Old 06-11-2005, 12:16 AM   #46
rc-zombies's Avatar
[QUOTE=big_G]Like these?
.....QUOTE]
yup. very similar to those...
here's mine:
Old 06-11-2005, 02:47 AM   #47
Send a message via AIM to Somerwil Send a message via Yahoo to Somerwil
Hi guys,
I'm really interested in this thread because I just wanted to let some Dean plugs come over from America. Here in Holland we have nothing else but the Corally plugs, so we thought that the Deans were/ are probably better.
To clear up some thing about the Corally plugs:
This is the standard plug (straight, there's also a twisted laminates version)
This is the tube to mount on a wire
The tube on a battery
This is a plug with which you canot shortcut
This is the smaller variant. I use those in between the speedo and motor.
There is also an 1/18th scale solution:
Nearly everybody here uses these plugs and they work fine for me for some 12 years now. Never had a single problem using them, but I found it rather strange that this isn't a popular product in the US. For as far as I know, Deans is the biggest connector guy over there, isn't it?
I hope I helped you somewhat and I also wonder which of the connector is best for any rc-car application.
Gr,
Mike
Somerwil is offline   Reply With Quote
Old 06-11-2005, 02:56 AM   #48
Carbon_Fibre3's Avatar
i am thinkin about going to hard wiring soon, because with discharge trays its a pain in the @$$ tryin to shoe horn them in ..
i have been using corally connectors for past 4 yrs
Carbon_Fibre3 is offline   Reply With Quote
Old 06-15-2005, 11:01 AM   #49
You can bend a battery bar for some 90 degrees and place the tube on top of the cell using this bended battery bar.
Replace the wires in the picture with the Corally tubes. They will fit the discharge tray easily now (at least with my old Orion tray they do).
Gr,
Mike
Old 06-15-2005, 11:42 AM   #50
Kevin CBR's Avatar
Originally Posted by big_G
Like these?
What brand are these and do you know who caries them ? All I can find are the straight type from Eagle Racing or Corally here in So Cal. I would like the type where the male is a 90 degree like pictured.
Thanks.....................
Panda Performance / Nemo Racing top secret R&D lab hidden in a lush bamboo forest....
Scorpion Power Systems
Kevin CBR is offline   Reply With Quote
Old 06-15-2005, 11:44 AM   #51
rc-zombies's Avatar
Eagle has the "small" euro plugs that can be soldered at 90degs.
see the Integy website.
http://integy.automated-shops.com/cg...31105050952.fc
Old 06-15-2005, 11:51 AM   #52
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Default batt. drawing
Ive got a tc4 so soldering directly to the battery end is not an option. As I posted earlier, I just switched from deans. My batteries look somthing like the attached pic. Works wonderfully to me. I like the smaller euro plugs. Considering replacing my hard wired motor with perhaps a direct solder of euro plugs to the motor tab. Hmmm . . .
Old 06-15-2005, 11:56 AM   #53
rc-zombies's Avatar
the small euro plugs are really small (less than 1/2" long)...they can be directly soldered to the motor tabs. This is extremely helpful if you're running more than 1 class and switching motors all the time.
Old 06-15-2005, 01:22 PM   #54
How much current can those small euro plugs handle? A buddy at the track advised me not to use them for TCs because they couldnt handle the amp draw.
smojoe is offline   Reply With Quote
Old 06-15-2005, 02:13 PM   #55
big_G's Avatar
R/C Tech Charter Subscriber
Connectors in the pic are from ebay here
It's a UK supplier but I am sure he will ship worldwide.
The 3.5mm are the ones I use for batts etc (90 deg connection) but also he carries smaller ones which I use for motors.
Powers also do this type of connector.
big_G is offline   Reply With Quote
what is the best connectors? noobie Electric On-Road 29 09-21-2005 01:18 PM
Soldering batteries VS Deans Connectors? dmayhew25 Electric On-Road 13 07-19-2005 02:12 PM
T Connectors?? JP-NZ Rookie Zone 3 11-17-2004 08:37 AM
Electrically&Soldering challenged ISO 3-wire ESC & connectors Q and Tips&Tricks Tom G Electric On-Road 4 06-26-2004 09:37 PM
Dean connectors Richy89 Electric Off-Road 13 04-14-2004 12:19 PM
