Old 05-23-2013, 08:38 PM   #1
Default 1/10 Touring car 21.5T Blinky Setup
New to racing, I have come up with this combo to get me started.
Chasis: Schumacher Mi5
Motor Esc: Hobby Wing COMBO-XS6A
Servo: Savox 1251MG
Body: Protoform Mazda 6 Heavy
Charger: LRP Quadra Pro 2 Charger (On special $75)
Battery: Turnigy nano-tech 6000mah 2S2P 65~130C Hardcase Lipo Pack
Radio: DX3C DSM 3-Channel Surface Radio
Paint
Wheels
Lipo Bag
Have I missed anything?
Any comments would be great!
Cheers
Will1/10 is offline   Reply With Quote
Old 05-23-2013, 10:57 PM   #2
Suspended
I think you have it all covered, just as a matter of convenience, i would add a 2S balance lead extension, they are generally too short to get out of the lipo bag.
RogerDaShrubber is offline   Reply With Quote
Old 05-24-2013, 04:45 AM   #3
Heres a good combo for $70
http://www.rcmart.com/reventon-brush...Path=1560_1301
Yogi- is offline   Reply With Quote
Old 05-24-2013, 10:57 AM   #4
Trader Rating: 27 (100%+)
Servo: Savox 1251MG
Paint
Wheels
Lipo Bag
Cheers
Make sure your local track actually races 21.5 blinky sedan. Usually 21.5 motors are used in VTA, f1, or GT. it'd be a shame to buy that motor combo and then have to purchase a new motor to run in a class.
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 05-24-2013, 06:44 PM   #5
Suspended
Originally Posted by Yogi- View Post
Motor is not on the ROAR list, which could be a real issue for him if being on the list is a requirement for his club driving.
Old 05-24-2013, 07:47 PM   #6
ta04evah's Avatar
Plus avoid the Reventons like a plague, they have so many issues and are the only esc where you have to cut a sensor cable wire with certain brands of motors. That's why they are being sold so cheap.
With the Hobbywing motors for 21.5 blinky you'll want to start out with a roll out around the 62-65mm mark and then either increase it or decrease depending on the size & layout of the track. The Hobbywing 21.5 motors are a low revving motor but have a lot of torque to pull the high roll outs.
Cheers
Rob.
Castle Hill RC On Road Facebook https://www.facebook.com/groups/121817254587521/
FatBear RC Videos https://www.youtube.com/channel/UCjiAhwa-rk5Vas2rv5IBD4A
ta04evah is offline   Reply With Quote
Old 05-24-2013, 09:42 PM   #7
The hobby wing is combo is on the approved list , the club has plenty of 21.5 blinky cars racing.
What are you referring to here gearing?
Old 05-24-2013, 09:57 PM   #8
Suspended
In a way yes, rollout is the distance the car travels in one revolution of the motor, you use this figure in calculating the gearing to use, it is used more in foam tire racing where the tires change diameter as they wear. But can also be used when changing brands or even batches of rubber tires, which might be slightly different diameters.
Tire Circumference x Transmission Ratio x (Spur x Pinion) = Final Drive Ratio or Rollout.
What you are attempting to do, is always keep the rollout/fdr constant, which means changing pinions as the tires wear.
Old 05-24-2013, 10:47 PM   #9
Cheers
Rob.
I think that's the reventon pro that has problems with the temp wire ? On some motors. I my self haven't got this speedie ,I have a club stock with a reedy sonic.
Old 05-25-2013, 02:14 AM   #10
ta04evah's Avatar
Yes, or if you prefer to know what "FDR" to start at, starting at 3.3 would be a good point to begin.
There's some Apps both for Iphone & Android out there that allow you to easily calculate the FDR or Roll Out. You would need to know your cars internal ratio, spur gear size, pinion gear size and the outside diameter of your tires.
When trying out a new motor or combo it's always a good idea to run if for a minute or so and check the temperature of the motor. If the motor is getting very warm then you may need to put a smaller pinion gear on the motor & test again.
Am not sure what the internal ratio of a Mi5 is nor the constraints of the sizes of the spur & pinion gears that can be used in that car. It may be a good idea to see if anyone else has one and try and find out how small or big the gears that can be used in the car.
The club stock is the more reliable esc of the Reventon series as it relies more on the hardware of the esc rather then the software of the Pro, R & S versions.
Cheers
Rob.
