Old 08-27-2005, 09:41 AM   #256
Company Representative
Danny/SMC's Avatar
MR Jolly deadshorting is not something that needs to be done. The racers who are looking for that little extra edge will do it to gain that extra .01 -.02 volts. In the end if racers don't have chargers that can charge deadshorted packs then they should not deadshort.
Danny/SMC is offline   Reply With Quote
Old 08-27-2005, 11:07 AM   #257
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
That`s good
i like exploring all avenues when i sell things on & since the IB cells a quite new & there have been loads of conflicting reports on how good IB cells are or are not
i thought i will do some home work & testing my self
If i sell these i need the answers for the buyer!! so here i am
They have not been here that long in the UK , USA have had them & using them alot longer
so you guy`s have the answers
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 08-27-2005, 08:34 PM   #258
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
Whats the pros of having a higher IR and higher overall voltage straight off the charger?
Does having a higher IR increase runtime or punch?
Sean
Team Duratrax is offline   Reply With Quote
Old 08-28-2005, 01:39 AM   #259
Danny/SMC's Avatar
Actually you want your peak voltage to be lower not higher. On a TM4 an IB cell peaks at 1.50v so you would expect to peak around 9v but it all depend on the charger some read higher and some lower plus you need to factor in the IR of the bars and solder job. Extra resistance will most likely increase the peak voltage by a bit.
Old 08-28-2005, 02:02 AM   #260
DIMO's Avatar
Default Is this right
Can someone tell me if this is a good procedure to follow for ib 3600s
After race discharge at 30amp to 5.4v
Equalize on smart tray .9v per cell
dont use again for atleas 2hrs
DIMO is offline   Reply With Quote
Old 08-28-2005, 10:13 AM   #261
Still Bill's Avatar
After race, immediately discharge at 30amp to 5.4v
Equalize on smart tray to .9v per cell
dont use again for at least 2hrs
Dimo,
After getting the cells down to 5.4V with a Spintec (35A) or Trinty (30A) pulse-type discharger, I have two options:
1) If using again the same day, I let cells rest for 2 hours...During this time they recover slightly (voltage-wise).
2) If not using them the same day, to put them away and start with Step 3 the next time I use them.
3) Equalize to .9V on my Smart Tray (takes short time)
4) Immediately recharge after equalizing because I believe that equalizing starts the chemical reaction that helps the cells to accept more mahr.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 08-28-2005, 05:10 PM   #262
Jon Williams's Avatar
wvince - WAYNE, is that you??? The famous Wayne Vince visiting us from the Great White North?
Good to see you on here, homie. Stick around!
Jon Williams is offline   Reply With Quote
Old 08-28-2005, 07:03 PM   #263
Just wonder? Shall I get a new charger, ie., Orion Advantage or get more new matched packs. Because buying a new charger means I will be buying 5-6 packs less due to tight budget.
I currently using a LRP Pusar Comp. It is fine or sensible to get a new charger? Will Pulsar Comp do the job to charge the Intellect 3800?
Thanks.
MARKANO is offline   Reply With Quote
Old 08-28-2005, 07:41 PM   #264
rayhuang's Avatar
Thanks.
PUlsar comp will do a fine job. New batteries will have a far greater impact on laptimes than a Charger ever could. It might get your packs a IB's a bit warm-sp keep an eye on them. ONce they hit 120 or 130 deg-shut it off and race it.
ON the deadshorting-everyone has to understand it comes at some risk to those who dont take precautions and deadshort batteries in the correct way-which is the ONLY WAY. Does it increase the performance of a pack? 100% you bet it does. But is it worth it-in some ways no. Forget running, discharging and putting your pack away.
Now you have to unsolder the deadshort bar-let rest for 20 to 30 minutes, set long lockout on charger and/or change charge profile drastically, charge, watch for false peaks, race, discharge, tray for 45 min. to 2 hours depending on tray, resolder the deadshort bar. Is it worth it???? YOu be the judge!! Just be sure you know what your getting into. I can back this up with info off my T35, deadshorting loses 20 to 30 sec of runtime and adds about 0.012 voltage or more. Also-a deadshorted battery is still an a-main capable pack long into its life-whereas a non-deadshort batteries voltage and runtime both continue to drop and drop and drop and ir rise.
Ray
Old 08-28-2005, 11:15 PM   #265
Tempest2000's Avatar
Trader Rating: 21 (100%+)
Ray,
Not to get off subject, but it was good seeing you again at halo. Sorry you couldn't stay for the race. It was a TIGHT stock touring field. Good practice for Vegas and the Classic...
Later
Michael Skeen
Thunder RC
Tempest2000 is offline   Reply With Quote
Old 08-29-2005, 02:55 AM   #266
"Deadshorting"
Mr RayHuang
I know this question was ask many times. What is the best way to deadshort a battery pack is:
1. While battery is still on the discharge tray? If so, shall the battery remain in the tray while deadshorting?
2. Immediately after the battery remove from tray?
3. After the battery cool down after a race?
Old 08-29-2005, 08:29 AM   #267
I'm not ray, but I can help you out...
Deadshort while the pack is on the tray. I usually let the cells cool down in the tray till they are close to room temperature before I will deadshort a pack.
You can remove the pack once it has been deadshorted.
later
Michael Skeen
Thunder RC
Old 08-29-2005, 09:04 AM   #268
theisgroup's Avatar
acutallu, the "BEST" way would probably be the novak DS tray. I know that it prevents cell reversal. And some believe that DS still has the possibility of cell reversal.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-29-2005, 09:27 AM   #269
I've been deadshorting for years with no problems.
I use the integy 030 tray now with no problems.
The only time I've seen someone reverse a cell is when they tried to charge a pack that was deashorted and hooked the leads up wrong i.e. pos. to neg. etc.
later
Michael
Old 08-29-2005, 09:45 AM   #270
theisgroup's Avatar
this is a quote from the promatch site and I believe jeff to be knowledgeable about cells.
The problem with shorting out packs in series is that after discharging the cells i.e.: lights, resistor trays, or other discharge devices and then placing a short wire across the cells, some power is still left in the cells. How can you prove this to yourself? Take a pack and put it in whatever discharge device you want and remove them after you think they're completely discharged. Let them sit for a few minutes. Check the voltage in the pack. Is it still 0 volts. Absolutely not (unless you have a dead cell!) Why? Because the cells will regenerate after resting. They will do the same thing even with a wire soldered across. This can but won't always cause damage to the cell structure. The result could be anything from barely noticeable to drastic. It depends largely on how much energy is in the cells when the "dead short wire" is placed across the pack. The more energy left in the cells the greater the risk and extent of damage to the cell can occur. What is occurring is a reverse flow of current through the weakest cell. Basically many cells survive this abuse because of their durability but over repeated dead shortings the damage will begin to show on all packs
yang lai
Intellect 3800 LIPO vazzo Australian Racing 5 06-18-2008 12:59 AM
***SMC, Integy, Intellect, 3800-4200 battery sale*** RYAN BARNES R/C Items: For Sale/Trade 2 06-27-2007 12:05 PM
Intellect 3800 Battery Packs acsubie R/C Items: For Sale/Trade 11 02-15-2007 10:09 PM
FS: 4 Matched Intellect 3800 Battery Packs WogBoy Australia For Sale/Trade 5 09-24-2006 05:37 PM
LRP Pulsar 1 setting for Intellect Battery 3600, 3800 and 4200 rcmnx Electric On-Road 12 01-27-2006 05:05 PM
