F201
#977
Originally posted by RCInfinity
I didn't have problems mounting my set. The play was the factor. It's almost like the balls were too small.
The ones from formula1-rc?
#978
My Tuned Chassis Kiy finally came in at my LHS, picked it up tonight. Lots of pretty blue parts!!
#979
hey newracer, can you please list the part numbers and quantities of the hop ups you got in the kit? I have heard heard that some people have not being getting all the parts that were listed earlier in this thread!! I am just a little worried because I am about to buy 2 tuned kits
#980
Carbon fiber body set, no wings just body
53515 Racing spring set
53567 53568 low friction damper piston set, front and rear
53513 turnbuckle set
53637 reinforced lower suspension arms
53522 x2 universal shafts
no part #'s on the following, all are blue ( I think that's why the parts #'s are blacked out)
x2 Aluminum damper cyclinders
aluminum body post set
fluorine coated 0.6 aluminum pinion (not blue)
x2 aluminum locker arm set
aluminum motor mount
aluminum motor guard
Last night I ordered:
Titanium screw set
lightweight propeller joint set
another spring set
Still plan on getting:
lightweight diff outdrives
re-inforced propeller shaft
Titanium screw set
another spring set
#981
Thanks newracer, you have confirmed the same hop ups as what my friend has got. It seems that you only get the hop ups that you can see on the outside of the car......i.e theres no upgrades to the internals such as lightweight shafts, gears and outdrives.
#982
nope but fortunatly most of the drivetrain hopups are pretty cheap. the diff outdrives are the only costly drivetrain hopup at $18 a pair
#983
F1RL Racers,
Great job today, nice to see all of you out there at Round 1 at the wonderful Tamiya America Raceway (Thank you Tamiya! ) Good clean racing everyone, a lot of great clean passes and great starts. It looks like everyone had a great time
Remember, round 2 will be back at Tamiya next Sat. I will post the result on the www.f1rl.com website as soon as possible.
Steve Wang
Steve Wang
#984
What do you guys think of the bearings in the f201 kit? Any tips on maintenance and prep?
I have an evo 3 original and if the f201 bearings are the same ill be upgrading to rubber sealed ones like on the evo surikarn. Ive found that the tamiya blue rubber sealed bearings a lot better in the areas like wheel hubs and diff outdrives......anything that can get clogged up with dirt
Is there any need to upgrade with the f201?
#985
Ooj
I don't see any reason to replace the kit bearings. I've raced 2 seasons with my F201 and haven't had any bearings go bad. I tore the car down at the beginning of this season and cleaned them out, but other than that, I have had no problems with them. As far as hopups go, the main thing is don't glue up the kit tires. The kit tires have very little grip and wear very fast. Get some Tamiya Type A or Pit Shimizu Hard compound tires. If you use the kit "nail" pistons, run Mugen 3000 weight silicone diff oil instead of standard shock oil. You can't get enough dampening with shock oil. Put some blue loctite on each diff screw when you assemble them and that's really about all that I would consider must do's. I would get a Tamiya High Torque Servo Saver rather than using the kit one, but the kit one will get you started.
#986
Hey Steve,
Look like Rod and I will run F201's next Saturday. I hope the invitation is still avail. to race with the F1RL.
George
The word around the pits was it went well, and even the non-competitors really enjoyed watching the show.
George
#987
I enjoyed watching, despite keeping one eye on my car.
#988
Originally posted by SpeedTech
F1RL Racers,
Steve Wang
F1RL Racers,
Steve Wang
I look forward to see the Canare brothers in the mix. I also learned some members plainly did not know about it, but I'm sure they will catch up.
#989
Yay, open wheel sedan racing...err I mean f1 racing. I look forward to this weekend's race and I'll drive with some really hurting equipment but it's all good and all fun.
Now somebody do the raindance!
