Old 02-25-2004, 02:36 AM   #1201
badboy's Avatar
Trader Rating: 14 (100%+)
Gearing question
guys,
is it TAC legal to use TB Evo 64p spurs for the F201? thanks
slow is fast . . .
badboy is offline   Reply With Quote
Old 02-25-2004, 06:32 AM   #1202
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Default Re: Gearing question
Originally posted by badboy
guys,
Nope, the only gearing allowed arethe stock and hi-speed set.
20 pinion and 55 spur 23 pinion and 52 spur
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 02-25-2004, 09:23 AM   #1203
badboy's Avatar
Nova F1 Racerv : thanks!!! btw, can i ask what is the final ratio for the 55/20 and 52/23 gearing?
slow is fast . . .
Old 02-25-2004, 11:25 AM   #1204
Neil Rabara's Avatar
I'm not Nova F1, but here are the FDR's:
55/20 X 2.6 (IDR) = 7.15 FDR
52/23 X 2.6 (IDR) = 5.88 FDR
Neil Rabara is offline   Reply With Quote
Old 02-25-2004, 02:19 PM   #1205
Dang right you not me....
badboy, see above... Neil is more knowledgeable on this subject than I am....
RC Tech member #11
Old 02-27-2004, 03:30 AM   #1206
Frank McKinney's Avatar
Default Question on option parts compatability
'ello guys,
I'm looking at buying some parts for my F201 (currently not modded at all) and want to check out the compatability of the parts I'm planning to get. If someone can help me out I'd appreciate it!
Here's what I'm planning to get:
TAMIYA
2 diff sets (#53521 should be the ball diffs, right?)
racing spring set (should I get two sets?)
alum rocker arm sets f & r
universal sets f & r
ltwt prop joint set (if there are better options for these let me know)
ltwt counter gears (if there are better options for these let me know)
reinf. prop shaft (if there are better options for these let me know)
3 RACING
carbon chassis kit
TECH
adjustable motor mount (this is the main thing I'm wondering about parts compatability)
TOBEE
threaded shock bodies
FPM
carbon cross brace system
alum. rocker arm brace kit
4 prs alum a-arms
spur gear brace set
SQUARE
spur adapter (this should let me use 64-pitch spurs, right?)
So does anyone see any glaring or not-so-glaring incompatabilities?
Obviously I don't plan on racing this in TCS series I just want something durable that is more tunable than the stock kit, and looks cool too. I'm planning to get other stuff too like body sets and Ride tires but of course those don't have compatability issues.
TIA
Minimal signature to save screen space! Big sigs suX0r
Frank McKinney is offline   Reply With Quote
Old 02-27-2004, 04:06 AM   #1207
utieh's Avatar
I am selling most of those parts
look in my signature.
utieh is offline   Reply With Quote
Old 02-27-2004, 04:18 AM   #1208
I don't see your sig and it's not in your profile, can you PM me what you have?
Old 02-27-2004, 11:20 AM   #1209
psycho's Avatar
Frank,
I'd skip the rear universals. Just unnecessary cost, imo. Use o-rings in the half shafts and outdrives and you won't throw the rear bones. I have the Tobee Craft shock bodies and I honestly would not recommend them. Granted, that I've had them for two years, but they rub on the shock shaft. Since they're alum, they rough up the shock shaft and aren't very smooth after a while. I'd go with the Tamiya alum shock bodies instead. They use preload spacers, but they are a lot smoother. I would also suggest the FPM anti-bumpsteer front tierods. Not sure if you left this off or didn't think about it, but I would also get a teflon shock piston set. Tamiya's set comes with a one hole and a three hole piston and Square's comes with a two home piston. I use the Square f/r set on my "club" car and Tamiya three hole pistons on my TCS car. Finally, I'd get 3 or 4 packs of 5Xwhatever shim sets. Tamiya and Kyosho have them in a set with 0.1, 0.2 and 0.3mm thickness and Yokomo has a set with 0.05, 0.2 and 0.3mm thickness shims. You'll need them to remove the slop from, uh well... everywhere.
Hope that helps. If you haven't already, check out www.formula1-rc.com for setup advice. Good luck!
psycho is offline   Reply With Quote
Old 02-27-2004, 12:04 PM   #1210
lbckevin's Avatar
Trader Rating: 91 (99%+)
Frank,
Check out what Psycho recommends ...That web site helped me alot.
Kevin
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 02-27-2004, 01:55 PM   #1211
Default Re: Question on option parts compatability
Originally posted by Frank McKinney
'ello guys,
TAMIYA
3 RACING
carbon chassis kit
TECH
TOBEE
FPM
4 prs alum a-arms
spur gear brace set
SQUARE
TIA
You don't need the Tech motor mount, the 3Racing chassis kit comes with one. The Tobee Craft shocks don't work well with any type of piston. Don't get that either.
Old 02-27-2004, 02:06 PM   #1212
Kryptonite's Avatar
I recommend to get the Tamiya Reinforced A-Arms instead of the FPM A-Arms. Tamiya rein. A-Arms are very durable, light & less expensive. Also, you can use the stock Rocker Arms instead of the aluminum. I don't see any big difference in performance between the stock & aluminum.
Good luck!
Kryptonite is offline   Reply With Quote
Old 02-27-2004, 02:59 PM   #1213
psycho's Avatar
You'll get much more actual suspension travel with the FPM arms, which translates into more mechanical grip. The reinforced Tamiya arms are a huge improvement over the kit arms, though.
Old 02-27-2004, 05:37 PM   #1214
badboy's Avatar
Neil Rabara & Nova F1 Racer : thanks guys.
slow is fast . . .
Old 02-27-2004, 10:34 PM   #1215
Really? How so?
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
