Old 03-15-2004, 06:29 AM   #1276
rccarracer's Avatar
I'm looking to finally run a F201 after having mine sit so long in the box. Just wondering if there are any points about the car I should know before I run it??
Like mods to cure possible problems, etc....
rccarracer is offline   Reply With Quote
Old 03-15-2004, 12:25 PM   #1277
Neil Rabara's Avatar
Take out all the slop with o-rings, free up your drivetrain, practice.
Neil Rabara is offline   Reply With Quote
Old 03-15-2004, 02:37 PM   #1278
psycho's Avatar
Put a drop of blue loctite on the diff screw before assembling the diff. If you get the lightweight diff outdrives, they will not loosen like the kit diffs do. If you use the kit "nail" shock pistons, don't use the kit included shock oil. Pick up some nitro car diff oil in 3000 or 4000 weight. Mugen, Trinity and others sell the stuff. That should get you in the ballpark for most tracks.
psycho is offline   Reply With Quote
Old 03-17-2004, 06:16 PM   #1279
Old 03-17-2004, 06:20 PM   #1280
I was just board one day and decided to post a couple of pics.
Old 03-19-2004, 07:49 PM   #1281
badboy's Avatar
Trader Rating: 14 (100%+)
newbie questions?
tires : whats the equivalent of sorex 36, the Tamiya type A or B tires?
diff settings : which should be tighter, front or rear (for medium bite tracks)
lastly, what's the difference between the the blue and slver aluminum hex hubs? can i use the silver one being used by the 414m?
thanks guys!!!
slow is fast . . .
badboy is offline   Reply With Quote
Old 03-19-2004, 10:42 PM   #1282
Default Re: newbie questions?
thanks guys!!!
Tires
Neither, can't compare apples and oranges.
Diff
Front should be tighter.
Hubs
The silver are thicker than the blue. The silver is the same thickness as the stock plastic hubs, and yes you can use the hubs on the 414.
Old 03-19-2004, 10:57 PM   #1283
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i figured he was talking about the silver ones with the orings. my 414 came with those, and they are the same thickness as the stock blue evo's. they make a silver clamp type that works excellent, and they are 6mm, nstead of 4.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 03-20-2004, 08:39 AM   #1284
badboy's Avatar
Default Re: Re: newbie questions?
Originally posted by Neil Rabara
Tires
Diff
Hubs
thanks neil
1. when do you use type A or B tires?
2. what hex hub (silver or blue) is ideal for short technical tracks?
slow is fast . . .
Old 03-20-2004, 05:24 PM   #1285
Generally, the A tires are for cooler or cold weather. The B tires are for very hot weather. Unfortunately, there isn't an in between. The B tires take two or three laps to get to temp and start working. You'll have to find a good set up to compensate for the tires until they warm up.
The hop up silver hex's are of the same thickness as the stock plastic ones. For short technical tracks, it is prudent to use the smaller blue hex's, but you take out traction and handling. Try them out and see what happens. I race at Socal raceway which is a short technical track, and I use the silver hex's.
Old 03-20-2004, 06:35 PM   #1286
badboy's Avatar
thanks neil
slow is fast . . .
Old 03-22-2004, 09:40 PM   #1287
With so many experiments to try and eliminate the bump steer and still be legal, I have exhausted all means and have returned to the original setup. No matter what I would do, it would bind up something, change the geometry, or alter the engineering of the car. All of which are unacceptable.
Old 03-22-2004, 10:53 PM   #1288
psycho's Avatar
I remember doing the same thing when the car first came out. That's why I bought all the aftermarket hopups!
Old 03-23-2004, 10:07 AM   #1289
I also have bought numerous aftermarket products for the graphite car. I was refering to my TCS car. Too bad it comes with bump steer, it can be so much better.
Old 03-23-2004, 08:47 PM   #1290
TC3Racer67's Avatar
Send a message via AIM to TC3Racer67
I have a nice graphite 201 in the for sale section if anyone wants to check it out.
TC3Racer67 is offline   Reply With Quote
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
