Old 08-31-2005, 06:21 PM   #316
Company Representative
Danny/SMC's Avatar
Originally Posted by shortyboy
does SMC have a warranty on the intellect batteries?the reason being is i think i have a bad batch.i dont know the #s on each cell because its a stick pack.basically my older venom 3000nimh is running 2 1/2 times longer than my brand new SMC IB 3800nimh.is there anything i could do to try and save the battery or am i stuck with a bad battery?thanx
Sorry to hear of your problem. How long does it take for the pack to charge ? At 6 amps it should take 35+minutes.
Just send the pack back to us and make sure you include your return address.
Danny/SMC is offline   Reply With Quote
Old 08-31-2005, 10:53 PM   #317
Still Bill's Avatar
Danny,
This question does not apply to SMC batteries. Just batteries in general.
If I buy a matched pack of 3300/3600/3700/3800 cells and one out of six cells registers zero voltage while the others register 1.20-1.25V, should I assume that the one 0V cell is bad?
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-31-2005, 11:00 PM   #318
Danny/SMC's Avatar
Yes that cell has one of 2 things. It could have an open circuit which means it won't even charge or it could of self discharged because it has an internal short in the plates so it actually deadshorts itself. Try charging the cell and see if it will charge. If it does charge it will have less runtime than they others so if you don't plan on deadshorting your pack you should send the cell back and get a replacement.
Hope this helps.
Old 08-31-2005, 11:29 PM   #319
well my charger only goes up to 4.5amps.at 4.5A it took 27mins.if that number is not acceptable ill send my battery in.thanx
shortyboy is offline   Reply With Quote
Old 08-31-2005, 11:34 PM   #320
Still Bill's Avatar
Thanks Danny.
Old 09-01-2005, 12:06 AM   #321
Danny/SMC's Avatar
Does the pack get as hot as your other packs you charge with that charger ?
We just need to make sure it's the pack and not the charger.
At 4.5 it should take close to 45+ minutes to charge.
Old 09-01-2005, 01:26 AM   #322
yes, they both get hot.is charging at 6A manditory for the IB 3800?if so then ill need to buy a new charger.btw,my charger is a MRC 959
Old 09-01-2005, 03:04 AM   #323
DIMO's Avatar
hey dannt just wanted to know if this was a good way to treat my new ib 3600 matched packs
Charge batt 6amps 4mv per cell
After run discharge at 30amp to 5.4v for the pack(linear on a cdr 5000)
Slap em on the smart tray down to .9v per cell
wait two hrs,
Slap on the novak for 30sec again just to get em equalized good before chargin
DIMO is offline   Reply With Quote
Old 09-01-2005, 08:07 AM   #324
Danny/SMC's Avatar
Your charger should be able to charge the IB cells at 4.5 amps and it's not a must to charge at 6amps.
DIMO your method should work well.
Old 09-02-2005, 03:56 AM   #325
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
27 minutes isn't right. The MRC 959 is known to false peak (ask anyone) when it reaches a certain temperature. Try using a fan to cool down the charger.
Sean
Team Duratrax is offline   Reply With Quote
Old 09-02-2005, 05:49 AM   #326
The Teacher's Avatar
Trader Rating: 48 (100%+)
Danny/SMC, I'm about to get a few of the IB3800 packs and I'm looking to find the best way to charge them. Guys at my local track are saying step charging (...with the Much More cell master) is the way to go. Currently I have a CE GFX which does not have this feature. Is there an added advantage to step charging which makes it worth the money to buy the new charger???
The Teacher is offline   Reply With Quote
Old 09-02-2005, 08:51 AM   #327
John Tag's Avatar
Trader Rating: 42 (100%+)
Your the Teacher..you tell us
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 09-02-2005, 09:52 AM   #328
Danny/SMC's Avatar
In my opinion I don't see that step charging will provide better results than a linear normal charge. Use .02 peak detect with your GFX and you should be in good shape.
Old 09-02-2005, 10:19 AM   #329
Thanks Danny...
Tag, you should probably use one of those 15min analog wind up chargers......I have motor tips as well just ask.
Old 09-02-2005, 07:17 PM   #330
wvince's Avatar
Location: Tupperville, Ontario, CANADA - like tupperware but with a population of 450.
Smile
I use a GFX to charge my 38's. With a peak detect at .02 and the pack came right off a pure resistor tray (30 minutes or so), I can get about 2650-2700 seconds charge at 6A into them. That seems to be in line with what I've been getting with the GP3300's at about 2350 seconds. I like to monitor my charge times on all my packs closely. The IB's have been very consistant. Hope this helps some.
wvince is offline   Reply With Quote
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
