Old 05-30-2005, 09:19 PM   #16
dakrat's Avatar
Originally Posted by axel
not even fully on, i was about to place the bottom two and they were half way on, then i pulled it out immediatlet after i saw the spark , let's just say my hands were on them the whole time during this incident.
So you think there was damage?
i dont think u damage that cells, if u did, its very minimal. mine was worst, the solder melted and cells got seprated from the pack. u should be fine
dakrat is offline   Reply With Quote
Old 05-30-2005, 09:21 PM   #17
dakrat's Avatar
Novak recommend not using the dead short feature? , why not??
also any replies to my previous question would be Greatly appreciated.
almost every cell manufacturer/matcher out there dont reccommend this procedure. there too many topics about dead shorting in this forum. do a search
Old 05-30-2005, 09:24 PM   #18
axel's Avatar
thanks , what a relief.
axel is offline   Reply With Quote
Old 05-30-2005, 09:34 PM   #19
centax error!'s Avatar
it's sort of a disclaimer... you will find alot of different opinions about dead shorting. If your not sure about what your doing don't do it.
centax error! is offline   Reply With Quote
Old 05-30-2005, 09:46 PM   #20
axel's Avatar
Do you guys store your packs after traying them down to .9v? And before my heat should i tray them down to .1v then charge them? How does this plan sound for stock racing?
Old 05-30-2005, 09:48 PM   #21
dakrat's Avatar
tray em just before charging. .1v eehhh its up to u
Old 05-30-2005, 10:47 PM   #22
axel's Avatar
Help !!!!! my pmr cells now charge peak at 3330mah??!! they used to charge to 3800mah?!! well this might have been do to that i trayed them down to .9v for the first time...but still 3330!!?? maybe i should've trayed down to .1v or deadshort them to get max. mah...is this permanet?!!!
Old 05-30-2005, 10:53 PM   #23
post charge settings?
Old 05-30-2005, 10:55 PM   #24
dakrat's Avatar
u got it the other way, dead shorting will not help gain MAH.
Old 05-30-2005, 11:05 PM   #25
axel's Avatar
what will then?? this really sucks if my cells stay like this
Old 05-30-2005, 11:10 PM   #26
axel's Avatar
ch: 5amps
disch:10amps ( i know weak)
peak sensitivty: 5mv/c
dsch. volt.: 0.9v/c
then i trayed them to .9v,
first time they chraged at 3700 range then later to 3338!!
I have a duratrax ice
Old 05-30-2005, 11:22 PM   #27
axel's Avatar
Help??? i think i might have permantly damaged my cells...but how this tray do that?
Old 05-30-2005, 11:32 PM   #28
ch: 5amps
dsch. volt.: 0.9v/c
Your setting seems ok basically and I assumed you trayed packs to .9v before charging and discharged them to 5.4V/pack using your charger after every run after it has cooled down .How many times do you charge pack in a day? The MAH will reduce slightly as the # of charge increases per day but will get back after you give them a rest and charge again on the next race. Also try lowering your cut off v on the smart tray and see if the MAH increase. Does this happen to all your packs? I really don't mind what the MAH #'s says on the charger but if you're really crazy about the MAH look for someone who has a T35 or GFX and give your pack one cycle and take note of the runtime ( discharge time). Your pack is not damaged if the #'s are close to the label on the cells.
Old 05-30-2005, 11:45 PM   #29
axel's Avatar
well i'm worried becuase this was all within 2 consecutive cycles...i worry alot about mah beacuse it shows me how much longer i can use these cells...i cycled them 2 times today and 2 times yesterday...i hope your right about having them needing rest.
Old 05-30-2005, 11:55 PM   #30
don't cycle your packs if you don't really have to. Again don't be confused with MAH and actual runtime. It's the run time that you should worry about. I charged all my packs maximum of two times per day and my good packs only ones.
orion advantage (non lipo) novak smart tray novak millenium Valentin.H R/C Items: For Sale/Trade 12 11-16-2007 06:37 PM
JR R1, Novak Smart Tray, Novak GTX, Futaba S9451, Hellfire stock motors, plus more yauipop Australia For Sale/Trade 7 08-27-2007 03:56 AM
Integy Zero-Thirty Tray, Novak Smart Tray domo Australia For Sale/Trade 9 07-29-2006 05:34 AM
Novak smart tray and trinity 2.5 tray joerocket900 R/C Items: For Sale/Trade 2 12-12-2005 10:52 PM
Trinity absolute zero tray/ novak smart tray ALL APPROVED R/C Items: For Sale/Trade 9 10-14-2005 07:54 AM
