Old 09-12-2003, 08:30 AM   #706
Trader Rating: 69 (100%+)
Originally posted by Que
Will a brushless motor fit into a f201??
novak's brushless will. came upon this link in the brushless forum...
http://www.teamnovak.com/install_pics/index.html
marvi is offline   Reply With Quote
Old 09-13-2003, 06:38 PM   #707
lazyboy's Avatar
Send a message via AIM to lazyboy
Post
how easy is to tune one of these cars and how do they drive compared to a touring car? i race 1/10 touring and well im thinking of getting one of these. what are parts for the this car that i should get for if before i race it (hop-up parts)?? oh yea and what motors fit in them???
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 09-14-2003, 09:57 AM   #708
Neil Rabara's Avatar
Tuning the car is similar to any car. If you intend to run in the TCS, only Tamiya hop ups are allowed. The car drives differently than a touring car, as you might expect. If you are contemplating getting one, drive somebody's first and get a feel for it.
Neil Rabara is offline   Reply With Quote
Old 09-14-2003, 06:57 PM   #709
lazyboy's Avatar
Post
k thanks ill do that.
Random Guy
FT B4
Trackside hobbies
Old 09-16-2003, 07:28 PM   #710
wrxmy99's Avatar
Default unequal turning
Hi all
Took my F201 out for its first race on Sunday and had some steering dramas. Its set up pretty standard i.e. - 1 camber all round, 0 toe on front 2 toe in on rear all on setup gauges but....
Left turns are beautifully balanced, right turns are a nightmare, the car runs wide and understeers in through and out of the corner seemingly regardless of entry speed.
Nothing that I can see that is out of whack.....any ideas?
Cheers
Andy
wrxmy99 is offline   Reply With Quote
Old 09-16-2003, 07:48 PM   #711
INFERN0's Avatar
it is not uncommon for the plastic chassis to be tweaked from either building or just driving and hitting a bump wrong.Although most of the time this does not make a drastic change it will make subtle changes especially noticeable if you run the stabilizer plate.I would suggest getting a tweak station, measuring left shocks compared to right shocks at full extension to make sure they are equal, measure the left to right rods to the locker arms with calipers as well to ensure they are equal length.once you know the suspension is equal left to right set the chassis on a level surface with no tires, check to see if it rocks corner to corner in any direction.
After determining either way if the chassis is suspect make efforts to straighten if needed by giving it a bit of a twist, put the wheels on and sit the car on a tweak station to see if it levels out.
Level the car with the rods not the shocks.
Once this is done ensure the camber and toe settings are good and equal left to right and then finally re-check the tweak before trying.
Enjoy.
Proudly driving for Kyosho America, Team Maclan and RC Pitstop
INFERN0 is offline   Reply With Quote
Old 09-17-2003, 06:37 AM   #712
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Default Re: unequal turning
Originally posted by wrxmy99
Hi all
Cheers
Andy
I had the same problem, here is how I fixed it.
I put the car on the HUDY set system and found out my servo was not centered. Left turn: 22 degrees, right turn: 12 degrees.
Changed the servo to a better quality one, and this will solve your problems.
I had made a lot of changes to the rear as well and once I changed the servo I also made some adjustments to the rear.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-17-2003, 11:19 AM   #713
SpeedTech's Avatar
wrxmy99,
check the ride height left and right. A lot of times the ride height could be off just a 1mm each side and can seriously affect the way the car handels.
You might want to also check the droop on the car and shock length. This car is very sensitive to changes on those adjustments as well.
(Oops, I just read Inferno's post, basically what he said )
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 09-17-2003, 11:22 AM   #714
psycho's Avatar
Did the steering problems happen immediately or after a crash? The lower front bulkhead where the lower arms mount tends to bend/break pretty easily and this will cause this problem.
psycho is offline   Reply With Quote
Old 09-17-2003, 11:29 AM   #715
Or a non working diff.
Old 09-17-2003, 05:15 PM   #716
wrxmy99's Avatar
Thanks all.
No crash involved, it started like this straight out of the box.
I'll recheck setup and see what I find..
Old 09-18-2003, 10:11 AM   #717
rcfiend's Avatar
Trader Rating: 30 (100%+)
I just purchased the Tamiya adjustable pistons for the F201. They come with 1 and 3 hole pistons. What pistons are you guys using front to rear and what shock oil should I start with.
rcfiend is online now   Reply With Quote
Old 09-18-2003, 01:35 PM   #718
Claydoh's Avatar
Send a message via AIM to Claydoh
I have 3 hole with 100wt and gold springs f/r
Does anybody know if the new reinforced arms will include the cross brace like on the TRF version?
Claydoh is offline   Reply With Quote
Old 09-18-2003, 05:26 PM   #719
The photos don't show alot. The arms themselves will be sold separately.
Old 09-21-2003, 12:14 AM   #720
I just saw a rcfiend's 3Racing F201 graphite conversion. I am absolutely amazed at the car and the way it looks. I'm curious if any of you guys can talk about how it handles compared to the stock chassis.
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
