Old 04-01-2004, 08:38 AM   #1306
Hey has anyone tried the front oneways from techracing? What do you think about them? And how does the car handle on a medium bit surface with the oneway?
Nthegame is offline   Reply With Quote
Old 04-01-2004, 08:44 AM   #1307
Neil Rabara's Avatar
I use the oneway. Like all oneways in touring cars, you will need to change your driving style to take full advantage of it. If you let off of the throttle, the rear end will begin to swing around, however you can counter this with a setup change. My laptimes have increased compared to a TCS legal F201, but part of that also contributes to the elimination of the bump steer.
Neil Rabara is offline   Reply With Quote
Old 04-01-2004, 08:53 AM   #1308
RCsilly's Avatar
Location: Redford Mi. Trying to keep up with Tim Stamper
How do you remove the bump steer ?
RCsilly is offline   Reply With Quote
Old 04-01-2004, 08:58 AM   #1309
The easy way is to purchase the bump steering linkages from FPM racing from the Formula1rc website. The more difficult way is to try and invert the steering knuckle ball end, then reattached the steering linkages without binding up the suspension, steering linkage, and bellcrank.
Old 04-01-2004, 09:00 AM   #1310
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
There are a set of bent steering arms from www.formula1-rc.com
that will remove most of it. Not TCS legal....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 04-01-2004, 09:32 AM   #1311
RCsilly's Avatar
Thanks guys ,
I just finished my car , BAR / Honda , and will be racing it in a team series here in Michigan starting in May , hop ups allowed , spec brushs in a monster , spec battery , type A's , std or speed gears ,are the only requirments.
Can someone Email me a good starting setup for smooth asphalt , w/ stock shock pistons , and one with the #2 & #3 s.
thanks in advance
Bob
Old 04-05-2004, 05:55 PM   #1312
badboy's Avatar
Trader Rating: 14 (100%+)
newbie question?
Hi guys, hope you can help with me with my problem. There seems to be a "play/slop" in my front shaft. There seems to be a space where in I can move the shaft front and back. When on-power, it is also moving front and back. What can I do to stop this? Thanks.
slow is fast . . .
badboy is offline   Reply With Quote
Old 04-05-2004, 05:56 PM   #1313
badboy's Avatar
newbie questions?
Also, can i use the Reinforced Lower Arms as Upper arms?
jygs
slow is fast . . .
Old 04-05-2004, 07:00 PM   #1314
Default Re: newbie questions?
jygs
You can't take the slop out of the shaft unless you stuff the inside of the cup. But if you do that, you risk binding the shaft. You can try using the reinforced arms on top, I haven't tried it but there is one guy here that has. But he is a machinist, and has altered a few things to make it work.
Old 04-06-2004, 06:22 AM   #1315
badboy's Avatar
Neil : Thanks! Would you know what parts he altered? Also, what gearing would you suggest for a Tamiya Type T motor, the Stock Gears or the Speedtuned gears?
slow is fast . . .
Old 04-06-2004, 02:50 PM   #1316
StoneMan's Avatar
I'm hoping someone can help with a spring question.
I purchased the hop-up spring set with the 3 pairs of springs. Are the stock springs more or less firm than the performance set? I put #60 oil in the rear shocks, 1 hole piston and used a .3mm shim between the shaft and piston c-clip and installed the medium springs and the rear still feels soft. Any suggestions?
I run TCS.
StoneMan is offline   Reply With Quote
Old 04-07-2004, 12:27 AM   #1317
His car is completely altered. He made his own chassis, used a mono front shock suspension, took out the front bump steer, altered rear toe blocks so it's mounted in front of the wheels, changed rear shock mounts to increase angle, made his own carbon stiffeners, etc. That's all that I was able to see.
Old 04-07-2004, 12:29 AM   #1318
The stock springs are similar to the med springs.
Old 04-07-2004, 03:19 AM   #1319
F. Alonso's Avatar
Send a message via AIM to F. Alonso Send a message via Yahoo to F. Alonso
Default Tire Warmers
Hey guys,
Whats the story with Tyre Warmers?? Can you just use touring car tire warmers like the Speedmind Set or the Trinity Set to warm up the F201 Tyres???
I am really curious as its getting close to winter and we are already noticing that we have to go to our softest compound at race meetings.
Simon Feigl
RCRacer.com.au - Dedicated Australian Forum and Website
XRAY | HPI | Hotbodies | Hobbies Australia | LRP Electronics | Futaba
F. Alonso is offline   Reply With Quote
Old 04-07-2004, 07:33 AM   #1320
Default Re: Tire Warmers
You can use regular tire warmers. The F201 tires are smaller than touring car tires and will fit within the warmers.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
