Old 02-17-2004, 11:40 AM   #1171
psycho's Avatar
I did say that I didn't have any experience with that motor!
psycho is offline   Reply With Quote
Old 02-17-2004, 12:22 PM   #1172
Neil Rabara's Avatar
Default Re: Question about F201 Setup & Motor Timing
Originally posted by hemi426
Another question: Motor is an Tamiya Acto Power Blue. Does anyone know the best timing for this motor?
What are the specs for this motor? If it has adjustable timing, then the motor itself maybe questionable to put in the F201.
Neil Rabara is offline   Reply With Quote
Old 02-17-2004, 12:49 PM   #1173
hemi426's Avatar
Tamiya Acto-Power Blue, Number 53154, 17x2 Turns, rebuildable, timeable
This is the Motor most people use in their F201s during the TEC (Tamiya Euro Cup). It has a lot of torque. Currently my motor has a timing of 5 degrees.
Why should it be questionale to use such a motor in the F201? I recommend using the alloy motor mount and the aluminium motor guard (acts as cooler), but nothing else is required.
Hemi
hemi426 is offline   Reply With Quote
Old 02-17-2004, 03:24 PM   #1174
psycho's Avatar
Here in the US, we run with 27T motors (ROAR Stock.) You should be able to run a lot more timing than 10 degrees and the motor should have more rpms. Is the zero mark on the can truly zero degrees of timing? I have a feeling that it has some advance where the can is marked zero. You really should be able to go as much as 36 degrees of timing. Not that you would necessarily want to run that much, but if you really need the rpms, it is possible. I would check if it really is zero degrees timing advance at the zero mark. The easiest way to do this is to use a power supply that shows you the amp draw. As you reduce the timing advance, you will hear the rpms go down and the current draw will also go down. Eventually, you will reach a point where the rpms continue to go down, but the amp draw will go back up. The point where the amp draw is at it's lowest is zero degrees timing. From there, I would try the motor with 24 degrees (you may need a timing jig for this) and see how it goes. Again, not having any experience with that motor, I don't know how it will go, but I would expect the overall performance to be better than at 10 degrees with moderate comm and brush wear.
Old 02-17-2004, 04:00 PM   #1175
Hardriven RC's Avatar
Hemi,
If you need some advise in German, go to the Tamiya Germany site and ask the question to Uwe Reinhart. He is the Tamiya guru in the west division of the German Tamiya Challenge. Tell him you got his name from me. He'll help you or can get you in contact with someone closer to home to help you further.
Best Regards
Roy
Hardriven RC is offline   Reply With Quote
Old 02-17-2004, 07:12 PM   #1176
Even with the aluminum motor mount, the heat generated in the motor area will warp, in effect change the characteristics of the car. Unless you have an adjustable motor mount, you can gear the motor so that it runs cooler. If it is the motor you guys use, then this conversation is mute, we can not say much other than practice and find the timing that allows you run time, and power.
Old 02-17-2004, 11:13 PM   #1177
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
hi guys... i am trying to setup a couple F201s for asphalt. should i use the 1 or 3 hole pistons?i have access to either. i read Juns setup, and am heading toward it now. it says 3000 wt. oil? or is that supposed to be 300?and for hot outdoor running, are the B tires the most suitable? sorry for all the q's, but i am going to the TCS in Memphis in july, and have no idea where to start. thanks for any help!!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 02-18-2004, 12:16 AM   #1178
Originally posted by psycho
The "standard gear set" is 55/20 (7.15:1.) I think the high speed gear set is 52/23 (can't remember.) The metal diff outdrives are the standard ones. I'd get the lightweight ones if I were you. I have them on both of my cars. If you use the kit diffs, put loctite on the diff adjustment screw and the grub screw of it will back out taking away drive to the wheels. If you don't use loctite, as you walk back to your pit mid way through your main because you lost drive, you'll be cussing and wanting to throw your car at me or Chris for getting you excited about it in the first place.
Oooo can I play?
Yeah you just be quite psycho.
Sydewynder is offline   Reply With Quote
Old 02-18-2004, 04:16 AM   #1179
Tamiyadriver,
As far as oil is concerned, i would go for soft 300 in front and the heavyest you can find for the rear (100wt). I know this sounds daft, but the entire car is daft!. Also try using exessive camber in front and rear to generate more grip in turns.
Regards
Old 02-18-2004, 09:27 AM   #1180
You'll find that the one hole pistons give more dampening than the three hole pistons. The holes themselves are quite large allowing good flow of oil, so with the 3 hole piston installed the shock feels like the stock nail type piston. Furthermore, the inside of the shock body is polished for smooth operation. You won't have any trouble with binding. For hot outdoor running, you will most likely have to go up in oil wt, but you can't determine that until the time of the race. Right now, it's not a good idea to try to set up the car for a race in July. Depending on track temp, the B tires work well if the asphalt is extremely hot (100degF +), but they take a lap or two to get to operational temperature. As far a Jun's setup, I tried it and discovered that the dogbones/universals kept coming out of the outdrives. I shortened the track width and found a nice medium between Jun's setup and the stock setup in the kit.
Old 02-18-2004, 11:42 AM   #1181
psycho's Avatar
Sydewynder
So, are you gonna drag your butt out and race with us this year? Don't give me that crap about being retired.
Old 02-18-2004, 12:59 PM   #1182
Suspended
Trader Rating: 28 (100%+)
Hey Neil!
In the setup you sent me,what weight oil front and rear are you using?
racenut123 is offline   Reply With Quote
Old 02-18-2004, 01:10 PM   #1183
Originally posted by racenut123
Hey Neil!
Stock weight, yellow.
Old 02-18-2004, 01:17 PM   #1184
Suspended
Your the man!
Old 02-18-2004, 09:29 PM   #1185
Your the man!
No prob, let me know how the setup works with your driving style.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
