-2005, 06:37 PM   #490
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by JRX-S Bill
Danny,
Why only 20 amps? Regardless of class if you buy batteries matched at 30 amps, wouldn't you want to discharge tham at 30 amps? Same for 35 amps...discharge them at 35 amps.
koabich is offline   Reply With Quote
Old 10-09-2005, 07:01 PM   #491
Still Bill's Avatar
Only if you are testing against the labeled numbers. Discharging a fully charged 6-cell pack at 30 amps makes it heat up in the area 170-180 F degrees. Even higher at 35 amp discharge. A real workout for em pups...
When I do use 30-35 amps for discharging these days is now only on a Spintec or Trinity Dyno Pulse. The pulsing type of discharge is kind to my packs...
Old 10-09-2005, 07:08 PM   #492
josh69162's Avatar
What discharges at 35 amps?
-Josh
Old 10-09-2005, 07:31 PM   #493
Hyperform Racing's Avatar
-Josh
Turbo 35
Hyperform Racing
www.Hyperform-Racing.com
[email protected]
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 10-09-2005, 07:38 PM   #494
josh69162's Avatar
Well, obviously that. I was thinking more on the lines of sub-$300 equipment. What kind of TRAYS discharge at 35 amps.
-Josh
Old 10-09-2005, 11:15 PM   #495
Alex_kipper's Avatar
Why not get a Indi Reactor 30 then get a much-more zero-v tray, that is what my current set is, and so far its working great
Alex_kipper is offline   Reply With Quote
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
