Old 10-28-2003, 12:32 AM   #931
King-G's Avatar
Send a message via ICQ to King-G
Correct Neil..use o-rings or the tamiya shims under the shock piston to limit droop..
I only use the pushrods to finetune rideheight...
King-G is offline   Reply With Quote
Old 10-28-2003, 10:58 AM   #932
Neil Rabara's Avatar
The only problem is range of motion. The shock bodies aren't that deep, so with o-rings in there movement is even more restricted.
Neil Rabara is offline   Reply With Quote
Old 10-29-2003, 12:29 PM   #933
Gavin, when are you leaving for Japan?
Old 10-29-2003, 03:44 PM   #934
King-G's Avatar
under 3 weeks!!!!..eeeik!
having not raced on carpet before it will be interesting, but I have raced plenty of high grip tracks (VHT coated)...
I am really looking forward to the challenge.
has anyone here played with inserts for the F201...
my winning setup included beveling the front inserts profile, to do this I trimmed the corners from the front inners, and then smoothed the edges using a soldering iron, It kinda sealed the foam, and gave me an almost moulded like finish..
works really well for tight tracks, requiring extra steering / mechanical grip..allows the sidewalls to conform a little more, rolling around...(i got the idea from Michelin)
lol
Old 10-29-2003, 03:48 PM   #935
King-G's Avatar
I found limiting the shocks travel to have a positive effect, there is still ample travel, I checked by pusing the chassis down to contact the deck, and also by rolling the chassis side to side, the limited travel helps the car to corner flatter, and carry more cornerspeed.
There are situations where this wouldnt be desirable, either really bumpy or low traction, but it has worked really well on the tracks I have tried so far.
I use one thick black o-ring, with another thinner and smaller diameter o-ring, closest to the piston as it doesnt restrict oil flow by blocking the piston holes.
Old 10-30-2003, 10:46 AM   #936
RCGaryK's Avatar
HELP!!!! Raced the car for the first time on carpet using George's setup, and the car had waaaaaaaaaaaaaay too much front grip. I'd breathe on the wheel and it would spin out. I put the stabilizer back on, but then it was waaaaaaaaaay pushy.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 10-30-2003, 11:29 AM   #937
gtypecanare's Avatar
Hmmmm....Carpet. Sorry Gary can't help ya on that one,but those are the numbers that seem to work well on the black stuff.
gtypecanare is offline   Reply With Quote
Old 10-30-2003, 03:34 PM   #938
RCGaryK's Avatar
Well, my sedan and F103 setups are normally similar from carpet to TA, so I figured the F201 would at least get me in the ball park. Must go faster....
HorizonHobby.Com
Old 10-30-2003, 03:39 PM   #939
Hmmm... I just looked at the pic of your car, and I see you have teh FW-24 body set, that front wing will cause your car to have tons of oversteer. Try less camber upfront, or more camber or toe in the rear. I hope it works for ya.
Old 10-30-2003, 03:46 PM   #940
Try the Ferrari body/wing set, or stiffen up the front.
Old 10-30-2003, 04:19 PM   #941
PW
PW's Avatar
Send a message via AIM to PW
Hey Guys.....Wanted to let everyone know that Schumacher is blowing out all of the Cross/Take-Off F201 hop-ups. All items will be 1/2 off!!!!!!!!
E-mail for parts listing [email protected]
Here is an example:
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 10-30-2003, 04:21 PM   #942
Here is an example:
Hey Paul
Is there a website where you have all the parts?
Old 10-30-2003, 04:28 PM   #943
RCGaryK's Avatar
I have a ferrari also, I just need to paint it up. I'll try that next week.
HorizonHobby.Com
Old 10-30-2003, 05:32 PM   #944
PW
PW's Avatar
Hey Neil....You may find some of the items at www.rc-cross.com but not all of them.
Paul Wynn
Old 10-30-2003, 05:43 PM   #945
Hi Paul, thanks, I'll check it out.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
