Old 08-27-2003, 06:41 AM   #661
ozone's Avatar
ernestf: cool... sat can only make it in the mn... normally wat time u reach there??
ozone is offline   Reply With Quote
Old 08-27-2003, 08:06 AM   #662
ernestf's Avatar
Send a message via ICQ to ernestf
normally, i visit nacos on Sat morning and leave around 3pm ..... not the coming 2 weeks tho.
hope to see you !
ernestf is offline   Reply With Quote
Old 08-29-2003, 11:54 AM   #663
Neil Rabara's Avatar
Originally posted by ozone
yup... definately... i guess u must b using the Bs... how is it compared wif type A? Using stock inserts??
The Type B's are a harder compound, basically for warm to hot climates. Depending on the temp, it takes a few laps to get up to operating temperature. In a main event, those few laps can cost you a win. In our climate here, there is a mix bag of drivers that like the B's, and others that like the A's. Alot of it also depends on driving style.
Neil Rabara is offline   Reply With Quote
Old 08-31-2003, 05:56 PM   #664
King-G's Avatar
Send a message via ICQ to King-G
I was measuring up some GP 3300's last night with calipers...trying to figure out if they will fit the f201 in stick pack formation, I see it being a tight fit length wise, has anyone tried>?
If its a real close fit I wont use the end caps...but Im not wanting to mod the car in any way to ensure its TCS legal.
wanting to build stick packs from some good GP's, to get best possible voltage.
anyone done any research as to which cells would be best suited to F201 tcs?..
my thoughts would be either Ultra Metals, or Gen2 GP's,
others have suggested Nicad's 1700-2400's charged at a very high amp rate, but me thinks the GP's and ultra's would have better average voltage through to the finish of the run. plus they can be run 2-3 times in the day, where as the Nicads I would need 4-6 packs.
give us your findings guys.
King-G is offline   Reply With Quote
Old 09-01-2003, 02:22 AM   #665
BagofSkill's Avatar
King G,
Are you running F201 now?! Do we have to guess which shell?
Have you fitted anything purple yet?
BagofSkill is offline   Reply With Quote
Old 09-01-2003, 05:59 AM   #666
wrxmy99's Avatar
I'm running GP 3300 stick packs with no size worries at all. With end caps and plastic sleeve.
with the st 540 they take about 15 minutes to dump!
wrxmy99 is offline   Reply With Quote
Old 09-01-2003, 05:56 PM   #667
King-G's Avatar
thanks wrx..
I wanted to be sure...
did you build the packs yourself??..
and to be sure, are you sure they GP ?..I wasnt aware of any matchers doing GP stick packs. ive only seen sanyo 3300 in stick..so I assume you built them yourself...did you use the trinity stick pack kit?
the problem I forsee is the length of the GP cell as the positive button on the cell protrudes, I measured one cell, and X 3 and I had 2 mm spare so with the end battery bar, and the joiners for the cells there may not be room for the plastic end caps to fit
Old 09-01-2003, 05:57 PM   #668
King-G's Avatar
as for hopups, lets just say it has enough....=)
waiting for the new stiffer arms though, the kit items bend like umm well plastic..and im sure they break real easy.
Old 09-01-2003, 07:54 PM   #669
ozone's Avatar
thanx again dude... well i better try to get hold of some type B...
ernestf: drop me a pm when u goin to track...
Old 09-01-2003, 09:35 PM   #670
ernestf's Avatar
i am not in SG now, will visit Nacos track on second week of Sept.
so you think type B tires work in Nacos ? i am now using Pit ....
Old 09-01-2003, 10:55 PM   #671
There will need to be some suspension changes with the new arms.
Old 09-01-2003, 11:57 PM   #672
black-knight's Avatar
R/C Tech Charter Subscriber
ohhh TCS F201 style will be a battle... it will be intersting to see what bodies and paintjobs people choose!
Black-Knight - None shall pass!
www.nbhc.com.au - www.facebook.com/smaracing
black-knight is offline   Reply With Quote
Old 09-02-2003, 09:10 AM   #673
Do your TCS rules in Australia allow you to mix and match different body and wing? ie Williams body with Ferrari front wing or vice versa?
Old 09-02-2003, 01:35 PM   #674
psycho's Avatar
I'd expect that you will need to run more dampening with the stiffer arms. That's what I noticed when I switched to the alum arms. Everything else was fine, though. No other changes were needed.
psycho is offline   Reply With Quote
Old 09-02-2003, 06:33 PM   #675
King-G's Avatar
Im not sure on that one as yet Niel, will look into that..
although our track is very small and technical..not sure Aero will come into it
NIP Tuned Chassis F201 AND spare F201 w/TONS of Hop-ups cartmen34 R/C Items: For Sale/Trade 11 04-23-2007 09:57 AM
F201 Corey The Great Australia For Sale/Trade 1 06-17-2006 09:21 AM
First F201... scarymonster Rookie Zone 2 12-13-2005 12:41 AM
Wtb: f201 car hpipro321 R/C Items: Wanted to Buy 5 08-30-2005 12:00 AM
F201 AQuionIV R/C Items: For Sale/Trade 7 06-30-2004 12:28 AM
