Old 09-18-2005, 07:21 PM   #376
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
APS Dyno Charge users- I found a 30 mv cutoff to work well with the Intellect cells. Peaked around 125-128 depending on each cell and its variance. This is at a 6 amp charge rate.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-18-2005, 07:25 PM   #377
Rick Worth's Avatar
Hey Ray, any of you guys using the Pitbull to stepcharge the 3800s? R.W.
Rick Worth is offline   Reply With Quote
Old 09-19-2005, 08:16 AM   #378
rayhuang's Avatar
Rick,
I did it on my Orion Advantage and I think it works well to get a full charge in the battery with good punch, but a cooler final temperature. Packs often peaked in the low 120 range instead of the higher 140 range. But instead of a triple rate charge-I have been charging with the lower peak detect instead.
I dont know if tis the way to go in stock. but I think it might have a greater impact in 19t and modified. A little more punch than chargin at 5 amps, but the longer runtime.
Ray
Old 09-22-2005, 07:08 PM   #379
I just got a new pack of ib 3800s and threw them on my matcher to check them out.
I heard one of the cells vent and immediately checked the temperatures. The were about 145 F. The cells got up to 180 F during discharge.
Is this excessively hot!?!?!
I charged at 5 with a .02 cut-off and the vent occurred on the charge, not a re-peak. Ambient temp is about 78 F. Discharge was at 30. All on a new TM 4/35.
Any help/recommendations? Thanks!
James
Yankey is offline   Reply With Quote
Old 09-22-2005, 07:26 PM   #380
cannon's Avatar
Trader Rating: 35 (100%+)
James,
I match IB3800's and only use a 0.01 peak. The 0.02 is too high. It will get the cells very hot. If you must use the 0.02 cutoff, then only use the Repeak/Discharge function.
cannon is offline   Reply With Quote
Old 09-22-2005, 07:42 PM   #381
Thanks for the reply. Do you re-peak when you use the .01 cutoff? Thanks!
James
Old 09-22-2005, 08:52 PM   #382
cannon's Avatar
Yes I use the cycle function which repeaks the cell.
Old 09-22-2005, 08:59 PM   #383
Still Bill's Avatar
Huh? Cycling and repeaking are two completely different modes.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-22-2005, 09:04 PM   #384
cannon's Avatar
Bill - read all the above posts carefully. We are talking about using a Turbomatcher and whether you simply use the Repeak/Discharge for a single peak or you use the cycle function which peaks, repeaks and discharges.
Please engage brain before typing
Old 09-23-2005, 01:34 AM   #385
Company Representative
Danny/SMC's Avatar
James
I'm not really sure why you would want to cycle cells that were matched on a TM4. I know that we use 35 brand new TM4/35 to do all our matching and we make sure the abient temperature is controlled and the TM4s are warm before we do any final cycling. Any changes in air temp or machine temp will result in different numbers. The best setup for IB is .01 using the repeak function. The IB cells take longer to drop back in voltage than other cells so this will create extra heat if a lower peak detect isn't used.
Hope this helps.
Danny/SMC is offline   Reply With Quote
Old 09-23-2005, 07:33 AM   #386
teamgp's Avatar
James
I cycle my IB3800's using a step charge of 7A to 3050mA, .5A to 3080mA & 6.0A to 3mV/cell peak on a CDR5000 and then discharge them at 30A. After charge, the temp is around 145F and then it increases to 170-180F at the end of the discharge. However, they have only vented twice. Once when I first put them together and cycled them and once recently when I cycled them after 30 days of storage. They have never vented during frequent use though.
The CDR5000 shows that they haven't lost any runtime or voltage and none of the individual cells performance has changed either.
Guy Hood
Sponsored by: Team XRAY / Team RC America / RB Products USA
/ Twister Tires USA / Maxy's Mods & Fuel / Parma PSE / Zubaks
Un-sponsored Shoutout: NexusRacing.com
*** 301 Raceway is my home away from Home ***
teamgp is offline   Reply With Quote
Old 09-23-2005, 10:43 AM   #387
mtveten's Avatar
Trader Rating: 27 (100%+)
The spintec batman will not make your new packs better. I have found that their conditioning process has helped to keep my newer packs @ their peak longer but they still degrade, it just slows the process.
Mark
mtveten is offline   Reply With Quote
Old 09-23-2005, 08:15 PM   #388
Danny/SMC's Avatar
Looks like the IB3800s are doing real well so far in Vegas with most of the TQ's in the stk/19t classes and in 12th mod.
This is the first major race where these cells are legal.
Old 09-23-2005, 09:04 PM   #389
rayhuang's Avatar
YAHOOOO!!!
Old 09-25-2005, 06:56 AM   #390
Hi guys! got to run my new IB3800 last night and must say they were awsome,they had good power all the way from start to finish.
Dont know if this will help or not but i charged a pack at 6cell 6amp 30mv cut of and the cells got very warm but nothing serious,so i then tried a pack at 5cell setting 6amp 30mv cut off and they came off a lot cooler and felt to have more power. Maybe worth a try!
Nick Simpson is offline   Reply With Quote
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
