Old 05-11-2004, 08:31 AM   #1411
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
Originally posted by Afro Puff
Question for y'all: can I use side by side packs for F201 or do I have to use stick packs?
if youre using the stock chassis, you can only use stick packs... but if youre using an aftermarket graphite chassis, i think you can use side by sides...
Racing is in my blood
Tommi Makkinen is offline   Reply With Quote
Old 05-11-2004, 09:57 AM   #1412
mtveten's Avatar
Trader Rating: 27 (100%+)
If you want to use sideX packs with your F201 stock chassis you will have to dremel out all the ribs in the batter compartement and put plugs on the batter. Having said that I would suggest leaving the chassis in tact and keep the car TCS legam so you can race it any track and participate in the TCS vrace program.
mtveten is offline   Reply With Quote
Old 05-11-2004, 02:13 PM   #1413
Afro Puff's Avatar
OK, thanks for the advice. Looks like I'll have to invest in some stick packs.
Ghetto Fabulous Racing: Not just ghetto, Ghetto Fabulous.
Team TYCO Jam Car: Independently controlled - acts as a moving obstacle!
Afro Puff is offline   Reply With Quote
Old 05-11-2004, 07:03 PM   #1414
RCGaryK's Avatar
Default Re: Re: f201 tires
Originally posted by cartmen34
99.9% sure they will not. Somebody correct me if I'm wrong, but I beleive the rims of an F103 are flat to accept glued on foam tires, while the tires for the f201 have a groove cut into them which lines up with a raised section of the f201 rim.
Plus, I think the width of the f103 rear rim is much more than that of the f201 tire...
The F103 tires are wider in back than the F201 tires, so they will not fit. The front tires are close, but again I think the F103 is wider. If you are just looking for the grooved slicks for an F103, Ride used to make them.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 05-11-2004, 07:08 PM   #1415
jackhammer74's Avatar
I just bought one of these, and by the way I love it. My question is, I was going through the TCS f201 rules and it states that you can drill holes in the chassis to allow for better motor cooling, has any of you guys done this already? I'm kinda hesitant because I've never drilled a plastic chassis before and I don't want to fudge it up, anyone got pics?
jackhammer74 is offline   Reply With Quote
Old 05-12-2004, 07:56 AM   #1416
no problemo bro.
Old 05-12-2004, 07:58 AM   #1417
havent bored out mine yet... havent had a heat problem bad enough to need the hole in the chassis yet... but try www.formula1-rc.com maybe the site can be of help... its been helpful to me...
Old 05-12-2004, 08:09 AM   #1418
RCGaryK's Avatar
What I did was dremel out the bottom of the chassis under the motor so it looked like the opening on a Surikarn. It helps, but the motor still gets way hot.
HorizonHobby.Com
Old 05-12-2004, 08:16 AM   #1419
GundamWZero's Avatar
Send a message via MSN to GundamWZero Send a message via Yahoo to GundamWZero Send a message via Skype™ to GundamWZero
I may be outa my league, but I own a Kyosho F1. When I had her running she was fast! Unforuunately, once you get a pebble in the rear diff, it is all over! I would like to see what Tamyia has that is great or should I get the latest Kyosho F1 kit? Also, it has become a PITA to find bodies for the Kyosho F1, That is why I want a Tamyia F1.
"People tend to get upset because they don't get what they ask for... then complain when they get what they deserve." - R.E.Jacobs
‎"We fight not because we hate what's in front of us...
We fight to protect whats behind us."
GundamWZero is offline   Reply With Quote
Old 05-12-2004, 10:03 AM   #1420
mtveten's Avatar
When drilling the chassis to improve heat disipation of the f201 I would advise against cutting a large section out of the chassis as this would signigantly decrease the strength of the part. For the best balance I would advise drilling maybe 5 holes about where the cooling vents and endbell rest approximatly the size of a body post. Please keep in mind that removing more material will improve heat disipation even more it will also allow the chassis to twist and flex more hampering the cars handeling.
Mark
Old 05-12-2004, 10:10 AM   #1421
RCGaryK's Avatar
When I did my chassis, there was no noticiable change in chassis flex. I was worried about it, but my concerns never came to life.
HorizonHobby.Com
Old 05-12-2004, 10:15 AM   #1422
rc-zombies's Avatar
To help cool the motor I installed the Evo clip-on motor heatsink.
Old 05-12-2004, 07:03 PM   #1423
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default MD2 Ball Nuts
Hi all
What is the best way to remove the Ball Nuts from the stock arms so I can use them with the reinforced ones?
rinkrat99 is offline   Reply With Quote
Old 05-12-2004, 07:34 PM   #1424
Ooj
Send a message via ICQ to Ooj Send a message via MSN to Ooj
rc zombies
I have used the evo 3 heatsink as well but I have found that it cannot fit it on when the aluminium motor guard is installed. Do you have the same problem?
Ooj is offline   Reply With Quote
Old 05-12-2004, 09:37 PM   #1425
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Default Re: MD2 Ball Nuts
Originally posted by rinkrat99
Hi all
I just put one of my hex drivers into the hole and kinda twisted them out. They came out pretty easily.
Turbo Joe is offline   Reply With Quote
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
